Question about JVC GR-D270US Mini DV Digital Camcorder
Videocam charging and keeping moisture out
Greetings,
how can i prevent overcharging of batteries and how to keep the videocam moist free specially when not in use for a long time? where can i place my videocam if i will not use it?
during travel, what can be suggested when charging inside an airconditioned room like hotels to prevent moistures and how to prevent power surge or over charging?
thankyou
steve
  • steprock2003 Nov 08, 2008
    thankyou sir,
    sir i got a replacement battery from singapore but made in japan. the one i got is for 7 hours use. how will i charge the new battery a little bigger from the one with the set? first charging is 6 hours, how about the succeeding?
    thanks again
  • Toyota Ed May 11, 2010
    MisterSony is very well versed in this field. I would rate his solution as a FixYa.
  • 320 Answers
The internal charger in the camcorder has sensors to prevent overcharging. Be sure to use an original JVC battery, as there is also a sensor in the battery to prevent overcharging and the inexpensive replacement batteries will not have the same sensor (some have NO sensor at all!)., In terms of keeping moisture out, avoid going from an extremely cold environment to a hot one, or vice versa as this can cause condensation to form in the camcorder. If you are taking the camcorder to a place where it might get wet, say the beach or out in the rain, place the camcorder in a ziploc bag to protect it. Be sure to rate this solution. Thanks!
Posted on Nov 08, 2008
  • Any Guy
    Any Guy Nov 08, 2008
    First, may I ask why you rated my solution as Helpful? i thought I had answered all of your questions.
Can't find float charger, can I just use a regular battery charger?
You can but keep track of charging time and unplug after use. Constant charging will damage battery. Float chargers use trickle type charging and are designed to keep battery topped off without overcharging. Got it?
Sep 06, 2017 | Cameras
Ndrive g800r battery charging
Li-ion battery packs in laptops have a circuit board that prevents overcharging. Unfortunately it also keeps count of the number of times the battery pack has been through a charge/discharge cycle and eventhough the batteries maybe still be good; IT keeps batteries from accepting a full charge and and that is why they will not keep a charge for as long as they did when new. Also if any battery in the pack goes bad it effects the whole pack because of the way they are assembled.
May 19, 2017 | Computers & Internet
I have a very noisy fridgidare upright freezer causing snow on contents inside it?
Hi Lisa, thank you for your post! New freezers retain colder temperatures. Especially on hot humid days, moisture entering the freezer (when the door is opened) can form frost inside the appliance and moisture collection inside the unit. Reducing energy use to meet government requirements, defrost heaters have shorter run times. Light loads in the freezer also contribute to the problem.
Here are some tips to keep moisture low in the freezer:
Use your air conditioner to reduce humidity.
Arrange shelving and food items so air circulates.
Don't "overload" or leave the freezer empty. It should be at least half full.
Set the controls as recommended in the use and care guide. Manufacturers may suggest different settings for summer and winter.
Properly seal liquids and high moisture foods stored in the unit.
Open the freezer doors as few times as possible.
Clean condenser coils at least twice a year. Check your use and care manual for specific procedures. You'll save energy, too.
Cover pots and pans and use the range hood fan when cooking to reduce moisture in the kitchen.
Check and maintain door gaskets. A good door seal keeps warm moist air out of the freezer.
These tips will help control frost and moisture in your freezer, but won't always eliminate the problem, especially when humidity is excessive. If you have taken all necessary steps to prevent moisture and humidity, you may need to reach out to a professional for further diagnosis.
Hope this information helps resolve this issue.
Aug 22, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
As you your battery life of your notebook ? The main problem with laptops is often the battery , after a year of heavy use loses almost 50 % of the power . How can I prevent that ? Have you could keep a...
I have some tips to keep your laptop battery live longer
1.don't undercharging and overcharging,laptops battery can reach 100 degress Fahrenheit and such heat can damage your battery. slowly but sure
2.ideally,you should try to keep your battery charged from 20 percent to 80 percent. i know it's inconvenient to unplug the charger before it reach 100 percent,but try to keep it charged near 80 percent
3.try to charge your battery constanly,and unplug it when you think its almost fully charged,overcharged can heat your battery and damage it
4.keep your laptop as cool as possible,don't try to charge the battery when the computer is turned on,even if the battery is going to 0 and you still need to use it,just shut down the laptop first and charge it,at least until the battery is charged 20%,unplug the charger and turn it on
Well,there are many other tips to keep your battery alive,but i only have those 4,thanks for using fixya
and good luck with the tree-planting project,i love environment very much
Aug 29, 2012 | Dell Latitude D630 PC Notebook
Keep leather shoes moist
Why do you want to do that? Leather is like skin in that it needs some moisture in it, but no too much! Saddle soap will help moisturize leather
Jul 16, 2012 | Element Electronics Element Skateboards...
CAN YOU LEAVE A RECHARGEABLE BATTERY FOR A 19.2 VOLT CRAFTSMAN CORDLESS DRILL IN THE CHARGER ALL THE TIME/
It depends on the charger taht comes with this drill, the dumb charger will just keep on charging the batteries even when it if fully charge and does not sop, which will be bad for the batteries, the smart charger (more expensive and has electronics inside the charger) will go into floating charge when the batteries are fully charge which will prevent the batteries from being overcharged. If in doubt, remove it from the charger after overnight charging.
Nov 23, 2011 | Drills
Hey what to do my phone battery not charging
I hope the battery is not old. If so then replace it. I also hope that you have not been keeping the battery most of the time as overcharging reduces the life of the battery and thus dead. Open the back cover and clean the battery terminals on the Battery and the cell phone as moisture or dirt can cause this. If all this does not help then you have to show it to one of the technicians.
Oct 29, 2010 | Nokia E63 Cell Phone
Hearing aids keep shutting down. Batteries get wet.
First you should probably keep your hearing aid and battery away from water.I suggest taking it out while in the shower/bath and cover your head with a hood or umbrella while out on a rainy day.If battery keeps shutting down then replace the old battery with a new one.If problem keeps accorring then maybe its time to take your hearing aid into your local hearing aid repair and let them solve the whole issue with why it keeps shutting down
Jan 19, 2010 | Sonic Health & Beauty
How often should the camera be charged
This is not a straight forward question, it would depend on how often you wisg to use it. It also depends on the type of batteries you have installed. Nic Cad, Polymer, NMH. Polymer don't need charging often because they have good holding power for months. The cadmium and NMH types need a regular charge, for instance at least a top up onjce a month to keep them live. If you dont use the camera much remove the batteries whjen in storage place them in a kliplock bag and place in freezer. This may be extremem but keeps the batteries alive for years.
Always before use fully charge the ewith an intelligent charger, one that stops when capacity is reached. This prevents damage from Overcharging.
hope this is helpful,
Please rate the help[++++Thanks for using FIXYA
Oct 12, 2009 | Kodak EasyShare M1073 IS Digital Camera
JVC GR-D270US Mini DV Digital Camcorder Logo
85 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
