Question about Fastora NAS-104 (nas-104d) 0.25 GB Hard Drive Array
Reset root password
Forgot the root (administrator) password to the unit. Anyway to reset to password? Thanks
See http://www.intel.com/support/motherboards/server/ss4000-e/sb/CS-022318.htm for an answer
Posted on Nov 06, 2007
Forgot administer password
Which password? Bios? Windows? Linux? Mac?
May 11, 2015 | Acer Aspire m5640 PC Desktop
How do i override admin password
Restart the PC, hold down F8 once you enter the Windows® Boot Menu choose
Safe Mode with Command Prompt, and now type in the following:
net user root /add
net localgroup Administrators root /add
net localgroup Users root /delete
The first command adds a new user called "root", the second command adds
that user to the Administrators group and the third command removes the
user from the Users group which leaves him in the Administrators group.
Once you've done, have a look at mine Password Reset Disk Step-by-Step Guide.
Direct link: http://www.itknowledge24.com/
Nov 09, 2014 | Medion Computers & Internet
Forgot user password
Hi I'm Peter , You can change your user password by going in with your administrator password. Here are a few helps https://iforgot.apple.com/password/verify/appleid and see
http://support.apple.com/kb/HT1274 and
and Kappys answer
https://discussions.apple.com/thread/4251616?start=0&tstart=0
In OS X Lion or later, you can reset your user password with your Apple ID.
In Mac OS X v10.6.8 or earlier, follow these steps to reset a password when there is only one administrator account on the computer, or if the original administrator account needs a password reset. "Original" administrator account refers to the one that was created immediately after installing Mac OS X. If the original administrator password is known, that administrator account may be used to reset the passwords of other administrator accounts using the steps described above. These steps require an optical drive; if your Mac does not have an optical drive and you have a Mac OS X v10.6 Install disc, see below.
  1. Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
  2. Choose a language, click the arrow button to continue,
  3. Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
    Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
    Mac OS X v10.3: Choose Reset Password from the Installer menu.
    Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
    Note
    : The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
  4. Select your Mac OS X hard disk volume.
  5. Select the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually the root user. You should not confuse it with a normal administrator account.
    http://km.support.apple.com/library/APPLE/APPLECARE_ALLGEOS/HT1274/HT1274_Leopard.png
  6. Hope this helps.
Apr 20, 2014 | Apple eMac G4 Desktop
Ubuntu adm password reset
Click "Applications" and then click "Accessories" on the top taskbar in the Ubuntu desktop.
Click "Terminal" to open a terminal window.
Type the following command at the Linux prompt and press the "Enter" key:
sudo passwd
To change the Administrator account password, the password of "root" is changed.
The "sudo" command gives the current user temporary Administrator access, in this instance, to change the password of "root."
First, the user will see a Unix prompt asking for the current user's password.
Type the user password for the current user account. Press the "Enter" key. Next, Unix will prompt the user for the new password for "root."
Type the new password for "root." Press "Enter." Finally, a Unix prompt will require a confirmation of the password.
Retype the new password for root, and press "Enter." The Administrator (root) account password for Ubuntu is now reset
or
Boot computer into recovery mode. Reset your computer and as it is booting, hold down the "Shift" key on your keyboard.
You will be presented with the boot menu.
Select "Recovery Mode" from the boot menu.
It is usually the the second boot option.
Wait for computer to boot up.
You will be presented with the Recovery Menu. Select "Drop to Root Shell Prompt."
Type "ls /home" and press "Enter." Note:
The command starts with a lower case L, not a capital i.
You will be presented with a list of usernames of accounts installed on the computer.
Type "passwd username" where username is replaced by the name of the account you want to reset. For example, if the username of your account was "jeff" you would type "passwd jeff" and press "Enter." You will be prompted to create a new password.
Enter a new password of your choosing.
Note: You will see no visual response when you type in your newly selected password; however, the computer still will register the input. Press "Enter."
You will be asked to retype your password.
Re-enter the same password and press "Enter."
Your password is now reset.
Type "Exit" to return to the boot menu and select "Resume Normal Boot" to restart Ubuntu.
hope this helps
Oct 02, 2012 | ValuSoft Ubuntu Linux for PC, Mac, Linux
I need help i have forgot the power on password for my hp compaq 6720 and need to know how to by pass it thanks
Here I collect some popular solutions to help reset HP laptop password if your laptop installed Windows system such as Windows 7/Vista/XP.
Solution 1 Reset HP laptop password by another user account with administrator privilege.
Solution 2 Reset HP laptop password with Offline Windows Password & Registry Editor.
Solution 3 Reset HP password with professional password recovery tool.
If you do not have another administrator account on HP laptop or you have little experience in Windows or LUNIX operations, you can use Windows Password Rescuer to help reset HP password without lose date. This software was provided by DAOSSOFT corperation, it supports HP laptop password recovery in Windows 7/Vista/XP and HP computer installed Windows 7/Vista/XP/2008/2003/2000.
Sep 13, 2011 | HP Compaq 6720s Notebook
I forgot my Mcafee password. I want to UNBLOCK a website but i cant do that without my administrator password.
Contact McAfee support - they can email you a password reset
http://home.mcafee.com/Root/Support.aspx
Sep 08, 2010 | Network Associates McAfee Parental...
I Have HP Compac c301 laptop I forgot my Password how to log in to my laptop
You can always log in as the root administrator by pressing ctrl+alt+del on after you've reached the logon screen. Key in the user name as "administrator" and the password. Hope the password is blank.
Once you are logged in as administrator, you can reset your account's password using the User Accounts in Control Panel.
Jul 14, 2010 | Computers & Internet
Forgot my password in my g3
Root user is special user in Mac OS X, has high privileges and rights to make any type of change to the system, and is different than administrator. If you forgot root password, see how to reset Root user password using different methods in Mac OS X.
How to Reset Root User Password on Mac OS X
May 11, 2010 | Apple PowerBook G3 Mac Notebook
Forgot password
download BB desktop manager and Completely reinstall the software on your device and it will remove the password lock.
May 24, 2009 | RIM BlackBerry 8703e Smartphone
Forgot password to log on to notebook
  1. i found this floating around, hope it helps, let me know please
Start up from a Mac OS X Install CD (one whose version is closest the the version of Mac OS X installed). You should first disable Open Firmware password protection, if it is enabled. Hold the C key as the computer starts.
  1. Choose Reset Password from the Installer menu (or Utilities menu in Mac OS X 10.4 Tiger). Tip: If you don't see this menu or menu choice, you're probably not started from the CD yet.
  2. Select your Mac OS X hard disk volume.
  3. Set the user name of your original administrator account.
    Important: Do not select "System Administrator (root)". This is actually a reference to the root user. Do not confuse it with a normal administrator account.
Jan 29, 2008 | Apple MacBook PC Notebook
Fastora NAS-104 (nas-104d) 0.25 GB Hard Drive Array Logo
3,625 people viewed this question
Top Fastora Computers & Internet Experts
David Payne
David Payne
Are you a Fastora Computer and Internet Expert? Answer questions, earn points and help others
