Question about Kenmore Dishwashers
Dish washer not draining
Dishwasher not draining (13472). just keep washing. What should I do?
  • 1,447 Answers
If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposal, be sure the knockout plug for the dishwasher was removed when the connection was made
1) Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink), and, using a wire, clean it. Also check the entire length of the drain hose for kinks and blockages, especially at the drain connection to the disposer or drain line.
2) Once the dishwasher is cool, shut off the power to it, and—if your dishwasher is made to allow this—remove the strainer, located under the bottom spray arm at the base of the cabinet (see illustration). Unscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, and then replace it.
3) Determine whether the sink trap or house drain line is clogged.
4) If the dishwasher still doesn't drain properly, the drain hose may be clogged or the drain valve may need replacement. At this point, it's usually best to call a repairperson. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose.
Hope this helps
Posted on Nov 08, 2008
My kitchenaid dishwasher kudc101xbl4 won't quit running or cancel / drain button light stays on and none of the other buttons work
If you wash your dishes off before you put them in the dish washer the sensor for the food particles won't pick it up and it will keep running. My repair man told me when he repaired my dish washer.
Sep 23, 2014 | Dishwashers
Frigidaire dishwasher model FDB520RHS2 will not advance pst wash- just keeps washing draining and refilling the wash. does not advance. Left it run for 3 hours, still wash only
We had a problem with our dishwasher, it just went crazy one day and lights would light up but ours did not wash or anything...anyways upon further investigation found out by taking 6 large round head screws off,, the handle and outer cover came off, then there was a cover that was covering a circuit board and this was the brains of the washing machine, ordered the part from sears 160.00 and washer is all set. good luck. oh ya, upon further exam. when I took the board off could see discoloration on part of the circuit board. this means burned out resistor or fuse.
Mar 22, 2014 | Frigidaire Dishwashers
The water does not get hot enough. I think it's the reason why dishes are not coming out clean. In normal conditions do I need to wash the dishes (like the manager of this apt. complex suggests) before I...
No you need not wash the dishes but just cleaning of the debris and then putting it in the dishwasher for proper cleaning will help you to prevent the drain from getting blocked.
First perform a vinegar cycle wash in the dishwasher. Pour a cup of vinegar into the bottom of the dishwasher. Keep the temperature at the highest setting possible and perform a wash cycle.Then start using a dishwasher most probably that would solve the problem. If this does not solve the problem then there must be some parts worn out or faulty creating the problem.
There are many probable causes of failure .
To clean the dishes the water temperature is essential.It the water is not hot then the dishes will not be cleaned properly.So check the water temperature.
Also check the filter in your dishwasher.Clean the filter if there is accumulation of debris in the filter.
Feb 22, 2011 | Whirlpool Dishwashers
Just washing, not drying and cleaning. watter was not draining
Sounds like your drain is clogged. The drain should be located just below the blades inside the dish washer when you pull the lower rack out. If you can clean it from the top end, that could be a simply fix. Otherwise you'll need to pull the dish washer out and clean the drain from the bottom.
Also, check your Blower Fan to make sure it is still running.
Jul 16, 2010 | Kenmore 24 in. 16032 Built-in Dishwasher
Miele Dishwasher G841 - Water not draining after wash cycle
If you suspect the dish washer, try discharging the drain in a bucket. After the drain cycle check the wash tub. If water is still left, you have to clean the drain filter attached to the bottom. Refer user guide.
The final drain end of the dish washer where you discharge, the fixing junction has to be cleaned, incase it is clogged.
Jun 01, 2010 | Miele 24 in. Touchtronic Platinum Built-in...
There is water in built in dishwasher when cycle is done.when you open door it runs out and rest remains in bottom of dish washer about an inch and a half of water.
The drain hose is supposed to go from the garbage disposal to a high point under the sink in back to keep the water from gravity draining into the dishwasher when it shuts off. If you look you will see that the hose is laying on the bottom of the sink cabinet. Get a hook and wire it up so you're not washing dishes with water from the disposer. Be sure to run the disposer. if it is clogged with food the dishwasher will not drain, water will back up and drain back into the dishwasher. Also make sure that the pipe exiting the disposer isn't clogged and draining slowly. hhe best solution is to have an air gap that mounts on the sink. It goes between the washer and the disposer to keep this from happening.
Mar 25, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
Mar 21, 2007 | Electrolux 24 in. ESI6220X Free-standing...
Dishwashers Logo
197 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
