Question about U-Line Icemaker
U-Line sp-18 RV Ice Maker
I defrosted the ice maker, noticed some water in the floor and wiped everything up. Now, after letting everything dry, it trips the breaker when i flip the switch on.
    Problem Solver:
  • 11 Answers
Allow the unit to dry out for a few more days and see what happens, but it sounds like there's a shorted wire someplace in the unit. I would not put this unit into service until this is found.
www.u-lineservice.com is the mfg website for service, you can find a servicer zip code search at this site
Posted on Dec 23, 2008
Ice maker leaks on floor when I turn on after awhile
Hello:
is the water coming from the ice maker for sure?
It could be that you may have clogged defrost drain line and the water has no where else to go but the bottom of freezer..Defrost happens roughly every 8 hr or so...
Jul 11, 2017 | GE Refrigerators
Seems the freezer door was not completely closed. Ice started ot melt and then form icicles! Well we closed the freezer the next morning. Now the ice maker and water dispensor are not working. In...
when you closed the door, the freezer froze all the condensation/melting ice,hence the icemaker freezing.
the best solution is a TOTAL defrost/clean out,then dry out.DO NOT USE HOT WATER/SCRAPERS,let it defrost naturally or use car de-icer.wipe out with bicarb to keep fresh.and then restart as new.
Sep 11, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
I have a whirlpool and my Ice maker started chunking out ice and water came out the door and warped my wood floor. Pulled out ice maker part 106 626636 and deiced everything. Noticed that the coating on...
i think you damaged the icemaker l to v is line voltage to valve . . only connection to be used with jumper is t to h this will run the motor till its started the harvest then pull wire and let it run on its on this will start the mold heater and run the drive motor and when it has almost completed the cycle it will call for water from the valve . / you need a new ice maker anyway . so just replace it and you''ll have ice i a couple of hours .. mm
Jul 30, 2010 | Refrigerators
I have a 1990 Carver Santego boat and it has it's original u-line ice maker on board. This year I noticed that the ice maker was still staying very cold but stopped making ice. My husband checked to make...
as the fridge gets older the gas gets less efficient so regasing the unit may work, but, due to its age, you may find replacement more cost effective...and more efficient.
Jun 17, 2010 | U-Line Icemaker
I have water leaking in the freeer apparently down the back wall and pools on floor to form ice. Water has also accumulates under freezer on hard wood floor but not all the time. Model MSD27326R There is...
Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
Mar 27, 2010 | Refrigerators
Ice maker not working
Usually when this happens the water line in the freezer is frozen. If this is the case, defrosting the freezer should free it up and all will work again.
Aug 02, 2009 | Refrigerators
Ice maker leaks with or with out power on the far right side
The water valve (or solenoid) that only lets the water through from the water supply line when the ice maker calls for it is leaking you have to replace it.
May 02, 2009 | Thetford Norcold RV Cooler/Freezer
Leaking ice maker.
Sounds like you have a bad inlet valve that is staying open and is not closing letting water run through the system all the time. The valve is located next to the Ice machine water line
Feb 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water will not flow into ice maker
This has happened to me a couple of times. First check to see if water is dripping from the water line on the back of the freezer. If it is that means ice has formed at the intake on the back of the ice maker and isn't allowing water to get in. Pull everything out and defrost the freezer for 3 - 4 hours. Make sure you dry everything out before putting the food back in.
Jan 13, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker not making ice after replacing water line.
Ice makers are a common problem. On many brands there is a reset button behind the plastic cover. However if you physically see Ice clogging your water inlet to the ice maker, this will without a doubt prevent the ice maker from making ice. Use hot water or a steamer to unclog the ice or you can leave the unit unplugged for a few hours to defrost the freezer. You should be able to hear when the ice maker cycles and lets in water. Note: if you're getting plenty of water out of your in door water dispenser, then it's NOT a water supply problem. You may need to check the solenoid that controls water entering the ice maker.
Nov 29, 2008 | Refrigerators
U-Line Icemaker Logo
258 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
