Question about D-Link AirPlus DI-524 Wireless Router
No wireless connectivity
No Wireless Conectivity. i have this Dlink wireless router DL524, i have been using it for last 2 years but suddenly i am not able to use it as there is no wireless connectivity with it now.its not detectable on Available wireless networks. i can only use net through wire. All the lights are working except Status one which is always blinking. I have tried resetting it several times but no results.
please help me with the issue.
  • cfantoni Nov 16, 2008
    We've installed the firmware, reconfigured the router, and the problem persists! We can see the wireless network, but cannot access it on any of our 3 home computers. We are only able to connect via cable. PLEASE HELP!!!
    Scholar:
  • 132 Answers
Try doing a firmware upgrade to your router.
Posted on Nov 08, 2008
Wireless network limited access
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Mar 23, 2012 | D-Link Computers & Internet
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
Unable to access internet through DLink DI-524 wireless modem
I would suggest downloading the manual and check the settings for your country.. it can be found here.
http://support.dlink.com/emulators/di524_revc/h_lan.html
Oct 25, 2017 | D-Link DI 514 Wireless Router (DI-514)
Can not connect to the internet using my DLink 514 wireles router
May be the wifi modem drivier is not installed properly. check it using device management
Apr 19, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
The conectivity is not consistent. I frequently
I would advise investing in a new one, it does sound like its componants are begining to fail.
Jan 20, 2010 | Linksys Wireless-G WRT54G Router
Why is my modem not recognised by vista ???
HI
Please confirm that your Dlink Di 524 firmware is upgraded. With Vista the firmware update resolves the issue.
http://support.dlink.com/emulators/di524/tools_firmw.html
use this to update teh firmware. its shows instructions on how to to do that.
let me know if you need more help.
thank you
rakesh
Dell Laptop Expert
Jan 06, 2009 | D-Link AirPlus DI-524 Wireless Router
I have a dlink dl524 and trying to set security on it
Hi, I will lend a hand if I can.
Important Note! Use a wired connection to your router when setting up security.
There are four basic steps to setting up wireless security, which are the same for most routers:
1) Login to your router
2) Change the router login password/username
3) Change the network name, or SSID
4) Enable WPA encryption
Here are the details, taken from the Dlink site:
1) Login to your router.
Type the router address in the address bar of a web browser. For this router, the default is
192.168.0.1
You should see a popup box. If you have not changed the password, enter username: admin and leave the password blank.
This should bring up the configuration screen/user interface.
2) Change the router password.
If you haven’t set a password, this is a good place to start. Go to Admin > Tools. Set new admin and username passwords and click 'Apply'.
3) Change the SSID (router name):
Go to Home > Wireless, and change the SSID from ‘default’ to anything you like –as long as you can remember it. It is case sensitive, and you can usually use up to 32 letters – but don’t use something that could identify you, or your location. Click ‘Apply’ when finished.
4) Enable encryption
Still in Home > Wireless, select WPA-PSK.
Under ‘Passphrase’ you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HapPY2009toyou8899). It is case sensitive.
The passphrase is also called the network key, and sometimes WPA shared key, PSK, pre-shared key, WPA-PSK, authentication key.
Note down the passphrase/network key carefully. You will need this to connect wirelessly. Click ‘Apply’ when finished.
That's it, you have done enough to secure your network, and can close the screen. (There are other options you can configure at a later stage if you wish.)
When you next connect wirelessly, you'll see the router with its new name in your 'available wireless networks'. When you attempt to connect, you are asked for the network key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps, but if it is not clear or doesn't work, please come back to Fixya. Good luck...
Jan 05, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
Wireles conection problem
I've run into this issue with USB wireless network cards from DLink, Linksys, and Netgear. For me, the issue was with the USB ports on the PC and not having enough power for the device, the connection would stay live for a random amount of time and then all of a sudden it would die (same thing would happen when resuming from hibernation or standby). I added a PCI card with a powered USB hub in it and it solved my problem.
Hope this info helps!
Jan 15, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-Link AirPlus DI-524 Wireless Router Logo
117 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
