Question about Miele Microwave Ovens
Miele h5080bm , after cleaning the oven / grill works but microwave will not heat
  • 537 Answers
SOURCE: MICROWAVE OVEN
Bad power diode, bad power capacitor or bad magnetron
Google on 'microwave not heating' and you'll get some sources of information
Posted on Dec 13, 2007
SOURCE: Neff HTHB86K Microwave oven.
The microwave unit is faulty as you can read from the display or the controller isn't working correctly, you should take your MW oven to an authorized service center. It can be repaired by yourself but it's highly dangerous because it has high voltage inside and microwave energy.
Posted on Feb 15, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Sharp Covection Oven/Microwave stops after 1min on any setting
This 59-second stop failure is due to a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller thinks that the door is not in the right position, it will shut down the cook cycle.
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 09, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: panasonic inverter dimension 4 microwave
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Posted on Sep 06, 2008
  • 97 Answers
SOURCE: MICROWAVE OVEN NOT HEATING UP FOOD
Will need to pull apart to check....common failure with magnatron fuse....but could be magnatron, capaciter, diode. sugg to have a tech look at....if your not able to check, also call manufacturer, sometimes will cover.
Posted on Jun 10, 2009
Is my Miele M6262 Microwave oven a convection oven?? Sounds silly but was told it was when we bought it but it doesn't seem to be?!?! Thank you
From what i can tell, it utilizes microwaves and is indeed not a convection oven. Although it does have some extra features such as a 'grill' setting, i think that is just using microwaves at a lower (or higher) power.
Sep 06, 2017 | Miele Microwave Ovens
The display on my miele h5080bm has gone blank ,any ideas .
I f it is still under warranty take it back. If not contact manufacturer.
Feb 16, 2015 | Miele Microwave Ovens
My miele combi oven microwave doesn't heat but oven is fine!
Probably a faulty door switch has blown the microwave fuse. If you are lucky.
Nov 17, 2017 | Microwave Ovens
The food is not heating
The wave generator (Magnetron) or one of its components is defective.
Nov 25, 2013 | Miele M638EC 1500 Watts Convection /...
Miele H147-2mb not heat when microwave other function OK
Check the door safety interlock switch. More than 90% of problems like this are due to failed safety switch. Switch fails because people open the door when the oven is operating.
Mar 17, 2013 | Miele H147-2MB Convection/Microwave Oven
I have a Miele h5080bm microwave oven. How can I clean the grease of the roof and sides of the microwave?
You can put a microwave safe bowl of water in the oven and heat it to boiling, stop the microwave, then leave the bowl of water in the oven for about 10 to 15 minutes. The steam will loosen the dirt and grease and then it can be wiped with a damp sponge. More stubborn grease my need dish soap on the sponge and a little more elbow grease. Rinse it well with a clean sponge or dish cloth and warm water.
Feb 15, 2013 | Microwave Ovens
My LG MICROWAVE OVEN IS MODEL MC-7836M CONVECTION MICRO GRILL IT IS RUNNING BUT NOT HEATING and GRILL ALSO NOT WORKING
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 27, 2010 | LG LRM1230W Microwave Oven
Sharp microwave grill and oven working ok, microwave option not
the magnatron is burnt out they are very expensive to replqace thus i would suggest bying a new microwave
Apr 21, 2010 | Microwave Ovens
Emerson Microwave Oven and Grill
The micro wave part is not working in your oven. It is mainly due to to the defect in the magnetron and the related components like high voltage side fuse and high voltage diode etc. you can check the fuse and the diode with a multimeter. If they are ok replace the magnetron.
May 23, 2009 | Microwave Ovens
Start button intermittent eg press many times (maybe 20) to start
Problem identified as plastic pushbutton on control panel, solution: interchanged with turntable on/off button (nevrer used). Had paid Miele €115 call out (for person who knew nothing about microwaves), Miele operate a closed shop. Local repair service say Miele will not supply parts, Miele designated repair agent will not repair microwaves, Miele will only send "engineer" to customer, no drop off facility. Was forced into buying new microwave oven from Miele as only way of recouping callout charge. Subsequently had a go myself with above positive positive result - now have a spare microwave cooker.
Mar 18, 2009 | Miele M625EG Convection Microwave Oven
Microwave Ovens Logo
75 people viewed this question
Top Miele Microwave Ovens Experts
William Miller
William Miller
Ruth summersides
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
