bought a toshiba equium A60 2 years past september it shuts down after a few hours while on main power,no warning ,happens all the time,tried rasing computer to allow ventilation and it seems to help a little but still shuts down more than once a day.
please help im really worried it might blow up i my face when i least expect it
My Mom's Toshiba Satellite had a similar issue, started running hot, got a laptop cooler, that worked for a while. Then it started to shut-down without warning. I thought it might be a bad power supply/defective battery. Did a search, found a user group that filed a class-action lawsuit about this issue. Turns out many of those laptops have a design flaw. There is a gap between the CPU heat sink and the intake fan. Apparently the gap gets clogged with dust, animal fur, lint, etc. I removed the bottom cover & discovered the gap full of lint & cat fur. I gently peeled the strip of lint out with a dry cotton swab (wore anti-static wristband while inside of laptop), then blew out the inside of the laptop with canned air. From there I tacked fine nylon window screening inside the bottom cover over the fan vents (very sparingly with Krazy Glue). After the glue dried I replaced the bottom cover, Mom hasn't had any overheating issues since.
I have a toshiba laptop which was unexpectedly switching off. The laptop was 2 years old. I did lots of searching online to discover this is a VERY COMMON ISSUE.
The problem is, dust blocks the heatsink. When I took my computer to pieces, I found a strip of dust half an inch (1cm) thick covering the back of the heatsink which prevented air flow. If your laptop is a couple of years old, this could be the problem. When I removed this dust, the problem disappeared.
If you are computer savvy, then try the following - if not, take it down to a computer shop!
1) Remove the 5 screws holding down the heat sink cover and processor cover. These are on the bottom of the laptop, in the centre, at the back.
2) Remove the 3 screws which hold in the heat sink in place.
3) Remove the heatsink
4) Take the dust out
5) Re-assemble
a note: be careful not to get dust in the thermal paste on the cpu - unless you have replacement paste.
Good Luck!
Was this helpful?
Yes
No
Solution #4
posted on Jun 30, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I suggest you need to clean your system plus the dust is covering the air existing from CPU fan. This will solve 90% of the problem you have
If ventilating helps, check that the vents on the bottom and where the fan blows out warn air are'nt blocked, try gently hoovering around area witha nozzle.
What is rtl120.bpl. A box appeared whenever I start my PC, asking me to re-install rtl120.bpl. I am...
(More)
What is rtl120.bpl. A box appeared whenever I start my PC, asking me to re-install rtl120.bpl. I am confused.? re-install rtl120.bpl. Lost Adnanced System care at the same time ?
fault: trips psu when power is applied on lap top /????? falult is laptop satrs than shuts down cud...
(More)
FAULT: TRIPS PSU WHEN POWER IS APPLIED ON LAP TOP /????? FALULT IS LAPTOP SATRS THAN SHUTS DOWN CUD THIS BE THE CPU ??? ITS A TOSHIBA EQUIUM A60 EA..
