Question about Whirlpool Duet GHW9150P Front Load Washer
Front load will not lock
When I try to start washer I close the door and the click normally heard is absent. The washer panel has all of the proper lights on and appears to be working. The problem is the washer will not turn on because I suspect the washer is not locking the front door and the washer will not start. Please any help will be great.
  • Anonymous Nov 09, 2008
    front load machine wont lock so machine wont start.
We are not hearing beeps only the light flashing on the chosen load cycle like normal. Any other ideas?
Posted on Nov 10, 2008
  • 62 Answers
Are you getting three beeps when trying to start, if so door lock problem
Posted on Nov 08, 2008
The code f-DL displays whn I try to start the machine . I was thinking the door lock was jambed so I used a flat tip screw driver to jog the lock. The problem now is the lock is now locked and won't...
Remove the screws attaching the bottom flange of the lower front panel to the machine cabinet then pull the panel down and off. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily. Once the panel is off, reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side. Locate the tear-drop shaped tab then gently pull it down until a click is heard.
You can also remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel. Pull down gently on the release tab until a click is heard.
The FdL code indicates a door lock failure and you need to replace the door lock/switch assembly if the problem persists after resetting the door lock. Click on the link below for the details of the procedure.
Kenmore Elite and Whirlpool Duet Error Code FdL
Jul 16, 2011 | Kenmore Elite 45986 Front Load Washer
Frigidaire Front Load Washer Model LTF2140FS1. Put clothes in washer, fill detergent dispenser, close it, shut the door, set my cycle hit start then the door lock clicks, clicks again, panel shuts off....
Make sure that the switch for the door is closing properly at all times. If not, unit will not start up or will shut down while operating because the switch has opened.
Sep 12, 2017 | Washing Machines
The door remains locked
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it.
Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side. Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. The replacement procedure is here.
Some
Whirlpool-made Front Loading such as the Kenmore Elite use another type of door lock and switch assembly but still with the release tab and can be accessed through the washer top. Remove the screws attaching the top panel to the rear of the machine then pull the panel rearward and off the cabinet. Pull the release tab until a click is heard then open the door.
Dec 24, 2010 | Kenmore HE2 Plus Front Load Washer
My duet ffront load washer give me the error code dl then an f when I try to start the cycle. I have tried pause cancel twice then opening the door and starting the cyle and closing the door last thing...
The door is not locked after 6 trials then the Central Control Unit (CCU) will enters a failure mode and the digital display flashes FdL. This is a door lock failure and the only viable solution is the replacement of the door lock and switch assembly.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Gently peel the part of the door gasket near the door lock and switch assembly off the lip of the door opening outer lip. Remove enough of the door gasket to access the door lock and switch assembly behind the front panel.
Remove the three screws securing the door lock and switch assembly to the front panel and slightly lift then pull it back off the front panel and out of the out of the washer cabinet.
Connect the wiring harness to the new door lock and switch assembly one at a time then install it back in place behind the front panel.
Secure the door lock and switch assembly then put the eased part of the door gasket back over the outer lip of the door opening. Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Sep 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer wont start door is locked
You can manually Unlock the door Lock System
1. Unplug washer or disconnect power. 2. Remove the lower kick panel. 3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit. 4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab. 5. Gently pull the tab down about a ¼" or until a click is heard. 6. The door may be opened.
Thank you !!
May 27, 2010 | Kenmore 44102 Front Load Washer
Front Load washer won't start , door lock light on, not locked
needs new door interlock,( sits behind where the door catches on to) easy to fit normally, make sure you un unplug the washer before starting.
Sep 29, 2009 | Washing Machines
The control locked light is on and can't start the machine
Power shd be on, try to hold down 'end of cycle' button for 3 seconds, try door after a minute or after hearing a click. IF NOT:
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about 1/4 inch or until a click is heard.
6. The door may now be opened.
Apr 06, 2009 | Kenmore Elite 45986 Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
FRONT DOOR LOCKED
First try to hold down 'end of cycle' for 3 seconds, try door after a minute or so after hearing a click, power shd be on. If not:
Nov 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
452 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
