Question about Logitech Quickcam Ultra Vision Webcam
Echo suppression I cannot remove the echos during a video session. The set up has the "Cancel Echo" and "Suppress Backgroud Noise" greyed out making it impossible to check those boxes. These boxes were available up until the last Logitect update. Running Windows Vista 32 and Logitech microphone is selected
    President:
  • 8,637 Answers
I don't know how to remove the echos from you video but think I know what is causing them.
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I'd use headphones during videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Posted on Feb 01, 2009
How do we set up echo to our home Internet?
to setup the Amazon Echo you need its Amazon echo app from the google playstore app normally the echo will tell you how to do so on its own if it is your first time setting the device up
Jan 08, 2017 | Miscellaneous
How how do i get the echo off of my phone
Amy, Go into call history log, hit menu, go to call settings, additional settings, and unclick the Noise Reduction selection.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cell phone echo problem How to fix
http://boards.straightdope.com/sdmb/showthread.php?t=150390
How to Cancel the Echo on Cell Phone eHow
Person talking to hears their echo how do fix this
Mar 05, 2016 | Cell Phones
How do i reduce effects
if you have echo during session try installing foam around the room you are in ... so that sound don't bounce off the walls to mic on a recording session..
Aug 12, 2012 | Behringer UB2442FX / Harbinger APS12 PA...
2000 toyota echo alternator noise
yes the water pump can be the culprit
May 19, 2012 | Toyota ECHO Cars & Trucks
People i am talking to on my pantech burst cannot hear me because there is an echo on their end
I had the same problem and had tried everything. The noise conceling was turned on and made no difference. I finally put a piece of sctoch tape over the second microphone located beside the flash and the problem disappeared. I think the dual microphone is causing the issue, it picks up the speaker sound and the time delay causes the echo.
Feb 27, 2012 | Cell Phones
What is the mean auto exe c bat in dos files??
An AUTOEXEC.BAT file contains MS-DOS commands which are executed automatically when a Personal Computer boots. This file is usually located in the root directory of the hard drive or floppy from which the computer boots (or starts) up. The AUTOEXEC.BAT file is used to set various default settings and to run programs that should be executed upon startup. Below you will find a list of executable statements (commands) that typically go into an AUTOEXEC.BAT file, along with explanations their.
The AUTOEXEC.BAT file is one form of a batch file, and it is used to automate functions in MS-DOS. In their simplest form, batch files contain MS-DOS commands (batch file language) which includes commands for such things as loops and execution branches and the like.
ECHO
Example: @ECHO OFF
This optional command will suppress the display of subsequent commands while the AUTOEXEC.BAT file is being executed
Dec 09, 2010 | Computers & Internet
Echo Problem
Try one or more steps to reduce echo:
1. In Device Settings, under Mircophone test make sure that 'Auto Adjust Audio' is checked. It automatically sets the audio and reduces echo.
2. Right click in the class window to open up the context menu. Click Settings in the menu. Macromedia Flash Player Settings window opens up. Click on microphone icon and check 'Reduce Echo' option.
3. Uncheck boost in microphone device settings.
4. Use a headset and not desktop speakers.
If a class participant (may be an attendee or a presenter) is experiencing echo then all other class participants are required to make settings at their ends. Preferably, the presenter may transfer control to the attendees one by one and identify the system generating echo.
Jan 16, 2010 | Acer 90.00012.30B Computer Speakers
Hp g6000 running very slow any suggestions.
The HP g6000 slow issue can be caused by many many reasons such as outdated hardware, overload startup programs, corrupt registry issues, too many junks, virus attack, poor security software taking too much system resources, remnants of uninstalled applications etc. The fact is, you should keep some system maintenance job regularly. If you don't want to do these manually, try the solution http://www.speeduphp.com/fix-slow-hp.html to give a free & full scan of your slow HP PC to find & fix all possible issues.
Meanwhile, upgrading hardware configuration (add RAM, change a new video card, larger-volume HDD etc) can be a fast yet effective way to improve your pc performance.
Mar 09, 2009 | HP Pavilion dv6000z Notebook
MSN Heavy Echo During Video Call
Which microphone do you use? an external one or built in?
Jan 05, 2009 | Acer Aspire 6930-6771 Laptop
Linksys adapter
Factors that Affect Voice Quality
  • Audio Compression Algorithm
    Speech signals are sampled, quantized and compressed before they are packeted and transmitted to the other end. For IP Telephony, speech signals are usually sampled at 8000 samples per second with 12-16 bits per sample. The compression algorithm plays a large role in determining the Voice Quality of the reconstructed speech signal at the other end. The SPA supports the most popular audio compression algorithms for IP Telephony: G.711 a-law and µ-law, G.726, G.729a and G.723.1. The encoder and decoder pair in a compression algorithm is known as a codec. The compression ratio of a codec is expressed in terms of the bit rate of the compressed speech. The lower the bit rate, the smaller the bandwidth required to transmit the audio packets. Voice Quality is usually lower with lower bit rate. However, Voice Quality is usually higher as the complexity of the codec gets higher at the same bit rate.
  • Silence Suppression
    The SPA applies silence suppression so that silence packets are not sent to the other end in order to conserve more transmission bandwidth. Instead, a noise level measurement can be sent periodically during silence suppressed intervals so that the other end can generate artificial comfort noise that mimics the noise at the other end using a CNG or comfort noise generator.
  • Packet Loss
    Audio packets are transported by UDP which does not guarantee the delivery of the packets. Packets may be lost or contain errors which can lead to audio sample drop-outs and distortions and lowers the perceived Voice Quality. The SPA applies an error concealment algorithm to alleviate the effect of packet loss.
  • Network Jitter
    The IP network can induce varying delay of the received packets. The RTP receiver in the SPA keeps a reserve of samples in order to absorb the Network Jitter, instead of playing out all the samples as soon as they arrive. This reserve is known as a Jitter Buffer. The bigger the Jitter Buffer, the more jitter it can absorb and the bigger the delay it can introduce. Therefore the jitter buffer size should be kept to a relatively small size whenever possible. If jitter buffer size is too small, then many late packets may be considered as lost and thus lowers the Voice Quality. The SPA can dynamically adjust the size of the jitter buffer according to the network conditions that exist during a call.
  • Echo
    Impedance mismatch between the telephone and the IP Telephony gateway phone port can lead to near-end echo. The SPA has a near end echo canceller with at least 8 ms tail length to compensate for impedance match. The SPA also implements an echo suppressor with comfort noise generator (CNG) so that any residual echo will not be noticeable.
  • Hardware Noise
    Certain levels of noise can be coupled into the conversational audio signals due to the hardware design. The source can be ambient noise or 60Hz noise from the power adaptor. The SPA hardware design minimizes noise coupling.
  • End-to-End Delay
    End-to-end delay does not affect Voice Quality directly but is an important factor in determining whether subscribers can interact normally in a conversation taking place over an IP network. Reasonable delay figure should be about 50-100ms. End-to-end delay larger than 300ms is unacceptable to most callers. The SPA supports end-to-end delays well within acceptable thresholds.
Dec 01, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Logitech Quickcam Ultra Vision Webcam Logo
108 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
