Question about Canon PIXMA MX310 All-In-One Printer
When Trying To Scan, ScanGear Message Comes Up Saying Cannot Comminate With Printer.
Whenever I try to scan, no matter if im using the included software or have pressed a button on my printer and used the software from there. A Message appears says that it cannot communicate with the scanner Error Code 2,155,0. Its really annoying because I cannot scan anything.
Make sure the "Still Image Service" is running on your system. Right-click "My Computer", select "Manage", then open "Services" applet. Scroll down to the "Still Image Service", right-click it and set its properties to "Automatic", then right-click it and "Start" it.
Posted on Jan 04, 2009
  • unfadingbeau
    unfadingbeau Sep 25, 2012
    Now a days the service is called WIA or Windows Image Acquisition, not Still Image Service
I have the exact same problem, when I tried to access the WIA through services and I told it to start I got an error code: 1068 " the dependency service or group failed to start. Now I have a HP all-one hooked up and It works just fine. I have reloaded the software three time and I am in contact with Canon Support. This is the pitts.
Posted on Aug 11, 2013
Does ScanGear run on a Server?
Posted on Jul 23, 2009
  • 1,447 Answers
Try to check if the cables are connected from the back of printer to your computer, try unplugging and replugging it. then try scanning again.
Hope this helps
Posted on Nov 08, 2008
Scan gear is not detecting our IR3300, how can I
Make sure to use the B&W version of ScanGear not the Colour one.
Latest version I think is v2.21. See
Also make sure your copier has an IP address in the same IP range e.g. 192.168.0.x (where the first three numbers out of 4 are the same) as your computer.
Also turn scanning online at the copier using the instructions in the manual included with the download. Be sure to turn scanning off so that other functions can be used when finished.
You may wish to try disabling a firewall (temporarily) or a direct connection to the copier if you still can't get it to work.
Nov 10, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Unable to scan document
try to add your printer so that you can scan, just click start of your computer then go to all program the add printer or scansoft then restart your pc to take effect
Jun 30, 2009 | Canon (6981A002AA) for imagerunner 2200,...
Whenever i try to scan, i get a message saying there is no scan options
Was having the same problem. I was however able to scan using the HP Solution Center. My solution was to make sure "HP Digital Imaging Monitor" was running. I found mine in: C:\Program Files\HP\Digital Imaging\bin The program name is: hpqtra08.exe It has to be running befor you turn on your printer. It's use is to allow you to scan to your computer without using the HP Solution Center.
Mar 26, 2009 | HP Officejet 5610 All-In-One InkJet...
When I purchased my Canon 4370dn I was u7nder the
Actually, Omnipage should be included on the CD that came with the unit. If (and I mean if) scangear installs correctly AND locates your 4370dn on the network, it will install itself as a shim TWAIN driver. After the installation of Omnipage, you will need to do a scanner setup and identify the scangear shim as the scanner you intend to work with. After that, Omnipage should work just fine using your 4370dn on the network.
Word of warning: I've had a lot of trouble with scangear if it doesn't install correctly or locate your device on the network. For whatever reason, sometimes it just doesn't want to cooperate sometimes and seemingly nothing you do will convice it that your device is alive and well on the network (including continous ping to the device and/or opening the web interface while installing). This is particularly true for Win64.
Mar 04, 2009 | Canon i-SENSYS MF4140 All-In-One Laser...
Scangear Error
i think this problem come with windows xp update!
when u started to see this messege?
Nov 30, 2008 | Canon MP610 Photo All-In-One Printer
RemoteUI Contents is Not Found
Remote UI probably has not been installed on copier. Get a technician to come out and use SST to load RUI onto your copier. They should upgrade firmware to latest version at same time.
Don't forget you can also pull scan over the network using Canon Network ScanGear Tool in case you would like to scan.
Oct 18, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
joslloyd universal send is not available on the 3300 but it is on the 3300i.
You link to an old version of scangear software. Use
On the 3300 press System/Options button, One of four buttons far right, next to copy, fax, mailbox.
Press Online.
Read the manual included with ScanGear for how to set it up. Or ask if you are having difficulties.
Aug 27, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Scan Problem
try using a lower resolution for your scan... also this is a known problem for windows vista what o.s. are you using?
Jul 25, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP210
Im going through the same exact thing and I just hooked it up. I have only printed a picture but can't scan. Any help you find will be appreciated!
May 04, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
Apr 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
2,154 people viewed this question
old marine
old marine
