Canon pixma mp210 printer - replaced ink cartridges with compatible ones - printer working fine except when printing both ink lamps come on solidly, not blinking, and status says there is no ink in cartridges. Have tried resetting and disconnecting USB and power for 5 minutes but these lights still come on when about to print. Can you help please?
    Guru:
  • 183 Answers
Dear merryan,
This printer uses FINE cartridge which has memory chip inside that store ink level data. Once the cartridge is EMPTY we cannot restore this data to be FULL even though we physically refill ink until FULL. So the printer keep displays NO INK warning.
Similar with using compatible cartridge, NO INK warning still remain because ink level data has been recorded as empty. Why?. Here is the explanation. As far as I know no third party compatible cartridge produced this printer since canon protect it with the chip. Compatible cartridge that sold in the market is refurbish cartridge which repacked with another brand.
To fix this problem we need to deactivate ink level detection function by holding down STOP/RESET button for about 9 seconds or more for each cartridge. The consequence of this is ink level become UNKNOWN.
Hope this will be helpful to you
Regards,
Xanda
Posted on Nov 08, 2008
Error 5 MP210 canon
Error 5 means a problem with the ink cartridges. Try re-seating the cartridges, ensuring the cartridges are compatible with the printer. If this doesn't work, sadly the only solution is to get new ink cartridges. Ink cartridges have a limited life span, and yours may have reached their end.
Jul 16, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
MY ALARM ON MY MP210 IS ON AN MY COLOR INK FLASHES WHAT DO I DO
Check the status of each cartride by using the ink lamp.
You have 3 lamps
(A) Alarm lamp
(B) Black ink lamp
(C) Color ink lamp
Make sure that the LED is on standby mode.
a) If the ink lamp lights.
Cause : Ink is low.
Action :You can continue printing for a while, but we recommend you have a new FINE cartridge available.
b) The Alarm Lamp lights and the ink lamp flashes .
* If "E, 1, 3 " is displayed on the LED, ink has run out.
Cause : Ink level cannot be detected.
Action : Ink may have run out.
The function for detecting the remaining ink level will be disabled since the ink level cannot be correctly detected.
If you want to continue printing without this function, press Stop/Resset buttonfor atleast 5 seconds.
Canon recommends to use new genuine Canon cartridges in order to obtain optimum qualities.
* If E,1, 6" is displayed on the LED,
Cause : Ink has run out.
Action. Rreplace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress, you want to continue printing, press the Stop/Reset button for atleast 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
c) Only the ink lamp flashes
Cause : The function for detecting the remaining in level is disabled.
Hope this helps.
Please rate my response.
Thanks
Have a good day.
Dec 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Is MP210 and MP240 the same? can i use the same cartridge?
no both are different
Here are the list of cartridges u can use
MP210
PG-30 Pigment Black
PG-30 Pigment Black Ink Cartridge
PG-40 BLACK
CL-31 Color FINE Ink Cartridge
CL-41 Color
MP240
PG-210 Black Cartridge
CL-211XL Color Cartridge
CL-211 Color Cartridge
PG-210 XL Black Cartridge
Nov 28, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Canon MP210 Third Party Ink Canon Does Not Work!
When the error message comes up, try pressing the "stop/reset" button and holding it down for at least 5 seconds. This works when I get an error message with compatible cartridges (only my error message says the ink is empty - and I know it isn't)
Jul 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
How do I change the ink cartridges on a canon mp210
tget the manual free copy this site and paste it in your ADDRESS BAR and hit ENTER.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp210#BrochuresAndManuals
(14) FINE Cartridge Holder
Install the FINE Cartridges here.
The Black FINE Cartridge should be installed into the left slot (ug_before_printing6.jpg) and the Color FINE Cartridge should be into the right slot (ug_before_printing7.jpg).
(15) FINE Cartridges (Ink Cartridges)
A replaceable cartridge that is Print Head and ink tank integrated.
i_note.gif Note
For information on how to install the FINE Cartridges, refer to your setup sheet.
(16) Scanning Unit (Printer Cover)
Scans original documents. Open it when replacing the FINE Cartridges or removing jammed paper remaining inside the machine.
This is in the first part of the Manual.
Hope this is of some help. Bud
Jun 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Scanning problem
For scanning, the printer need the cartridges in place. So the best thing is to place your cartridges back in the printer ( even if the are empty).You can refill the cartridges but the niveau wil still be empty. To print again, press the paperfeed button at least for 5 seconds. Now everything wil work fine again, except the inkniveau meter. So dont print when one color is empty.good luck.
Dec 10, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon pixma mp210 and compatable ink cartridges
Try pushing the reset button for about 5 seconds. This has worked for me.
Oct 27, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Ink cartridge
See this link. The PG-40 and CL-41 are high capacity versions of the PG-30 and CL-31.
May 30, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Canon Pixma 210 - Error 5
Just changed black ink cartridge and now getting Error 5. WIll not print at all. I am quite sure the new cartridge is compatible, it a like for like replacement. Is there a way to reset or resolve this issue? thanks
May 29, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
1,164 people viewed this question
jasbo
jasbo
