Question about HP LaserJet P2015dn Printer
HP P2015 Has Paper LED Solid Lit. Will not go off. Help!
I have two printers that do the exact same thing. The paper LED is solid. I have changed paper trays. changed the type of paper in the tray and it will not continue past that LED.
  • 2 more comments
  • mcanning Jan 22, 2009
    All 3 error lights are lit and the Go light is off (top 3 lit & bottom 3 are not lit)
  • Anonymous Mar 06, 2009
    same problem
  • kkao Mar 27, 2009
    Paper LED (not Paper Jam LED) is stuck on. Removing the memory upgrade solves the problem. But why is it stuck when memory is installed in the memory upgrade slot? I've tried different DIMMs from different memory manufacturers in several P2015 series printers with no luck.
  • Anonymous Mar 30, 2009
    Had the same issue and the solution resolved it for at leat the short term.
    Sniper:
  • 87 Answers
It seems that none of the printer's sensor is faulty, in fact, the printer has a faulty firmware on the formatter.
Your printer may need replacement of the formatter board, however, please try the following before swapping the formatter.
HP LaserJet P2015 Printer Series - Paper Jam Light Solid ISSUE: The HP LaserJet P2015 may come up with Paper Jam Light solid and would show the same light pattern even if the printer is power cycled.
SOLUTION: The Light pattern is as shown in the diagram below.
Perform the following tasks in the order listed.
1. Reset the printer using the Super NVRAM initialization. The procedure is
a. Turn off the printer
b. Press and hold the GO button
c. Turn on the printer and continue to hold the Go button for at least 50 seconds. During this process the Attention, Ready and Go light turns on. Then the Attention and Ready light turns off, leaving just the Go light illuminated.
d. Release the Go button. The Go, Attention and Ready lights turn on.
e. Press and hold the Go button. All lights turn off. During the next three seconds, the Go, Ready and Attention lights turn on in that order, one per second.
f. Release the Go button to perform the initialization. The control panel lights begin cycling from front to back. After the Super NVRAM initialization process is complete, the printer returns to the ready state.
2.Unplug the power cord when the printer is on and leave it unplugged for 10 Seconds.
3. Turn the printer back on.
If the above steps resolve the issue, then print a configuration page and check the firmware version and the formatter board no.,
If the firmware version is below: 20080312, then your printer needs to upgrade the firmware, however the firmware can be upgraded only onl those models whole formatter board's third number from left is 0, 1 or 2, eg: JK0xxxx
If the 3rd number from left of the formatter board no is anything other than 0, 1, 2, then firmware cannot be flashed.
Please let me know the next update.
- Nikhil
Posted on Nov 10, 2008
    Problem Solver:
  • 11 Answers
GO TO THIS SITE.
http://www.fixyourownprinter.com/forums/laser/48992#22
THIS IS A KNOWN PROBLEM WITH THE P2015 PRINTERS AND PRINTER NEEDS TO GO BACK UNDER WARRANTY.
THE EPROM ON THE FORMATTER IS BAD
Posted on Nov 12, 2008
Models P2015 and P2014, do the have the same formatter boards?
Posted on Jun 25, 2010
Orange light on SIDE (not top) of HP LaserJet P2015 Series printer won't go out. Have disconnected all leads and re-booted printer and computers (2) to no avail. There are no paper jams and have
Is there any text to indicate what this light refers to?
In general, you might want to remove paper trays, and use a compressed air can to spray inside the printer, especially the paper path. Oftentimes, paper dust will impede a photo-optic sensor, and keep an indicator light lit when there i no real reason for it. It can also give you a paper jam indication when there is none.
So blow out all paper dust to get the printer to work correctly now.
Cheers!
-a.
Apr 10, 2012 | HP LaserJet P2015dn Printer
I can't seem to get my HP P2015 to work. When I turn it on, it just comes on with a solid orange light designating a Paper Jam, but there is no paper in the machine.
couple things that it could be are your pick-upn roller is not picking up paper and needs replaceing because they break occasionally, another thing is that the shutter link assy., the black and white plastic piece that is in the upper right when you open the printer could be defective or the plastic arm that goes in there is possibly broken off.
Jan 28, 2011 | HP LaserJet P2015 Printer
HP P2015 Intermittent paper jam lite on solid.
Remove the covers and thoroughly clean the inside of your printer. Vacuum it out and wipe it down. Then examine the sensors and their wiring connectors. Intermittent problems are difficult at best. I suspect a thorough cleaning will eliminate it.
Nov 09, 2009 | HP LaserJet P2015 Printer
HP LaserJet P2014 keeps showing paper jam when there is no paper jam. How to clear?
If paper jam light is solid than checked paper path sensors and toner sensors and if they are aligned correctly than perform cold reset(Keep pressing and holding the green button) if still the issue persists and orange light remains solid than i m sure formatter board is faulty and we need to get formatter board replaced.
Thanks and Regards
Neeraj Sharma
Jul 01, 2009 | HP Office Equipment & Supplies
My HP P2015 reports a Jam when there isn't one
Take the Tray 2 out and check if all the paper guides are moving freely if they are than remove the toner cartridge and check if any toner sensor is not align correctly.
If they are aligned correctly than next to the pickup roller there is a small piece of plastic make sure it should be hanging freely if it is than we need to perform cold reset of the printer.
Switch off the printer press and hold down the go button and switch the printer on keep holding down go button till the time three lights lit up on control panel, as soon as three lights lits up release the go button and let the printer initialise of it s own.
If that doesn't fix than Formatter Board of the printer is faulty.
Logic:
If there is no paper jam and printer rep[orts the jam means either any of the sensors is not aligned correctly and reporting the jam or formatter Board(Motherboard) of the printer is faulty and showing incorrect display.
Thanks and Regards
Jun 20, 2009 | HP LaserJet P2015d Printer
Printer problems - solid yellow light down on HP P2015
Logic:
Thanks and Regards
Apr 20, 2009 | HP LaserJet P2015dn Printer
HP P2015 Has Paper jam lit and will not print
Try removing paper from the printer and put papers in the tray. Also try one round of cleaning.
Mar 23, 2009 | HP LaserJet P2015dn Printer
Dell 1110 Laser Printer Solid red warning light
Hi in this case the paper jam made some sensor through the paper road they are not in normal position or still tigger on by piece of something or error stander. you may try:
1) check paper input sensor near paper tray roller\
2) check margin sensor inside paper way before drum unit
3) check fuser sensor near fuser unit
4) check paper output sensor near output tray roller
sometime need sensor adjustment back to normal position
Dec 22, 2008 | Dell 1110 Laser Printer
Hp laserjet p1250 error
Check this out the paper i was using was cheap then it rained all week the humidity caused my paper to be to heavy to grab and pickup i changed the paper with hp paper and a new batch and wallah it started working again!
May 18, 2008 | HP LaserJet P2015dn Printer
HP laserjet P2015D , JAM LED in a solid state ??
Dear gentlemen,
Hope this helps you sort out the problem. Please check paper jammed pieces of paper remains from paper in to out paper path. Check if the paper is properly picked-up, else check rubber roller pick-up and the solinoid motors that control to fed on and off the tray to engage pick-up. Check paper path sensors if possible. If you can determine when is the paper Jam happens please advice. Other means you can also refer your manual and machine diagnostic menu which part of the operation the paper will jam.
Best regards,
Rosener Guyano
Jan 10, 2008 | HP LaserJet P2015dn Printer
HP LaserJet P2015dn Printer Logo
10,324 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
