Question about Kenmore 44103 Side by Side Refrigerator
Cant seem to get the Icemaker working
This is a brand new refrigerator. I am trying to connect my icemaker. However, after connecting the water pipe from the water supply to the refrigerator connection at the bottom, the water doesnt seem to flow into the refrigerator and it causes a leak right at the connection(brass compression nut). Is there a valve that need to be opened to make the water flow into the refrigerator or what am I not doing right?
  • Anonymous Mar 12, 2014
    There is no icemaker.
    President:
  • 878 Answers
Mungah, There is no valve that needs to be turned on. The water travels through the valve into the filter and up to the ice-maker. Try pressing the water lever and stay on it until the water fills the filter and comes out. You should hear the valve energizing. The ice maker cycles every 2.5 hrs. approx. When it calls for water it may take several cycles to prime the line and fill the ice maker...As far as the leak, something is wrong with that compression connection, re-do it and see if it stops...Catriver..post back.
Posted on Oct 21, 2006
My lg refrigerator lsxs26326 is dispensing water but not filling ice tray up. What could be wrong?
the water solenoid valve for the water dispenser is separate from the icemaker water supply solenoid valve . get to the icemaker water supply solenoid and test it if it works alright . unplug the fridge from wall outlet do not close water supply valve. disconnect water tube connection on the water discharge side of the icemaker water supply solenoid valve . pull - out power supply connection of the solenoid coil . connect solenoid valve directly to wall outlet. a faint click should be audible and water should come out from where the tube was removed -- from the water supply discharge side. if no water is coming out with the solenoid plug in , then the solenoid is faulty. but if water comes while solenoid is powered -on , check the position of the icemaker lever. if it is on off position icemaker timer won't activate icemaker water supply valve..move icemaker lever to on and check for water pouring into the icemaker tray' if no water comes out . change the icemaker timer. thanks.
Mar 04, 2016 | LG Refrigerators
Tip
How to repair an ice-maker of a refrigerator
An icemaker receives water through a small, 1/4-inch water supply line that runs from the refrigerator to a water pipe, where it is connected by a tap valve. The water supply line enters a valve in the refrigerator that is controlled by an electric solenoid that sends water through a fill tube into a mechanized icemaker assembly. There, the water freezes and is dumped into an ice bin. When the bin is full, the ice lifts a bail wire that turns off the icemaker. If the water’s route is blocked or the solenoid doesn’t work—or if the bail wire is lifted—the icemaker won’t make ice. (Also note that your home’s water pressure must be strong enough to serve an icemaker.)
Here are a few steps you can take to get your icemaker working (be sure the bail wire above the ice tray is in the down position):
1) If the icemaker doesn’t make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is finished, the water valve is asking for water that isn’t arriving. This means the valve and the solenoid are probably okay, but the water supply is not. Be sure the water supply line isn’t kinked behind or beneath the refrigerator (1/4-inch copper tubing is much better than plastic fill line).
2) Check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
3) Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
4) Check the tap valve; a bad tap valve may cause the problem where the icemaker’s supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the “self-piercing” type). You can do this yourself, or call a repairperson or plumber to install an inline water filter when replacing the valve.
5) The water line attaches to a solenoid at the back of the refrigerator and then travels to the icemaker. The solenoid may be defective or may not be receiving power. You can try removing the sediment screen inside the solenoid and flushing it with water to clean it, and at the same time you can inspect any seals or diaphragms to ensure that they are sound. Unplug the refrigerator first. Unless you’re skilled at home repairs, this job is better left in the hands of an appliance repairperson.
on Sep 02, 2010 | Refrigerators
Freezer stopped making ice
Without any more information regarding the specific symptoms, diagnosis will be difficult. However, assuming that your refrigerator has a factory built-in ice maker, there are several items to check:
1. Is there water flow to the icemaker? If not, check the water supply line (small tubing) and make sure it's not clogged. Disconnect it and blow it out, then reconnect.
2. Check the small saddle valve on the water pipe where the tubing to the refrigerator connects. If it's full open, then it's possibly blocked with calcium buildup. Close your main water supply valve, remove that saddle valve and replace it with a new one. Before doing so, make sure that the hole in the water pipe is clear and full open. It may also have some calcium buildup. If so, simply drill it out with an appropriate sized drill bit.
2. The solenoid valve which activates water flow to the icemaker may have stopped functioning. Check the electrical connection to the solenoid valve and ensure power is getting to it. If it is, then the solenoid valve most likely needs to be replaced.
3. Check the manual for your refrigerator. It should include instructions on how to bypass the automatic function and *manually* start the icemaker.
May 28, 2014 | Kenmore 57029 Side by Side Refrigerator
Which water line or lines do I connect to refrigerator, model # ED22RFXW01, man. 08/99
It's advisable to go with flexible plastic tube with sweet water supply. Please follow the instrction as per video attached.
Even if your refrigerator comes withan automatic icemaker, you will need to connect it to a water supply for it tomake ice. While this is not a particularly difficult job it requires someknowledge of plumbing and the use of tools. ThingsYou'll Need:
  • Compression Nuts
  • Knife Or Scissors
  • T-valves
  • 1/4-inch Copper Or Plastic Tubes
  • Drill Bits
  • Variable-speed Drills
  • Drill Bits
Read theinstruction manual that came with your refrigerator. Specific instructions forhooking up the icemaker may be included. Locate thepipe nearest the icemaker that carries cold water. Most often, this is the coldwater pipe that connects to the kitchen sink. Install at-valve in the main cold water line - not on the 3/8-inch faucet tubes - sothat there are two outlets: one to the sink and one to the icemaker supplyline. Turn offthe water. Put asleeve and compression nut over the line that will supply the icemaker in orderto tightly connect it to the water line. Turn thewater back on, and, holding the end of the tubing in the sink or over a bucket,flush the line to remove any debris. Turn the water off again. Snake theline from the water source to the icemaker connection, drilling holes in thebacks of cabinets if you have to in order to push the line through. Find theicemaker inlet from the refrigerator and attach the other end of the line usinganother compression nut. Turn thewater back on. Throw awaythe first few containers of ice to be sure the line is completely clean beforeyou use the ice.
http://www.youtube.com/watch?v=vB-uUMsckSA&feature=related
thanks.
Feb 05, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ref GS5SHAXNL00 NEW ICE MAKER NOT
Check your water pump to see if it's working.
Also you might miss some connection when you replaced the new one so double check all your connection
Nov 30, 2017 | KitchenAid KSRG25FK Side by Side...
Icemaker is not making ice.
First, check to see if you have an adequate water supply. The valve connected to your cold water pipe may be obstructed. Next, does there seem to be any sounds comming from the icemaker? Also check to see if the lever that controls the amount of ice is stuck all the way up. If this is the case simply push the lever down. Generaly, ther are not many serviceable parts in the ice maker. A bad timer might also be the culprit.
Aug 20, 2009 | Refrigerators
Icemaker not signalling for water.
cheek the condenser fan.if its opration is not correct.
May 23, 2009 | Whirlpool GD2SHGX Refrigerator
Icemaker stopped working
you likely need a new icemaker (part # 2198597) i would visit the following website to help determine this fact.  http://fixitnow.com/sbrvrs/icemakers.htm
Feb 05, 2009 | Whirlpool GD5SHAX Side by Side...
Icemaker does not work
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 15, 2008 | GE Profile PCF23NGW Side by Side...
Kenmore 44103 Side by Side Refrigerator Logo
155 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Bill
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
