I am using a micronet wireless router to connect to the internet but it won't connect to the internet, but if I just connect to the normal modem it works. How can I get the router to conenct to the internet?
  • alex_overend Nov 08, 2008
    1. Virgin Media
    2. I connect the modem using the ethernet cable to the wan port.
  • Jannette Amandy May 11, 2010
    1. Who is your Internet service provider?
    2. How do you connect your modem to the router? Which port of your router did you connect the modem?
  • 132 Answers
Virgin Media is a cable ISP, right? What is the IP address that your computer obtained when it is connected to the Micronet router?
Posted on Nov 08, 2008
My modem and router won't work simultaneously
They chain together. Connect the modem first to the ISP drop. Then the modem to the routers main port. Then the connect the PC to the router.
Modem > Router > PC
Jan 09, 2013 | EnGenius Technologies ESR-9752 300mbps...
How do I discover or reset the password
Your modem if it is a Speedstream 5200 does not have any wireless capability and as such, there is no need for a password. You can only use one computer connected with an ethernet cable to your computer. What you can do is purchase a wireless router, preferably a N series wireless router because it is stronger than a normal G series router. Normally your modem connects to your computer via the ethernet cable. With a wireless router, instead of plugging the modem to your computer you should plug it in router. From the router you can connect another ethernet cable and plug it in on your desktop. You can connect at least 4 wired computer to your router. For the wireless part, all they have to do is look for the strongest wireless signal then hit connect. If it ask for a password then it should be in the sticker at the side of the wireless router.
Dec 14, 2011 | Efficient Networks SpeedStream 5200 Modem
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
Can not connect with my home computer.Router and modem working,just won,t connect
Configure the Router 1. Step 1
Open your web browser, type " " into the address bar and hit "Enter."
2. Step 2
Use "Admin" as the username in the pop-up box and leave the password blank.
3. Step 3
Connect to the Internet and click on "Internet Setup."
4. Step 4
Select your connection type from the drop-down menu. Choose "DHCP" for cable modems or "PPPoE" for most DSL modems. If you are unsure of these options, check with your ISP.
5. Step 5
Set a service set identifier (SSID) to identify the router and change the password.
6. Step 6
Encrypt your wireless connection using a Wireless Encryption Protocol (WEP) key. Under the "Wireless Security" option, enter a passphrase and click "Generate." This will generate a password which will need to be used by any client connecting to your router.
May 14, 2010 | HP Pavilion dv6000z PC Notebook
Router won't broadcast
Use your computer's web-browser to connect to the web-server "inside" the router.
Check the 'WAN' settings -- they seem to be OK, since you have Internet access.
Check the 'Wireless' settings, or just rerun the Wireless Configuration Wizard, to rebuild your wireless network.
Apr 24, 2010 | Linksys Wireless-G WRT54G Router
Belkin wireless G router and MicroNet Realtek RTL8187B USB
I got the answers (for free) from Belkin's excellent technical support.
Many thanks.
Jun 18, 2009 | Belkin (F5D7230-4) Router (587009)
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
How to activate wifi 802.11g;ADSL2+Router
switch on modem, computer. launch internet explorer. type in tool bar. You will get prompt for log in. log on id is admin, password is 0000. now, you will get connected to modem. On left side list, you will see "Wireless". Click on this. you will get to Modem wireless basic page. Tick "enable wireless",change country to India,click save/apply. Now open control panel on your laptop. You will be having wireless network tool / wizard. Click on this, follow the prompts to connect to the wireless network that gets detected automatically.
Nov 08, 2008 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
