Question about LG Shine KE970 Cellular Phone
LG td-c70040e tumble dryer Clean Filter indicator will not go off
Dear all,
LG td-c70040e - despite cleaning the filters the "Clean Filter" light refuses to go off and hence the dryer will not work.
I have repeatedly cleaned the filters and removed the back to try pressing the reset button but problems remains.
....can you please help?
  • frogwaxer Nov 08, 2008
    ....Sorry condenser has been cleaned too.
  • johnstamp Nov 27, 2008
    i have the exact same problem,clean filter light on, so machine will not start, any advice welcome,
There is an access flap below the door on the bottom left.  Open the flap turn blue levers, take plastic cover off (there may be a bit of water there).  Clean the inside.  Problem solved
Posted on Feb 14, 2009
Try 2945#*# and factory resetting good luck
Posted on Nov 09, 2008
Just run with coll air
Posted on Feb 28, 2009
    Problem Solver:
Its your pcb board faulty it will cost you about £75
Posted on Sep 04, 2009
Where is the filter on tumble dryer AWZ241
Hi Angie, The filter is at the back right in the middle, You pull the cover off and clean off the lint.........CHEERS..
Apr 27, 2016 | Electrolux IQ-Touch EIMED55IIW 27"...
The tumble dryer bip and flash "empty water" even if no water. I have cleaned every filter (2 inside the big filter at the bottom of the tumble dryer) but still have the trouble
I want to first make sure that your dryer is serviced up. so i want you to do these steps.
Most of the problems will be resolved doing these......
As clothes are tumble dried, they drop fibres. Most of this fluff is trapped by the lint filter and this needs to be checked and cleaned regularly. Lint also builds up in the vent pipe and around the electric motor in the rear of the dryer.
1.clean lint filter
Wait until the dryer cools, open the door and lift out the lint filter.
Gently brush off lint using your fingers.
On many models, the filter may also be washed. Check your manual for instructions.
If the filter is damaged in any way, you should replace it.
2.Vacuum area where lint filter sits:
The area where the lint filter sits should be vacuumed .
Remove the lint filter, and use a narrow vacuum nozzle to remove dust and lint from the fitting.
3.Clean inside the tumble dryer:
1. Make sure the dryer is cool, switch it off and unplug it.
2. Unscrew the retaining screws on the back panel, and lift it off. Vacuum the blower area.
3. Also vacuum around the vent pipe connection.
4. Replace the back panel and refit all the screws.
4.Check tumble dryer vent hose:
8d2299a.jpgWait for the dryer to cool. Unplug the vent hose and inspect its entire length for snags in the pipe.
Make sure the vent is not obstructed on the outside wall, and fit a flap or screen to keep out small animals.
If your vent pipe is punctured or damaged, you should replace it.
To avoid dryer problems,
Make sure the dryer is level and does not rock, and consult the manufacturer's instructions for the maximum weight of clothing to dry at one time. Also, make sure clothes have been spun-dry before putting them into the dryer.
This is just initial help,
Post your comments about how things turned up, Ill be giving suggestions based on your reply........
Thanx for using fixya,
Cheers.
Sep 27, 2008 | LG Dryers
My lg front load dryer lights up with check filter and the flow restricter light comes on too. The dryer won't start to tumble or heat. all clean and no air restiction. ???????
have you cleaned the in side pipes ??? and the output pipes. then make sure as you will then need to press power and select at same time and it should chime then turn off, press power and set settings and should start.
May 19, 2015 | LG Dryers
Clean filter
If this is a condenser dryer, it could be the condenser unit that needs cleaning
Dec 21, 2013 | Siemens Dryers
Turned on dryer & tried to start but it gave a load thud noise & wouldn't go. Stop it then re-started a light came on stating clean filter. Clean filter & look inside that area to see if...
there is a sensor located beneath the lint filter, more the likely the dryer sheet residue is on it, gently brush it off, it has two screws. As far as the loud thud noise is/may be a problem with the drum/rollers/glides/belt/idler arm/motor Here is a website that will assist you, once the filter light goes off and the drum will not turn.Good Luck Tim
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 05, 2011 | LG DLG5988 Gas Dryer
CLEAN FILTER LIGHT REMAINS ON ALL THE TIME, I HAVE CLEANED FILTER, PROBLEM STILL PERSISTS. i HAVE ALSO CHANGED THE DOOR CATCH AS THIS APPEARED DIFFICULT TO CLOSE.
Hi, My Hotpoint Aquarius TCD32 0771200901
Tumble dryer stopped working, first a filter care light, so cleaned the filter and now the light comes on but nothing happens. Any ideas? Thanks
Dec 17, 2010 | Hotpoint TDC32 Electric Dryer
I need to clean my filter on my beko tumble dryer!
I usually just stick the shower on it to clean out all the bits of fluff that gets gathered in there, but remember to give the inside of that hatch u brought it out of with some kitchen towel before u put the condenser filter back in.
Feb 23, 2010 | Dryers
LG TD-C70040E dryer shows ELE/EHE code ....
This happened to my LG dryer and I took of the raised back panel that covers the flywheel and there is a red reset button. This worked for me.
Good luck
Funny how this happened after 3 years exactly. hmmm
Jun 14, 2009 | LG DLE5977 Electric Dryer
Clean filter light stays on LG TD-C70045E Dryer
I had the same problem. It actually has nothing to do with the filters. If your dryer sounds like it wants to start the capacitor is blown.
Dec 07, 2008 | Zanussi TC7102W Electric Dryer
LG Shine KE970 Cellular Phone Logo
2,642 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
