Question about La Cornue Chateau 120 Dual Fuel (Electric and Gas) Kitchen Range
Oven on European La Cornue chateau 120
I ordered in 1995 a La Cornue Chateau 120 from France. I live in the British virgin Islands and they built it for propane. For several years I have had a continual problem with the pilot light going out after the oven has been on. I have a large oven, not the small vaulted type and the right side has an electric warming oven. I can turn the oven on and it will stay on for several hours sometimes, but then it shuts down and I when I try to relight it, the pilot is reluctant to light and if it does the oven won't stay lit for very long and I actually can hear it click off/ Several years ago, I replaced the thermocoupler and the thermostat, but the problem continues. La Cornue is the worst company for service and repair, and I have been waiting on the phone for someone to actually answer when you call them, but I get fed up and hang up. The repairment that come and look at it have no idea what is causing the problem. Now they suggest that I replace the pilot light, because they seem to think that it is not a thermostat problem or a thermocoupler problem. Sometimes, when I open the oven door it blows out too. I thought about just replacing the whole of the inside of the oven with another brand ie US, just because I am so fed up with this. HELP
It could be your air to gas mixture is too lean, and the flame is blowing out. the oven will then turn off, but it is producing a lot of carbon monoxide have to see flame to really tell.
Posted on Jan 31, 2010
Where is the safety trip on the electric oven?
Typically on the back of the oven there is an access panel at the top behind the control's should be a circuit board with a fuse ?
Feb 21, 2015 | La Cornue Chateau 120 Dual Fuel (Electric...
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
Can't locate plus character to put in front of an overseas contact number on my panasonic KX-TG2511ALdigital cordless phone
The "+" is merely a placeholder for the international call prefix (IDD) used in your country.
  • For example, if you live in France (IDD: 00) and need to call a phone located in Germany (Country code: 49), you would call 00 49 ...
  • If you live in USA (IDD: 011) and need to call a phone in Germany (Country code: 49), you would call: 011 49 ...
Find your country of residence in the list below and use its IDD as a replacement for the "+":
  • 00 - all countries not listed below, ITU recommended code.
  • 0 - Samoa
  • 00 ~ - Hungary
  • 000 - Tanzania, Uganda
  • 000, 005, 006, 007 - Kenya
  • 005, 007, 009 - Colombia
  • 001, 007 - Cambodia
  • 001, 007, 008, 009 - Indonesia
  • 001, 008 - Singapore
  • 001, 0060, 007, 008, 009, 1666 - Hong Kong
  • 002, 005, 005, 007, 009 - Taiwan
  • 001 - Guyana, Mongolia, South Korea, Thailand
  • 0011 - Australia
  • 009 - Nigeria
  • 010 - Japan
  • 012, 013, 014, 018 - Israel
  • 011 - American Samoa, Anguilla, Antigua and Barbuda, Bahamas, Barbados, British Virgin Islands, Canada, Cayman Islands, Dominica, Dominican Republic, Grenada, Guam, Haiti, Jamaica, Marshall Islands, Micronesia, Montserrat, Northern Mariana Islands, Palau, Puerto Rico, Saint Kitts and Nevis, Saint Lucia, Saint Vincent and Grenadines, Trinidad and Tobago, Turks and Caicos Islands, USA, Virgin Islands
  • 1xx0 - Chile, xx depends on international carrier code
  • 119 - Cuba
  • 810 - Belarus, Kasakhstan, Tajikistan, Turkmenistan, Uzbekistan
  • 807, 810, 811, 816, 818, 854, 860, 869 - Georgia
  • 810, 826, 827, 828, 856, 857, 858, 859 - Russia
  • 00, 99 - Finland
Jan 17, 2011 | Panasonic KX-T7730 Corded Phone
My la cornue oven not heating, turn 1st knob to function desired and then temperature knob to desired temp but oven does not heat up
First thing should be to make sure the top selector switch is not set to the optional Pizza element.
Make sure the power to the unit is OFF. Also keep in mind that the following tests should be done by a qualified appliance specialist. To find one near you, contact the La Cornue Service Center @ 877-522-6768
Is this the first time using the oven? If so, make sure the overall power to the range is 240 volts. This can be checked at the main terminal block.
If your model has three indicator lights and the red light is illuminated, then it is likely the hi-limit thermostat has tripped and you will need to reset it. The reset switch is located underneath the cycling thermostat. To access this, you will need to remove the front fascia. Please note: The original safety thermostat is no longer available. Use current safety thermostat (reference: 06ELTS01). If your model has only two indicator lights and the red light is illuminated, that means the oven is heating up. If the red light is not illuminated when the thermostat is set at the desired temperature, then check the hi-limit thermostat.
Power relay/contactor on the back of the unit should be checked. It
Jan 06, 2011 | La Cornue Grand Maman Dual Fuel (Electric...
No operating instructions
the top one turns the broiler elements on 1 is for the center element 2 is for the 2 side elements and 3 is for all 3 elements. The next dial down turns the electric on or off . the third dial is the same as the top except for the bottom elements
Apr 11, 2009 | La Cornue Chateau 120 Dual Fuel (Electric...
Shipping to france
Hey yala34,
Unfortunately, orders placed through the Best Buy™ website and stores cannot be shipped internationally at this time. Orders placed within the United States can only be shipped to U.S. addresses, APO/FPO addresses, P.O. Boxes, the U.S. Virgin Islands and Guam, while orders placed within Canada can only be shipped to Canadian addresses.
Please keep in mind that additional restrictions may apply, and you may always refer to the shipping and delivery FAQ's located at www.Bestbuy.com for more information.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 10, 2008 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
La Cornue Chateau 120 Dual Fuel (Electric and Gas) Kitchen Range Logo
493 people viewed this question
Top La Cornue Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a La Cornue Kitchen Range Expert? Answer questions, earn points and help others
