Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Hitachi 50v 500a
The small fan in the rear never turns off. wht can i do
  • 10,594 Answers
This fan is to cool down power supply temperature and even in standby mode power supply works.
Posted on Nov 08, 2008
Hitachi 50V500. The fan will not turn off.
the transistor that controls the fan has shorted out and needs to be replaced, follow the wiring down from the fan to the pc board and trace the connection from the plug to the transistor, and replace,,,good to go, let me know how that worked
Jan 27, 2010 | Televison & Video
From about 4 inches down from the top of the tv and from the center to the left corner is red and green and the corners on the bottom of the tv are also arched but not as bad
this is a vartical non linarity folt .
chech vartical stage capaciter 470umf/63v 4.7um/50v 1000/50v
0.47um/63v Replace and first svr.menu to set vartical linyarity adj.
set V- hight is sum down sum 1" or 2 " after the set vartical linyarity V-line. set up to down and check the pictur. if not then Replce capaciter.
Oct 04, 2009 | Hitachi 51F500 51" Rear Projection...
Cooling fan won't turn off.
this set has more then one fan; one fan will run all the time to cool the digital circuit board---if it is the actual LAMP fan then you have a problem---the digital fan is very small and not located near the lamp.
Aug 06, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
HITACHI 50VS810 WON'T TURN ON. .
If the set comes on momentarily, see if the lamp fan is turning. If not , the fan is probably bad.
Hope this helps,
skyassoc
Jun 26, 2009 | Hitachi 50VS810 50" Rear Projection HDTV
Hitachi 60fx30b
ck F 903 and c730 4.7 uf 50v capacitor it is a Non-Ploarized cap also resolder relay black square little box they have been known to have poor solder connection.
Dec 02, 2008 | Hitachi 50FX30B 50" Rear Projection...
Hitachi 43fdx20b Need capacitor but i dont know which to buy!!
Hello Soleftright,
I have CK24 as a 1000pf 50v cap. Look at CK25 it is the same value as CK20 - CK24. Were your convergence ICs STK392-110s? One side of the cap goes to pin 14 of the (IK-04) IC and the other to ground.
I hope this helps
Thank you,
Shuttle83
Oct 21, 2008 | Hitachi 43FDX20B 43" Rear Projection...
Won't turn on
Resolder all poor connections,relay resolder it check Fuse903 and Non-Poliarized capacitor 4.7uf 50v C730
Oct 12, 2008 | Hitachi 50FX30B 50" Rear Projection...
Hitachi 53UDX10B Power Light Flashing after convergence IC replacement
C603 is a polyestor capacitor 0.068UF-FEB 50V part number 0880047R S901 is the power relay ALKS329 the part number for the relay is FJ00142 . I recomend checking the pins on the ICs to make sure they are not bridged. If you need more assistance let me know. Vance Baldwin should have the parts if not you may have to order through hitachi
Jun 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
126 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
