Question about Toshiba Portege S100-S1133 Notebook
My wifi not working
I have new asus x80 L series. after i reinstall new window and all the drivers only wifi not connected to my wireless router. i check evrything ok. what should i do?
Ramle. Thank you.
  • 741 Answers
Go into the Device Manager. If you have a yellow! or Red X by the wireless adapter, then right-click on it and get new driver. This should take care or it.
Posted on Dec 22, 2008
What known wireless issues exist with the Asus TP500L?
have you updated the drivers for the WIFI adapter to the latest?
Also, there were different standards for WIFI in the past, so if your router is really old you may see issues. Is your WIFI router at the latest firmware?
updating the driver should resolve your issue.
Nov 15, 2014 | ASUS Transformer Book Flip TP500L-UB51T...
I need to reconfigure my router
download the latest wireless drivers for your computer on another pc/laptop and reinstall it on your new windows 7 box. try and reconnect to your wifi
Feb 20, 2012 | NetGear WNR2000 Wireless Router
I just bought this asus K42F series and I cannot connect to the wifi here in our house. the wifi is functioning properly because my friend's laptop was able to connect to the same wifi. and my asus...
Change Your Wireless Channel
If you're using a Linksys router, you'll need to browse to the address of your router, which is probably set to but could be assigned to another address. You can run a quick ipconfig command at the command prompt to check:
In my case the address is different (because I changed it, of course), but what you're looking for is the Default Gateway for your Wireless connection, and then go to http:// in your browser. Enter in the password that you hopefully remember, and head to the Wireless -> Basic Wireless Settings tab.
My router has two separate bands, but your router might just have a single band here. In my case, what I've done is set the 2.4 GHz band to only be used for Wireless-G, and the 5GHz one to Wireless-N only. Since I'm not having any problems with the Wireless-N settings, I've left those on auto.
Where I am having a problem, however, is my Wireless-G devices-so what I've done is chosen channel 9, since it's the only channel that's not being used by any of my neighbors, who are using mostly channels 1 and 6, though a few are using 11 as well.
Channels 1, 6, and 11 are the most common channels to choose, and most routers will use one of them as the default channel-but the general idea is to be as far away from everybody else as you can.
Note: I've also configured my router for 20 MHz only on the 2.4 GHz Wireless-G band, just because that was the only way it would let me choose the standard channel manually.
If you are using a different router, the IP address will generally be the same, but you'll have to figure out how to change the Wireless channel without any screenshot tours. It's usually fairly easy, though, once you know what you're looking for.
Fun Technical notes
Jul 18, 2011 | ASUS K42F A1 Notebook
I'm trying to connect it to my wireless router and it's not connecting
try reinstalling the wifi driver and if it still doesn't work then update the driver online... else
Run ipconfig /all from a command prompt & post the output....
Mar 11, 2011 | Sylvania G-Netbook
Hi I am using ASUS router rt-g32 . whenever I connect my inernet via ausu it is not working but through ADSL modem internet is working fine. please help.I have reinstall and instaleed software of ASUS...
My asus rtg32 wifi wireless router is not getting connected to net. It shows connected (router with laptop) but its not connecting to net. I am not able to openany site. I m using BSNL connection. It shows no internet access.\r\n
Please suggest me what to do, what procedure to follow. Mine is windows 7 , 32bit OS
Aug 14, 2010 | ASUS RTG32 Router
Wireless adapter has suddenly stopped working.
First unplug your adapter and boot your computer. It wouldn;t hurt to reboot it once as well. This should clear out any settings. When it has fully booted up only then insert the adapter into a different usb port. If it recognizes it and works it can indicate a usb problem.
If it finds it but doesn't connect a adapter problem. You can uninstall it and reinstall the drivers and it might work. If not replace. If it does nothing then its died on you and your adapter needs to be replaced.
Most adapters and home network units (wifi routers etc) only last for 1-2 years before they act up or die on you. Very annoying and can be expensive. I have a stack of wifi routers where the wifi isn;t reliable but the rest works. And a drawer full of various wifi adapter that are detected but not connected and a few just plain dead ones. All of them seem to fail at about the same time after purchase.
Jul 09, 2009 | ASUS (WL-167G) 802.11g/b (wl167g) Wireless...
How to change (or update) wap to wpa encryption on ASUS WIFI-B Network Adapter
With this Asus wireless B adapter even the new driver dont support WPA wireless security , because right now sicne WPA is a much newer and higher type of wireless encryption only some wireless B adapter supports that and sorry to say this wireless adapter that you have don't support it even with the latest driver so it will be better to get a new wireless G adapter that supports WPA 100% , you can get the wireless adapter from Asus or from other wireless device manufacturer like Linksys, Netgear. Dlink and Belkin....
Nov 02, 2008 | ASUS WIFI-B Network Adapter
Intermittent WiFi with ASUS WL-500W
I had the same problem. The problem is interferance from other devices. Solution, Change the channel from auto to a fixed one. That worked for me. No more droped connections, and a very strong signal now.
May 16, 2008 | ASUS WL-500W Router (WL500W)
Asus Wifi-b Nework Adapter
Hi Tony872,
Do you have a wireless router hooked up to your broadband modem?
If you do not, you will need to purchase a wireless router to hook up to your broadband modem if you want to have wi-fi in your home.
Here is a link that will provide you with some wireless routers that are available.
I hope this helps you out.
Agent Xiong
Apr 17, 2008 | ASUS WIFI-B Network Adapter
Linksys wireless card with ASUS WL520g Router - encryption error
you have changed the network key, but why update the username and password as it should always be the same which is the one supplied to you to connect to your service providers connection, assuming you mean the security key, go to your pc and search for your network again, as it will be trying to connect to a non existant unsecured router. When it searches and finds the networks in your area, choose yours click connect and the enter password window should pop up to be entered. Go to your browser and clear old temp files and cookies in tools, internet options, restart pc and you should assuming you have put the correct settings in be online.
Sep 13, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Toshiba Portege S100-S1133 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
