Question about Sceptre DragonFlat D73F (White) 17 in.CRT Conventional Monitor
Sceptre D73F Dragonflat Not enough contrast
Dragon eye/Dragon flat CRT monitor, 17" manufactured April 12 2001 Adjustments are on front, OSD type. This display is pale, even when brightness control is right down and contrast right up. Other settings OK. A quick look inside shows a bit of dust otherwise no obvious problems. All parts thru hole, can't see any SMD. I can't find any obvious controls or pots to adjust. Is this the end? Klave
4 Suggested Answers
  • 18 Answers
SOURCE: X7G-Naga Sceptre 17" LCD Monitor
Try your monitor on a different computer and see if you get the same result, if not, there is a problem with your pc operating system and or video card. If you get the same result, get a new lcd if it is not under warranty.
Posted on Jun 12, 2008
SOURCE: control buttons on flat screen scepter monitor
My 22" Scepter Monitor wont light-up, pulsating blue light on. I posted this SOS a feww hours ago but I couildn't sign into FaceBook. Please anyone with a solution would be tremendously appreciated.
Best regards,
Oscar
Posted on Oct 27, 2009
SOURCE: i have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Posted on Nov 10, 2009
How do I Adjust contrast And sharpness
To adjust contrast and sharpness
1. Press osd button (on screen display)
2.Use the up and down arrows to highlight selection then press auto/set button
3. Use the arrow keys to adjust settings
4. When you have finished press the osd button to save and exit
Thank you for using fixya.
Jul 11, 2011 | Gateway FPD 1730 17 in. Flat Panel LCD...
"OSD LOCKED" box on my screen
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
OSD stands for "On Screen Display." It is an onscreen configuration menu included with various monitors. When you press the MENU button or one of the other buttons on the front or side of a monitor, the onscreen display may appear. The OSD typically includes monitor calibration options, such as brightness, contrast, and color adjustments. Some OSDs may also include horizontal and vertical position controls as well as tilt and keystone adjustments.
If you can't make adjustments to the monitor settings using the OSD interface, the onscreen display may be locked. You may also see the phrase "OSD Locked" appear when you try to change the settings. Some monitors include an option within the menu called "OSD Lock", which you can turn on or off. If this option is available, simply turn OSD Lock off and you will be able to make adjustments to the settings.
If your monitor does not include the "OSD Lock" option, you may be able to unlock the OSD by pressing and holding the MENU button on the front or side of the monitor for several seconds. If you try this method, be patient! It may take up to 15 seconds for the OSD to unlock.
VOTE ME
Dec 07, 2010 | Dell Computers & Internet
What is meant by osd
On Screen Display.
It's an on-screen display of adjustments such as brightness and contrast.
Sep 13, 2010 | ViewSonic E70fb (Black) 17 in.CRT...
How do I change the imaage sixe on the screen using the controls on the front of the monitor?
Here are the controls for the on screen display (OSD) adjustments:
http://support.dell.com/support/edocs/monitors/e172fp/En/controls.htm
Make sure that you have the Windows Display Properties resolution set to 1280 x 1024 before making any OSD adjustments.
Dec 27, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
OSD automatically displays and I can't rid of it. Monitor display adjustments are being made and I can't control it. Sometimes it's like this. Sometimes it's OK. I am having this problem for months...
My view sonic monitor E70fB Model. Without I Press the menu, it always appearing on the Screen. Some times Contrast up/down and osd lock and it suddenly scrollsfor other options.
If I press the exit button, it sometimes exits or agin it occurs.
So please kindly solve this problem
Dec 06, 2008 | ViewSonic 17" CRT Monitor
Dark colors
Increege LOT screen preset
check G2 voltage at neck board G2 cathode
remove Sg caps
replace G2 pf
Oct 26, 2008 | LG Studioworks 700S 17" CRT Monitor
Troubleshooting
REPLACE FRONT SIDE OSD BUTTONS (EXIT,BRIGHTNESS,CONTRAST,MENU) IT IS MOISTURE PROBLEM
Aug 06, 2008 | IBM E74 17" CRT Monitor
Display menu virus? :(
try disconnecting your network cable and adjust the settings again, if you cant, enter safe mode by pressing f8 in the startup and select safemode then adjust the contrast there.
Or is this in the CRT monitor? inside the monitor? there are no viruses ever made for monitors. So its most likely a hardware fault in the crt. Maybe its time to buy a new one. LCD preferably easyer on your eyes.
Apr 28, 2008 | AOC 7F 17" CRT Monitor
OSD Locked
Press menu button for 5 seconds until the text "OSD Unlocked" appears on the screen.
Aug 28, 2007 | LG Flatron L1750S 17" LCD Monitor
Sceptre DragonFlat D73F (White) 17 in.CRT Conventional Monitor Logo
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
