Question about Black & Decker 9"/230MM 5,000 Rpm Large Angle Grinder with 4 Hp Motor
Unable to loosen flange to remove disc on angle grinder
I have been using my grinder to cut masonry. It is brand new. However now I can't seem to loosen the outer flange to take the disc off and put in another. I tried using a pipe on the spanner for more leverage but ended up snapping one of the pins off of the spanner. I have another spanner and hope someone has a solution.
    Novelist:
  • 99 Answers
What sort of disc do you have on there at the mo? If its just an abrasive disc the easiest way to remove it is to use a hacksaw to cut the disc sideways so that you are actually sawing it out between the lock nut and rear flange. This will release the pressure on the nut. If it is a diamond blade and you have already snapped a pin spanner then I would suggest securing the blade in a vice and using a set of stiltsons/pipe wrench. While in the vice you could also try using a punch in the pin holes to shock it round a bit, then the pin spanner (and leverage if needed).
Posted on Nov 08, 2008
I had the same problem with 9" Hitachi, worn holes and worn cutting disc.
With a 5" I cut two parallel faces on opposite sides of the nut, just a few mm in and clamped the nut in a vice on these faces, pressed the button and swung the grinder, easy! We use the grinder again.
Posted on Dec 06, 2013
  • 3 Answers
I agree with the previous solution but would try a couple of drops or Kroil penetrant, K&N knok-r-loose, maybe some heat then try the wrench and the hacksaw last.
Posted on Jan 06, 2009
Misplaced my angle grinder's inner disc flange
If you use a nut, the arbor nut will not hold your grinding/cutting wheel properly and you'll use up threade the arbor nut needs to tighten. What you need is the clamping flange, Bosch part number 3603340501. If you have a tool repair center near you they may have one or can order you one. If not, you can get one on sites like www.ereplacementparts.com.
Dec 06, 2012 | Bosch 1800 4 1/2" Angle Grinder Cutoff
I have a D28110 angle grinder and I want to use a 1/8"cutting disc with it. Do I need a different guard than what it came with?
haven't heard of a different guard for the cutting disc you want to use. Most people remove the guard when using them
Sep 15, 2011 | Dewalt D28110 Heavyduty 412" Small Angle...
I've got a B & D Pro 4247 Grinder and I need to change out the grinding wheel and use another (because of the material that I'm grinding)... but I don't know how to remove the wheel that's on the...
if you don't have a spanner wrench, I would find a punch and loosen the outer flange, but the spanner wrench is not that expensive to have in the future. the part number is 149645-00. let me know if you need more assistance
Feb 11, 2011 | Black & Decker 7750 4 1/2'' Small Angle...
I own a metabo 9-125 quick but can't don't know how to place the blade
On the silver part on top of the grinder is a button , press this button and hold it down. now turn the blade until it stops moving, this locks the blade, keep holding the button down and turn grinder over ,and turn the nut counter clockwise, and remove it , take old blade off ,put on new one .it should go over the shaft and at the bottom on a "fit" Make sure it is on the "fit". replace the nut and tighten. If you dont get the nut tight enough it will loosen while in use and the disc you are cutting/grinding with will wobble and may even come off causing possible injury .
Jan 29, 2011 | Metabo ® 12 Amp 9000 RPM Model WE14150...
I have a dewalt 4 1/2", 120V angle grinder. I am breaking the thin cutting wheels when I use them very quickly or I pull out the stamped metal ring in the center of the cutoff wheel. The RPM rating...
If you are using these disks you need to apply very light pressure with the angle grinder and ensure you aren't putting any side pressure on the side of the disc.
Also imagine a line at a tangent to the disk. This should be kept at a shallow angle to the work piece to prevent the edge of the metal digging into the cutting disk.
As a rule of thumb you have the correct angle when the sparks are flying at less than 30 degrees back towards you.
Also make sure the retaining flange nut on the angle grinder is the correct way around to grip the disk, sometimes the nut has to be reversed to grip grinding discs.
Nov 24, 2010 | Dewalt Welding Tools
I have a brand new Grinder 230mm and now need to change the grinding disc however I cannot get the locking flange off - I have detroyed one spanner, and purchased a stronger one, but still no good. can...
Try turning it the opposite way. Instead of loosening it, you may be tightening it. Reverse threads on these machines are necessary to keep the flange from flying off by itself. Joe
Apr 12, 2010 | Black & Decker 9"/230MM 5,000 Rpm Large...
I borrowed a B&D 7750 3 to cut off the legs on a wire shelf system. I would like to replace the grinding disc but it appears to need a special tool to remove the disc. Is that correct? The owner says...
Yes you need an angle grinder spanner/wrench. It is like a tool with two pins that fit in the holes of the grinder disc securing nut. You can see a picture of one here: http://images.toolspot.co.uk/Angle%20Grinder%20Accessories/Angle%20Grinder%20Spanner%20For%20412in.jpg
They do come in different sizes, but you can also buy adjustable ones. Your best bet is to take the grinder to the local hardware store, big box outlet or anywhere power tools are sold and they should have a grinder spanner to suit your grinder.
Jul 03, 2009 | Black & Decker 7750 4 1/2'' Small Angle...
How to change a cutting disc.
You can download a manual for a 9" unit (9069S) from
http://www.materielsektionen.dk/skabelon/pdf/359.pdf
I know it's a Danish site, but the manual itself is multi-lingual and includes English.
Dec 03, 2008 | Makita 9069 9" Angle Grinder
Black & Decker 9"/230MM 5,000 Rpm Large Angle Grinder with 4 Hp Motor Logo
4,092 people viewed this question
Top Black & Decker Saws Experts
Craig Butler
Craig Butler
Ruben Bustamante
Are you a Black & Decker Saw Expert? Answer questions, earn points and help others
