I put in the radio code after changing my battery on a 2008 Honda. Radio works but the information doesn't appear, ie station, musician. etc. Spoke to a guy in parts and he tells me it needs to be done outside not in my garage, followed instructions, still doesn't give info. Thanks!
SOURCE: 2006 honda accord, after changing the battery.
Unless the Accord was jump started, creating possible power surge to damage radio, it should not of had any relationship to the radio.
But, just in case, would suggest disconnecting battery for 5 minutes, reconnecting battery, reentering radio code and see what happens.
If that fails, hopefully your under 36k miles or got the Factory extended warranty "Honda Care" Service plan, so take to the Honda Dealership to see what they say.
SOURCE: I need radio code for honda odyssey 2004
SOURCE: I replaced the battery on my 2008 Honda Civic
you will have to check your glovebox for manualy, there is also a card with the radio code, if you cant find it then the radio has to be removed to get serail # and then call the dealer; they will give you the code.
SOURCE: car radio decoder
notify dealer they have code the radio code is a security[anti theft ]code but it also activates when battery dies or changed out
SOURCE: 2008 honda accord stereo code error 4
I just changed the battery in my 08 accord same thing there is a code on the left side of glove box.type that code in using the preset numbers it will be on white sticker
