Question about Toshiba Computers & Internet
Toshiba Satellite Pro 6000 ps600e
I am trying to upgrade the 128Mb ram to 1Gb but when I put the new ram in I get one long and one short beep and the laptop does not boot up. This happens no matter what configuration I put the ram in.
  • 39 Answers
You might want to go to the computer manufacturers web site and see if they have a list of error codes for you computer. If not, you might also try to do a Google search for error codes pertaining to your particular computer.
If you can't find a list of error codes, keep in mind that some computers can be very finicky about the type of RAM that is installed. If you haven't already, check to make sure that the RAM you are trying to install is 100% compatible with the computer that you have. If so, you might try installing the RAM one stick at a time and rebooting with each chip individually. This will help to determine whether one of the chips might be bad or not. If the RAM is 100% compatible - AND - it will not boot with a single stick installed, there is a distinct possibility that all of the RAM sticks could be bad.
Posted on Nov 09, 2008
About toshiba m40 motherboard
Toshiba Satellite M40 Specifications (as reviewed):
Intel Pentium-M 760 (2.0Ghz, 533Mhz FSB)
1GB RAM (2x 512MB DDR400)
60GB (ATA 100 5400Rpm, 8mb Cache)
15.4" Widescreen TruBrite' Glossy display (1280x800 native)
NVIDIA GeForce Go 6600 128mb PCI-Express
Intel Pro 2195 a/b/g Wireless
Matshita DVD-RAM UJ-8315 (DVD-RAM, +R / + - RW)
Microsoft Windows XP Professional (SP2)
Toshiba 6.1 Hour Li-Ion Battery (6 cell; 4300mAh)
also see this... http://www.notebookreview.com/default.asp?newsID=2677
Nov 18, 2010 | Toshiba Computers & Internet
Toshiba sp6000 512mb sdr 133mhz chips
These are the memory modules for your notebook, any others won't work. The max is 1024mb
You need these modules:
PC133 512MB (PA3108U-1M51)
PC133 256MB (PA3086U-1M25)
PC133 128MB (PA3085U-1M12)
If the modules you've installed meet the above criteria then make sure they are seated correctly.
Bear in mind it is always possible one of the modules is defective so try them one at a time, also they are non-eec.
Jul 08, 2010 | Toshiba Satellite Pro 6000 Notebook
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
My satallite pro 6000 wont boot up
This error code most likely refers to the RAM.
The RAM module/s may only need reseating to make proper electrical connection.
If this doesn't work the the RAM module/s is possibly faulty. Take it to your friendly computer shop the get it tested or insert it into another laptop to test the RAM.
May 07, 2009 | Toshiba Satellite Pro 6000 Notebook
Change 1gb ram to 2gb ram in laptop
Go to any computer accoseies shope and buy a kingston 2 GB DDR2 ram for your laptop
Apr 03, 2009 | Toshiba Satellite Pro L300 Notebook
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
RAM uprgade doesn't work on Toshiba SP6000
Hi
Furthermore you can upgrade the memory to max 1024 MB
hope this helps
Leecom72
Nov 13, 2008 | Toshiba Satellite Pro 6000 Notebook
New RAM for Satellite 1400 won't work
Hi this problem has arisen on both desktops as well as laptops, the reason for it is quite simple. a lot of the RAM available on the market now is HIGH DENSITY RAM and unless your satellite is specificaly designed to run high density RAM it will not recognize it.
You will find all the major RAM brands are low density and will work fine. A brand like Kingston is an ideal option.
Regards mistyman
Aug 14, 2008 | Toshiba Satellite 1400-S151 Notebook
Having trouble with memory upgrade for Toshiba laptop
I don't see anything about DDR2 I do see DDR SODIMM.
Kingston ( a company owned by Toshiba) has the specs you need for your pc. Here is the link:
http://shop.kingston.com/modelsinfo.asp?SysID=23890&mfr=Toshiba&model=Satellite+M55&SUBMIT1=Find
Jun 21, 2008 | Toshiba Satellite M55-S135 Notebook
Computers & Internet Logo
375 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
