Question about Emerson Smartset Clock Radio
Projection malfunction New clock, new battery. The projection does not project clearly. You can only see part of the numbers.
  • Anonymous Nov 24, 2008
    have to turn the clock part of radio to wall to get the projector to work right
    President:
  • 814 Answers
Sorry it took so long to answer your question. This may be a problem with the adjustment of the light guide on the Clock/Radio. You must check your owners manual and make sure you adjusted the light guide correctly. If after making sure you have checked the owner manual for the correct way to adjust the light guide, you are still having problems with the display. You can call the Emerson Customer support at this telephone number 1-800-909-1240. Call them between the hours of 8am to 4:30pm central time USA. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you solve your problem with the projection display. Thank you for using FixYa and have a nice day!
Posted on Jun 15, 2009
Timer clock not working
Problem is not clear.
If this is new installation, then wiring is probably wrong.
Voltage and model number of timer is not known for certain.
You posted under T10404R that has 2 T104 240V timers.
Open following link for T104 wiring:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Add a comment and describe your wiring.
If timer worked before, then you might need $18 clock motor
Open following link for troubleshoot checklist and instructions for replacing clock motor:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 01, 2011 | Intermatic T10404R - two 220 time clocks...
The projection clock is not working
Since I'm not sure on the model, it's hard to say, but, on some models the projection clock is seperate from the regular clock. It is actually ran on batteries. If it rotates or moves, look underneath or around the projection housing for a screw or a sliding piece and change the batteries if it has any. If it is the same unit, you may have a more serious problem. Hopefully it's an easy fix!
Sep 18, 2009 | Sylvania Audio Players & Recorders
Remote signal not received by Shift 3 projection alarm clock
1) Does the remote have batteries? See other posts that describe how to do this (4 screws in back need to be removed). Temperature should be displayed in small window of the sending unit if it's working.
2) Hold Channel button for 3 seconds until it beeps - the unit then searches for a signal.
Aug 02, 2009 | La Crosse Projection Alarm Clock with...
Time projection repeatedly either fails to turn on/off/lock
You have to change the internal battery. The type of battery is a CR2430. This battery has only a three year life span in ideal conditions. If you have had power outages or left the Clock/ Radio unplugged for long periods of time the battery life shortens. You can find the battery is most electronic stores and in large drugstores and supermarkets. Fry's electronics, Radio shack.You must unplug the radio from the plug and let the microprocessor discharge and reset itself. This will take about a hour. After you let it discharge, you can put the new battery in the Clock/Radio and check to see if the problem is fixed.If this does not fix the problem, you have a damaged microprocessor and will have to buy a new clock/radio. Emerson does not provide out warranty service for this product. I hope this information help you with your problem.
Apr 05, 2009 | Emerson Smartset Clock Radio
Emerson Research Clock w/Projection Display Not Working
You will need to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio and remove the internal battery. Let the Clock/Radio set for at least 1 hour and then put the battery back in and plug in the Clock/Radio. The functions should return to normal. If not, replace the battery (CR2430) and leave the Clock/Radio unplug for a period of hours. Then put in the new battery and and plug in the Clock/Radio to see if the functions have returned to normal. If not you may have a more serious problem with the microprocessor. You can call the Emerson customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of the Clock/Radio and ask them for assistance. I hope this information help you with your problem.
Mar 25, 2009 | Emerson Smartset Clock Radio
I have a new Emerson CKS3528 clock radio with projected clock. The LED clock reads the correct time, which is 4:30pm, but the projected clock reads 9:30am. What should I do?
Sorry it took so long to give you some help with your problem.I hope You have returned the Clock/Radio for exchange at the place of purchase. If Not I hope You contacted the Emerson Customer Support and told them about the problem you are having with projection display malfunction. I hope they were be able to help you with the problem. if you have not already done any of the above, The contact Telephone number for the Emerson customer support is 1-800-909-1240 between the hours of 8am-4:30pm CT. Give them the make and model number of the Clock/Radio. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day.
Dec 25, 2008 | Emerson Smartset Clock Radio
Skyscan 34202 Projection
I doubt there is a way to change that, but it's also not clear which way it's supposed to go anyway.  Mine projects "right side up" if you are facing the same direction as the clock is facing - that is imagine you are looking away from the face of the clock.  It is upside down if you are looking at the clock's readout.  One way to solve the problem would be for you to turn the wheel of the projector to make it face the opposite wall.  It will then be right side up.
Oct 11, 2008 | SkyScan 34202 Clock Radio
Lg 44sz21rd
go to the EZ menu and select clock to reset to zero
Feb 12, 2008 | V, Inc. VIZIO RP56 Rear Projection...
Emerson Smart Set Clock Radio CKS3095S
You need to reset the microprocessor in the Clock/Radio. To do this you must unplug the Clock/Radio from the A/C source. You must also remove the internal battery (CR2430). You must let the Clock/Radio set without any power source for at least 3 hours to allow all the power to drain from the microprocessor. After the power has drained from the microprocessor, you can reinsert the internal battery and reconnect the Clock/Radio to the A/C power source.Now test the Clock/Radio, to See if the functions have returned to normal. If they have not returned to normal,unplug the Clock/Radio from the A/C power source and remove the internal battery. Replace this battery with a new Battery (CR2430). Let the microprocessor drain all the power out. Then reinsert the new battery and plug the Clock/Radio in to the A/C power source. The Clock/Radio functions should have returned to normal. If this is not the case, then you may have a more serious problem with the Clock/Radio. You will need to call the Emerson Customer Support. The Emerson Customer Support Telephone number is 1-800-909-1240. Give them the make and model number of your Clock/Radio and ask them for assistance with your problem. I hope this information helps you solve your problem. Thank you for using FixYa and have a nice day.
Jan 26, 2008 | Emerson Smartset Clock Radio
Emerson Smartset Clock Radio Logo
441 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
