Question about Pioneer PD-F507 25-Disc CD Changer
Lost my manual
Not sure what happened, but it's is flashing locked. How do I unlock
0 characters
1 Points
Wont start
Just a thought. It might be the anti-theft portion of the remote lock system. I cannot explain what might reset it to make it work later... unless perhaps unlocking a second time does it.
Mar 27, 2014 | Jeep 2008 Grand Cherokee Laredo
2000 Jeep Grand Cherokee Laredo Power Locks going out
thats kinda 2 things.. lol... but the back pass door.. your actuator in the latch could be bad or someone that used a slimjim to unlock the car on that door bent the rod.. does it move at all when you hit the power lock button ? if it moves some that it could very well be a bent rod.. or the actuator is stuck and needs to be replaced..
Oct 07, 2012 | Jeep 2000 - GRAND CHEROKEE
All doors except drivers side lock and unlock? with and without remote. There is a sound in the drivers door like it is trying to lock and unlock (so there must be power to it). Any ideas?
Remove door panel amd see if something came loose also clean and lightly oil lock make sure nothings stuck inside also check fuses start with dcm fuse
Oct 02, 2012 | Jeep 2008 Wrangler Unlimited Sahara
My 2002 blazer's factory radio says LOC on the
You need to get the radio Lock code from the owners manual or dealer and input the code. That is an Anti-Theft function in teh radio that makes it useless if stolen since you ahve to have vehicle and radio information to get teh proper code to unlock it. When you get the code make sure you write it down someplace because if you ever have to replace the battery you will need the code again.
Jun 18, 2011 | Alpine Car CD Changers
We replaced my car battery, now all it does is flash!
You need to enter the car stereo anti-theft code. The procedure is illustrated in the car or in the stereo user manual (depending if stereo is factory one).
The stereo code is also printed in car documentation.
Details on how to enter the code depend on car stereo make and model (or on car make and model).
The stereo code is unique, if you have lost the code you may need to pay a small fee to recover the code.
If you have lost the code, the unlock job can also be done for a small fee at the nearest car dealer.
Aug 08, 2010 | Panasonic CQ-DP830U CD Changer
My radio has a RDS and it is locked, how do I get
you would have to get the radio removed and get the serial# and provide the dealership with this # and they should be able to provide you with a code, but first I would check the owners manual for the code if you have it
Jun 07, 2010 | Car CD Changers
I have a stereo of Cavalier 2002 but it shows ''LOC'' in the display. Can somebody help me to clear this lock. What could be bad on it?
your stereo is locked. your battery drained and clock memory was lost to radio. a simple fix can be found on this forum but they charge 4.99 or so to help. they dealer will cost 50 + so 5 bucks is worthit.
i am sorry you had to go threw this. positive side you will have the code so it will not be a problem in the future for you.
they radios of modern cars employ so called anti theft mechanisms, but in reality they are designed to cost us money to get things working normal again. this is by the way the only device on your car that is lockable by the power failure
good luck with it. and a little tip: they sell a 9 volt battery maintainer used by professional stereo installers to keep clock memory voltage on the radio so this doesn't happen when you need to disconnect your battery again. i would highly suggest getting one. they are fairly cheap and will prvent you from having any major issues in the future when you need to replace or disconnect your cars battery again.
Feb 18, 2010 | Car CD Changers
Central locking not working on peugeot 206, so got 3 new motors for each door and boot, worked for 5 mins only on driveres side and boot, but not on passenger door.Used car next day and central locking not...
It seem that you have a relay on the control unit with burnt contacts or a bad connection from the control unit to the solenoids. I will opt for the relay on the control unit. Try replacing the control unit
Nov 19, 2009 | Car CD Changers
Cd player flashing lights
Yes- it is in anti-theft mode. Whenever you lose power from the battery, the factory system needs to be unlocked. This would prevent theives from wanting your radio as they would not be able to use it in another vehicle without a unlocking code.
If you have the original owners manual from the car there are specific instructions as to the lock code for your unit. Hopefully, the dealer recorded them for you.
If not- you have to go to a Chrysler dealer and they can do it by the VIN code.
May 27, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
please help to get code
philips 22rc200/65
prod no:FD0900479245981
96 392 193 8001
Apr 02, 2008 | Car CD Changers
Pioneer PD-F507 25-Disc CD Changer Logo
35 people viewed this question
Top Pioneer Car CD Changers Experts
Jesse Walters
Jesse Walters
Eddie Dalton
Eddie Dalton
Level 1 Expert
Are you a Pioneer Car CD Changer Expert? Answer questions, earn points and help others
