I have a Coby DVD player, and I have lost the instructions of how to hook it up to my TV. The connector wires have a yellow, a red, and a white plug on each end. I plugged them into what I think are the correct connections...putting the white plug into the green hole on the DVD and the TV. I put the TV in the VIDEO mode, but it does not come on. I have cable TV.
  • arnoldrachel Nov 08, 2008
    I have a coby DVD, and it now works, thanks.
    Sergeant:
    Champion:
  • 331 Answers
 the connectiong wires correspond to the color of the rims in the cinnection jacks  both  for the TV and the DVD player.
you  must be able to connect to the DVD player making the right connections
usually the Yellow -> Audio out of Dvd and other end the "Audio in" of the TV
                  White-> Video out of DVD and the other end into the correspoding "video in " of the TV
make sure you are connectiong the cables into the Audio and video "in"  of your Tv and not "Out"
hope this help  if it does not please do post back.
Posted on Nov 08, 2008
    Genius:
  • 1,011 Answers
Sir,
Step 1 Find the audio/video cable in the box of your new Coby DVD player. The cable will have red, white and yellow plugs on both ends.
Step2
Find the video output jacks located on the back of your Coby DVD player. The video output jacks will be the same colors as the plugs on the audio/video cable.
Step3
Plug the cable into the video output jacks of your DVD player by matching the color of the cable with the color of the jacks.
Step4
Find the video input jacks on the back of your TV. They too will correspond to the colors of the plugs on the audio/video cable. Plug the cable into the video input jack on the back of your TV by matching the cable with the corresponding colors of the input jacks.
Step5
Turn on your TV and your DVD player and insert a DVD into your DVD player.
Step6
Cycle through the video inputs on your TV until the DVD you’re playing appears on the screen.
thanks
goodluck
  • 94 Answers
The Yellow wire goes to the Video Input of your TV. While the white and red wires are for your audio.
    Brigadier General:
  • 3,614 Answers
The YELLOW = VIDEO
RED / WHITE= AUDIO
  • micromaster
    micromaster Nov 08, 2008
    YELLOW WIRE GOES TO VIDEO OUT / IN
    RED AND WHITE WIRE GOES TO AUDION OUT / IN.
  • micromaster
    Component video connections are found on most DVD players and HDTV
    tuners, and on a growing number of TVs and A/V receivers. However, this
    type of connection can vary in bandwidth from unit to unit. To pass
    progressive-scan DVD signals without noticeable softening of the
    picture, a component video connection should have a bandwidth of 12 MHz
    or higher; passing HDTV signals without softening requires a bandwidth
    of 30MHz or higher. If you are only slightly shy of the required
    bandwidth for the signal you're viewing and your TV is 36" or less, the
    picture softening may be extremely subtle, or even unnoticeable.
I have a coby dvd 224 player connected to Emerson tv, and all I see on screen word video and no picture.
if you're using RCA video cables red white and yellow plug the yellow wire from the DVD player into the green input on the TV and then plug the two audio cables red and white into the same input red and white on the TV it's the green one that carries the video signal this is generally call the component input because it breaks down the colors into their components most DVD players do not have component outputs but if you hook the green and the yellow from the DVD player you should get a picture
Jan 28, 2015 | Coby Televison & Video
Can't hook-up RCA wires in back of tv, dvd recorder,and directtv dvr I don't know which go to input or output red, white, yellow
from your dvd,plug the yellow to video output red and white to audio output. then plug the other end of the yellow to video input on tv and the red and white to audio input on tv. from tv, plug the other rca cable yellow to video output and red/white to audio output and the the other end yellow to dvd recorder video input and the ed and white to audio input
Nov 13, 2010 | Hyundai Televison & Video
How to hook up my dvd player
ya its easy there are 3 wires yellow for video & red - white for audio just plug that wires in the same color socket from tv to player
Jun 12, 2010 | Hitachi DV-P745U DVD Player
Need to connect dvd player have yellow, red and white connectors
Red is right channel, White is Left Channel, and Yellow is video.  If you just got the TV and DVD player its a pretty simple setup.  Just look on the back of the DVD player and hook the yellow cord to video and hook the other end to video on your TV.  Now just plug in the red and white cords to the audio on the back of the DVD player and connect the other ends to audio on the back of the TV.  You can bypass these connections and just get a HDMI cable which has video and sound all in one convenient cord, but they cost more.  You just connect the cord on the back of the DVD player where it says HDMI and then plug the other end to the TV where it says HDMI.
Nov 05, 2009 | Televison & Video
Trying to hook up a Philips 22'' TV to Sony CD/DVD player. Need help. I have a Red, White. and Black connector to go from TV to CD Player. Do I need anytning else? TV model # 22PFL3504D/F7
Usually the Color Red and White is for the audio channels and yellow is for the video but in your case you find black instead of yellow.
So you do the connection as per the instruction given below.
TV DVD Player
Red--------------Red
White------------White
Black-------------Yellow
Jul 25, 2009 | Televison & Video
Orion tv without input/output plugs
from the looks of the picture you have one audio video input port on the front of the tv. The connectors are yellow and red or yellow and white. Yellow is video and red or white are audio. Find those same connectors on the back or your dvd player, hook it up to the tv and there you go. You'll have to go to game mode or input 2 on the tv to see the dvd player.
Jul 01, 2009 | Orion1934 19" TV
No Sound when playing a video game on Coby Pertable DVD player
Do you have the audio plugs in the proper spot? The red & white audio plugs from the PS 2 need to be plugged into the audio in jacks on the portable dvd player in order to get sound. Should match up red to red; white to white for sound, yellow to yellow for video. Hope this helps.
Feb 03, 2009 | Coby TF-DVD1023 Player
Coby DVD player set up
Brenna,
Here are some things to remember when messing with cables TO and FROM electronic audio/visual
devices. YELLOW connectors are for what you SEE on the screen of your TV or other viewing device.
The RED/WHITE connectors are for what your ears will hear, LEFT/RIGHT in stereo or mono.
Now all you need to do is connect the YELLOW output jack of your Coby to the YELLOW video
input jack on TV. You must remember forever and ever that the YELLOW jacks and plugs never
contain or transmit or move TV channels or CABLE channels or DISH channels. The YELLOW cable
which has plugs at both ends goes to jacks (output to input) and carries/transmits BASEBAND VIDEO signals only. Now all you need to do is make the TV stop listening to it's antenna in, and to
start listening to the YELLOW/RED/WHITE jacks on the back of the TV. You will need find out how
to put TV into MONITOR mode, or AUX mode, or VIDEO INPUT 1. Basically just match colors and
OUTPUTS to INPUTS. Hope this helps you out.
louie12fix @ fixya
Dec 17, 2008 | Coby DVD-224 DVD Player
Klh 1220dvdplayer
color coded RCA plugs in the back of the DVD will match the jacks on the rear of the TV, you only need 3 but can use up to 6 if motivated. red and white are sound while yellow is always video for the most basic connection for an anolog TV. Orange is digital audio, small optical out (square plug) is for optical audio and the 3 other colors back there are for colorstream outputs or composite outs. If you have a rectangle plug in the back that is for a HDMI cable. Of course if you have a solver metal threaded connector like a cable jack in the back you can use that too but there are very few DVD players that have this connector.
Feb 13, 2008 | KLH KD1220 DVD Player
How do i connect to my tv?
the yellow line is for the video the red and white is for the audio, and you can connect your DVD to your TV.
Oct 02, 2007 | Coby DVD-207 Portable DVD Player
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
