Kenmore front loader washer squeaks in washer mode and shakes in spin.
Recently, our Kenmore front loader washer started squeaking in the wash mode. I thought it was the rubber on the back of the bath mats that were washing, but then it started shaking in the spin cycle. Since then, the problem has gotten worse. It sounds like a belt slipping or maybe a bad bearing.
Shocks made of plastic squeaks, a little greese may help
Posted on Mar 18, 2009
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
The kenmore super capacity 3.5 washer is squeaking and and shaking during the spin cycle. The squeak can be quieted by pushing against the door, but continues as soon as the pressure is released. The...
One of my favorite problems!
We often think that washers are level BUT one of the 4 feet probably requires adjusting downwards so that it really presses against the floor. So-
Remove power.
Press very firmly against one front corner and in towards the centre (sorry- I'm a retired Englishman living in SW France!) and try to rock it. If it moves even the slightest it's the foot at that corner which requires adjusting- with the open-ended spanner which came with the machine (what spanner?)! An adjustable will do and make sure that the foot is adjusted downwards so that it does really press against the floor, almost to the point of raising the corner but not quite.
If not that corner then do the same with the other.
Once adjusted lock all 4 feet by screwing the lock nuts up tight to the base of the washer so they will not move. You should not be able to rock it anymore.
If, after this action, the washer STILL shakes during the spin cycle, I suspect the drum suspension springs/shock-absorbers as being faulty..........................but I would bet that adjustment will cure it!
Good luck,
John C
Feb 09, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
Front loader has gotten really really loud and shakes the whole floor when it spins properly. Today it left a lot of water in the clothes. It used to make a weird whining noise when it didn't spin out...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 13, 2010 | GE WBSR3140DW Top Load Washer
Whirlpool Estate etw4300sq squeaks during spin
WASHER IS FINE, SOMETIMES SQUEAKS WHEN THE TEMPERATURE CHANGES
Nov 08, 2009 | Crosley CW5000 Front Load Washer
Kenmore top-loading washing machine squeaks
Hi
Thanks for using FixYa. Please check if there are any sucked small clothes, safety pin, lint or debris in the water pump. If the pump is fine then the squeaking sound may be due to gear dogs in the agitator or bad gear case. The washer will spin and agitate at the same time. If the washer is still under warranty then do not try to open, repair or replace any part to void the warranty.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 13, 2009 | Kenmore 22422 Top Load Washer
Kenmore he2 plus front loader washing machine comes up with an error code or rL
The rL error code during the clean cycle is likely caused by friction on the spin basket shaft since you indicate that you hear squeaking when the washer is spinning. The squeaking is normally caused by a bad bearing in the rear tub shell. I recommend that you have the washer diagnosed and repaired by a Sears service technician. This type of problem will normally require an extensive tear down of the washer to repair. It is not a problem that you can normally repair yourself.
Open the door & slowly rotate the spin basket to see if you can feel any kind of drag on the bearings. If the bearings check good, the control board is sensing a load & will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 10, 2009 | Kenmore Washing Machines
My front end loader really shakes bad when it is in spin mode.
yes ,,check the lock nuts on the legs,,they came lose...onthejob
Dec 18, 2008 | Kenmore 43052 Front Load Washer
Squeak in Kenmore HE 2plus front load washer when drum spins
Squeaking noises are hard to find unless u open it and pin point where its coming from.. you can open the back cover if you are comfortable doing so.. let it run to see if you can heard... sometimes the bolt holding the pulley to the drum is loose and need to be tighten. Other possible is the shocks came loose or when install new.. the shipping materials were not remove..
Dec 13, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Aug 31, 2008 | Maytag MAH2400A Front Load Washer
Squeaking Washer
did you remove the shipping pins pins when you installed it
Jan 04, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
587 people viewed this question
Top Washing Machines Experts
