Question about HP Officejet 5610 All-In-One InkJet Printer
No Printing I inadvertently deleted the driver for the printer. I reloaded it, and it still does not print off computer, copies fine.
    President:
  • 1,901 Answers
You need to uninstall the software and delete the printer through the Start>Printers and Faxes window. (Right click on the printer and select Delete.)
Disconnect the usb cable from the printer and reboot your computer.
Begin from the beginning and only connect the usb cable when prompted by the software.
Posted on Nov 09, 2008
New Ink cartridge is printing a large blurred copy
1 Either have a defective cartridge, return to store for new cartridge.
2 defective hardware, printer is broken or wires in the printer ribbon are shorting together.
3 Delete printer off the computer, reboot and reload software for the printer it may be corrupted.
Mar 25, 2015 | Office Equipment & Supplies
Printing problems
sounds like a driver issue, try deleting and reloading driver, if same try a different version of driver.
Mar 26, 2014 | Office Equipment & Supplies
How do i speed up a 2844 printer. It was printing fine until we had to change computers. After the computer change it prints slower. We have reloaded the driver etc to no avail.
The print speed is controlled from the printer driver usually. Even though you have reloaded it, the default speed is probably lower now that what was set on the other computer. You didn't mention if you made any changes to the driver after reloading so check the speed setting.
If by slower, you mean there is more time between when you hit print and when the label actually prints, then that is more related to communications.
Hope that helps !
Apr 21, 2010 | Zebra LP 2844 Thermal Label Printer
My 1800 is printing extremely slowly , until I
Your printer may have recieved a spike from the same lightning and fried the circuit board.
Is it under warranty?
If so call Epson and get an exchange unit.
The MAY help you if you mention the surge
Jun 19, 2009 | Epson Stylus Photo R1800 InkJet Printer
Printer not printing
Have you tried reloading the drivers for the printer - try it on a differant pc to if possible.
Feb 15, 2009 | Canon PIXMA MP530 All-In-One InkJet...
My printer won't print documents from the computer
I would reinstall the printer. Reload the drivers and see if the pc now recognises the printer.
Heres the latest driver version:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&lang=&product=3301296&#
Just select the operating system then the driver or driver/software combination.
Hopes this solves your problem.
Nov 18, 2008 | HP Officejet J5780 All-In-One InkJet...
Only prints on restart
I don't completely understand your description.
On any printer problem, I always delete and reload the driver first.
I've spent hours only to find out there was a glitch in the original install.
A fast, simple thing to do, might be to share the driver off another computer and print through it.
Are you using the remote login when you are trying to print?
If so, the print driver has to be loaded on the server as well as on your computer. And you have to be enabled in the printers group with premission to print.
Apr 08, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
AL1641 CS won't make two sided copies anymore
Sounds like a driver or configuration problem, 1st) Make sure when you are printing, to go to Properties, you must choose 2-sided printing each time on that model, some programs won't allow you to change your printers settings.
2nd) go to control panel/ printers/ Al-1641, right click, properties, In the first tab General it should say at the bottom (Double sided - Yes) If not you need to delete the driver, a fairly common problem, and reload the driver, get the driver from Sharps website to be sure you have the most current driver, if a driver is corrupt it won't tell you there is a problem, make sure it allows you to print two sided.
Jan 11, 2008 | Sharp AL-1641CS Color Copier
Dell Printer will no longer communicate
RELOAD DRIVER FROM DISK THAT CAME WITH YOUR PRINTER.
IF YOU DONT HAVE A DISK DO INTERNET SEARCH FOR DELL PINTER DRIVERS DELL 924
YOU NEED TO KNOW WHICH OPERATING system you are using Windows 98,xp ETC.
DOWNLOAD DRIVER INSTALL AND HAPPY PRINTING.
Oct 17, 2007 | Dell 924 All-in-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
Ben Johnson
