Question about Gigabyte GA-8ID533 Motherboard
P4 2.66GHz 533FSB Problem on Gigabyte GA-8ID533
I have been running a Pentium 4 2.0GHz 400MHz FSB processor on a Gigabyte GA-8ID533 (1.1) board. I wanted to upgrade my processor and went on Gigabyte's website to look at compatible processors. I bought a Pentium 4 Northwood 2.66GHz 533MHz FSB Processor online as the website shows this processor as compatible, and tried to install the processor. When I tried to boot up, i get a blank screen, no beeps, just the fan running. When I replace the original processor, everything runs fine. The stats on the GA-8ID533 show that max FSB is 400MHz, but prcessor compatibility searches online show that there are a numer of 533MHz Bus Pentium 4's and Celerons that will work. Do i need to change the BIOS or CMOS Settings proir to installation? I have already updated the bios to F4.
Please help!!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 175 Answers
Well if the board support till 400FSb then the 533FSb CPU will not work with the board did you check the website and he board manual that says it support upto 533 bus?
Posted on Nov 08, 2008
I want to know that shall i put pentium 4/ 2.4 Ghz/ 533 Fsb/ Processor on this Gigabyte 845GVM-RZ board? will it support ?and i have 1 Gb ddr1 400 mhz ram will this work on this Board?
Yes for the Intel Pentium 4/2.4GHz/533FSB processor. (Socket 478)
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#Northwood_.28130.C2.A0nm.29
(Scroll through. What sSpec number is on top of the processor's case? {You are following Anti-Static Precautions, correct? }
Won't support better than a Prescott Core Pentium 4. (Next chart down)
The Gigabyte GA-8I ((Supports 400MHz or 533MHz FSB)
NO to the Ram Memory.
The Gigabyte GA-8I845GVM-RZ supports DDR Sdram at 333Mhz. (PC2700)
IMHO it will not support DDR Sdram at 400MHz. (PC3200)
My reasoning is this;
Ram Memory typically operates at half of the FSB frequency rate of the Processor.
Processor FSB > MAXIMUM frequency rate is 533MegaHertz for the GA-8I845GVM-RZ
Ram memory at 333MHz is doable.
Not 400MHz.
No, you won't be able to overclock, and bring the FSB of the Processor high enough for PC3200 Ram Memory.
(The rest of the motherboard wouldn't work anyway if you did. PCI Express bus, PCI bus, etc., would not match)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128238&cm_re=Gigabyte_GA-8I845GVM-RZ-_-13-128-238-_-Product
Have more questions concerning this, or comments, please post in a Comment.
Regards,
joecoolvette
Nov 08, 2010 | Gigabyte GA-8I845GVM-RZ Motherboard
Do you give me a list of gigabyte ga-81rm memory suppor ?
307_sub.jpg GA-7N400 (rev. 2.0)
  1. Supports AMD Athlon™ XP 400MHz FSB processor
  2. Supports Dual Channel DDR400 memory architecture
  3. Supports AGP 8x interface for outstanding graphics performance
  4. Integrated 6-channel AC'97 audio with S/P-DIF function
  5. Provides 6 USB 2.0 for high-speed connectivity
Oct 12, 2010 | Gigabyte GA-7N400 Pro Motherboard
Upgrade to window vista & can the processor be upgrade
Hello Rizmum,
Yes you can change the processor,Kindly look for following processors if they are available in the market
Intel Pentium -M (Dothan) 725 1.6GHz 2M/400MHz FSB (Pentium M 725 (1.6G 2M 400FSB)
INTEL PENTIUM M 1.7G 2M 400FSB uFCPGA2 SL7EP B-1 STEPPING (Pentium M 735 (1.7G 2M 400FSB)
ntel Pentium -M (Dothan) 745 1.8GHz 2M/400MHz FSB (Pentium M 745 (1.8G 2M 400FSB).
Let me know if you require any further information on this.
Thank you,
Regards
Hemanth
Apr 13, 2009 | Computers & Internet
Upgrading laptop CPU
Yes. Your motherboard only supports cpu's with a FSB of 400mhz. If you want to upgrade you would need a compatible cpu running 400mhz FSB. Hope this helps.
Dec 24, 2008 | Toshiba Pentium M, 1.5 GHz 715...
Will my motherboard support a Core 2 Duo processor: GA-8S649MF (Gigabyte Motherboard)
Every system needs a rock-solid foundation, and that's just what you get with this Gigabyte GA-8S649MF motherboard. It features Socket 775 compatibility and support for Intel Pentium 4 or Pentium Dual-Core processors with 800 MHz front side bus speeds. Two DIMM slots support up to 2 GB of DDR400 system memory.
Dec 21, 2008 | Intel Motherboard
Upgraded cpu- wont boot
Teresa, if you changed the front side bus to 533, your memory must have the same clock speed. Memory clock speeds are what is known as "backwards compatible" but not forwards. This means that you could put a piece of memory of a clock speed of 400mhz into a system that runs at 333mhz and it will "downclock" the memory, but you could not put a piece of 333mhz memory in a 400mhz fsb pc and expect it to run. one of two things will happen, the system will not boot at all or the syetm will downclock the processor to a slower speed. In your case your cpu must be 533mhz clock speed with pc4200/533mhz memory to function correctly.
compdoctor2005@btinternet.com
Dec 13, 2008 | Shuttle AV49VN Motherboard
Audio/sound
For the Vista compatible sound drivers of a Realtek AC'97 as used in a Gigabyte GA-8ID533, pls try here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 29, 2008 | Gigabyte GA-8ST800 Motherboard
Motherboard
Hi hamideh, your board can Supports up to 3GB PC100/133 SDR-SDRAM Dual memory module DIMM's
Here is the link to your board.
http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1402
Enjoy hamideh...
& please vote for me
Mar 08, 2008 | Gigabyte GA-8ID533 Motherboard
Gigabyte GA-8ID533 Motherboard Logo
268 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
