Question about Samsung V25 XVC 2800 Notebook
V25 laptop will not turn on from battery power
Hi  i am a complete novice and have a problem with switching on my laptop from my battery, i have installed a new battery and syncronised it with the laptop but i still cannot start it from the battery, but once started from the mains it will run on battery power for 2 hours can anyone help with this problem, any help gratefully accepted thx. les.
    Problem Solver:
  • 12 Answers
The problem associated with Laptop not being able to power from the Battery, even if the Battery is new, can be attribute to the mainboard charging Electronic. The charging electronic in Mainboard is perharps defect. If your laptop still have warranty, this is the best time to change the mainboard.If not, seek for a qualified technician to check the PC, run the system, make Bios Update, and have the mainboard checked.
Posted on Jul 23, 2009
Hi, my Samsung laptop v25 does not hold battery charge. I have replaced the battery with new one but it still does not hold it. thanks for help.
Is it charging? Does it Fully Charge? When you say "not holding a charge", how long are we talking about? Minutes, Hours? Battery life depends on what your doing and what is running and other factors, Some aftermarket batteries aren't very good. Inexpensive batteries are cheap for a reason.
Jan 11, 2013 | Samsung V25 2600XPP (NV25NP0SJM/SUK) PC...
My samsung Laptop screen too dark when used with battery
It will because when you unplug the Power cable, it will automatically switch battery mode. When in battery mode it also activates a kind of Power saving mode by default. Thats why it seems dark. Now if still want to brightness then remove adjust the brightness level while the laptop is on Battery Mode but i must tell you, your battery backup won't last too long.
May 04, 2010 | Samsung V25 XVC 2800 Notebook
How can i turn on the wireless on samsung v25
well your laptop should stay on when you take it off of your charger if its charged. Usually when someone has the problem it means the battery on their laptop is no good. This usually happens when you let your laptop die and lose all its power from the battery this can really damage your battery. Thats the only thing I can think that happened. Your probably going to need to get a new battery. I hope I helped you.
Dec 15, 2009 | Dell Latitude E5500 Laptop
Need to know how to wire the power socket at back of v25
Have you determined the problem correctly?
The fault maybe the power adapter or the power plug that connects into the laptop's power socket rather than the power socket on the laptop.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. The power socket is soldered directly onto the motherboard, there is no wiring required.
If you cannot DIY then I suggest you get a quote first.
Dec 02, 2009 | Samsung V25 XVC 2800 Notebook
Getting started with a samsung v25 laptop
Hello Mark
Hold down the Fn key and press the F key which should have a wireless icon on it.
Seen as its Christmas and i also live in good old Yorkshire, if you still need a hand when it comes to the day email me at leecom72@hotmail.com
Merry Christmas
Dec 23, 2008 | Samsung V25 XVC 2800 Notebook
Blank screen
Might be the VGA connector to the motherboard.
Turn upside-down. Remove screw in the centre marked KBD.
There are 4 screws running along the back. Remove the 2 inner ones.
Lever up the keypad with a small screwdriver - Careful not to disconnect the ribbon underneath.
Undo the 3 screws along the strip above the keyboard and remove the strip.
VGA connector is next to the power button. Check it is pushed down firmly.
NKYG
Dec 03, 2008 | Samsung V25 XVC 2800 Notebook
Which hard drive fits in my v25 samsung notebook?
You can use an IDE laptop Hard Drive unit from 40 GB. to 100GB. That laptop came with a 40GB.
Hard Drive
Hard Drive Capacity 40 GB Storage Controller Type
Specs are at this link:
IDE
http://www.shopping.com/xPF-Samsung-V25-XVC-2800-NV25NQ0VLR-SUK
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 01, 2008 | Samsung V25 XVC 2800 Notebook
Samsung v25
Try to diagnose the problem first...
1. Turn it On your Laptop
2. If you have CRT Monitor? connect it to your Laptop if they have screen appears.
3. If they have display your LCD have a problem.
Aug 09, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 laptop
Make diagnose this problem...
Try to replace the Hard Disk?
Try to replace the Memory?
Jun 13, 2008 | Samsung V25 XVC 2800 Notebook
Samsung V25 Laptop When it is powered up nothing is showing on the screen although the power light is on and you can hear a noise. This has happened before and it just came on.
One way to make sure the system is still working, remove the Batery, then plug the power adapter only and turn the computer back on, normally if the laptop goes into Hybernation mode and the battery is low on power this can happen. If that fixes the system then you can do a safe shutdown and re-install the battery and turn your laptop on and it should come on, the fact that you mentioned this has happened before makes me believe it is Hybernation issue. Good Luck.
Jan 07, 2008 | Samsung V25 CXTD 2000 Notebook
Samsung V25 XVC 2800 Notebook Logo
127 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
