Question about Kodak EASYSHARE 5100 All-In-One Printer
Getting Kodak AiO home centre software to work
Good day etuckram,
I had one of their tech guys spend many hours with me trying to get this software to install. He told me it uses .net framework 2.0 and mine was probably corrupted so we renamed that so the install would ignore it. Although he did not say, I presumed the install includes .net framework 2.0. Can I uninstall this and re-install it, can I get this from Microsoft?
Interesting note, I only want the AiO not anything else, but the install still tries to install the EasyShare portion of it.
Regards
James
  • 34 Answers
Hi James, Thank you for considering me as an option to your answer. I love Kodak and their products but as we all know, manufacturers have defect on their own but it can be fixed. Going back to your issue, you can uninstall the .net 2.0 for it is not a windows xp requirement, you can also download it for free from microsoft. The only thing is, if you have a program that uses 2.0 it may not work for the meantime once it is uninstalled. Let me know if you have some concern. Willing to help you to the best of my ability.
Posted on Nov 09, 2008
How important is downloading kodak home centre software for the kodak printer to work?
Kodak AiO home center, serve as a driver as well for your printer to print from the computer. It will let you scan, copy or print pictures. AIO home center will let you select the settings you want for your printer
Sep 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
The kodak aio home center won't open getting error 1--2010 esp3 printer
if using vista try this:
Right-click on the Home Center icon.
Select Properties.
Select the Compatibility tab.
Click Run this program as administrator.
Click OK.
reply if does not work.........
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak AiO home Center will not open
My son has the same model and issue. I had him go to http://www.kodak.com/global/en/service/downloads/dln_ekn034524.jhtml?pq-path=12667 and get the latest software and firmware update.
Make sure to use the dropdown to select your operating system. The page defaults to XP.
The software is a new version of the AIO home center.
The firmware installer updates the physical printer. Before you run this program be sure to read and understand the instructions.
If both ink cartridges have good levels of ink, and you keep getting the clean the print head issue after updating both the software and the firmware, then call Kodak support. 1-800-421-6699, 7 A.M. to midnight Eastern time, 7 days a week. They will ask you if you put in new cartridges and installed the updates for the firmware and the AiO centre software. Be patient. They will get a solution for you.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
My Kodak 5100 prints colour but not black
if you have the software installed on the computer and if it is Xp then click on start button and go to all programmes and go to Kodak and there would be AIO home center......it is vista then click on start button and go to all programmes and scroll down to find the Kodak and when you click on it there would be AIO home center........there is more if you dont find it so let me know
Jan 05, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Home Center will not open...Can't scan
I finally figured out that it was my "Assembly Registration Utility" whatever that is.Reset my computer back to the factory settings and got the printer downloaded which also cured some other problems.Might not do it for u but worked for me,hope this helps u also.The printer is working really great now!
Jan 02, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Uninstalling .net 2.0 software
It could make your other software stop running but you will reinstall it right away so you have nothing to worry about.
willing to help,
etuckram
Nov 19, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak AiO software
Hiya,
Here is the link to the Kodak clear utility tool for removing their software:
http://wwwuk.kodak.com/global/en/service/downloads/private/xp_vista_98_ClearUtility.jhtml?pq-path=12361
Select what software you need to remove from the drop down list, click continue and follow the instructions from there.
I hope this helps.
Mike
Sep 13, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
AIO Home Centre
Try to do the following:
Go to www.kodak.com/go/clear ; download the utility and run it.
After that, go to www.kodak.com/go/downloads and download the Software with drivers. If it still giving you trouble, call Kodak AIO tech support.
Aug 10, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
On some vista setups the Kodak Software needs to be set to run as administrator
1. Right click the Kodak AiO Home Center icon and select 'Properties'
2. Select the 'Compatibility' tab
3. Make sure the 'Run as Administrator' box is checked
4. click apply and ok.
Hope this helps
Feb 29, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
I needed to reload my AiO Home Center software and no one seemed to have the correct procedure. Maybe if you remove & reinstall yours it will resolve your problem. This procedure worked for me on my XP-machine:
1. got to Control Panel/Printers&Faxes and delete the printer
2. go to your Hardware/Device Manager/Universal Serial Bus Controllers, right-click on USB Composite Device and select Uninstall
3. go to Control Panel/Add/Remove Software and remove the EasyShare software
4. disconnect the cables from the Printer
5. download from Kodak.com the program "install_aio.exe"; run the program
(I selected only AiO+EasyShare+Software Updater to load)
6. followed the prompts after the sw installed to reconnect the Printer cables
7. rebooted
WORKED for ME !
Jan 13, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
117 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
