Question about Pioneer GM-5200T Car Audio Amplifier
No bass at higher volume
I installed my system about 3 days ago. Its a Pioneer GM-5200T amp and a Sony Xplod 10" sub. It was working fine for the first 2 days then last night I was listening to a song and now I cant get any bass past 17 in the volume. I was Idle at the time while I was listening to the music when It cut out and It just hasent worked right after that. I checked the fuses they are ok. Anyone know whats up? Im not sure what the power rating is on my amp so could it be that my battery is not powerfull enough? Thanks for your time. Phil
    Problem Solver:
  • 13 Answers
Your battery should be fine! Although the amp might not be strong enough for the sub. All you can do is check the RCA cables from your radio to your amp as these might vibrate loose when you get to 17 volume and also check the monster cable from your amp to your sub asit might have vibrated loose as well.
Posted on Aug 15, 2007
SOURCE:
I got 2 1100 watt sony xplod subs powered off a 1000 watt sony xplod amp, everything works fine i just wanna make sure this will be ok and the amp or subs wont blow or fry.
you can blow a sub out when they are overpowered as well as underpowered. Distortion is the main reason thing go out. distortion occurs when you have the volume n the head unit up all the way and the gains on the amp are up all the way. always make sure the bass plays clear and you should be okay
Jun 14, 2010 | Car Audio & Video
Bass cut off when volume is too high
When an amplifier shuts the Bass off that means its going into protection mode otherwise it will burn out the outputs. One way is to turn your gains down, Pioneer amps are not the best amps for bass out there, they are more for car speakers, I personally wont use a pioneer amp to run my subwoofers especially if they are hard driven subs like JL , Kicker Solo's and MTX subs. But for now just turn the gains down to 3/4 and that should help u, you can also install a fan to keep your amp cooler, if this never happened before in 5 yrs and now it does then that means your amp is just tired and the inside components are overheating easily, thats common with Pioneer and Sony amps.
Good luck buddy.
Lex...
Jun 12, 2010 | Pioneer Car Amplifier GM-5100T - 2CH 760...
What amplifier should I use for 2 650W Subs?
HI DUDE .. I JUST GIVE suggestions Boss Car Audio D5504 "Diablo Series" 4-Channel Car Amplifier 2200 Watts ITS REALY GOOD FOR SOUND SYSTEM DUDEaaf1faf.jpg
Jun 10, 2009 | Pioneer GM-6300F Car Audio Amplifier
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Wiring
Usually an 800 watt peak sub would be a 400 watt rms. Hmmmm. Anyway, just bridge the amp (1x 380) nd keep the gain up enough to stay clean. Watch the sub and turn up gain until it starts to distort, then back it down a hair. Do this with the CD players volume up 2/3 to 3/4 volume with the BASS and treble at zero (bass better at minus 4 or so if you are a bass head! Hope thishelps.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 27, 2009 | Pioneer GM-5300T Car Audio Amplifier
Pioneer GM-5200T problem
i dont think transistors are bad . you should check the amp controlls they may need adjusting
Jan 20, 2009 | Pioneer GM-5200T Car Audio Amplifier
Sub woofers dont give clear sound on high volume
THE AMPS PERFORMCE IS DIRECTLY RELATED TO THE STATE OF THE BATTERY AND THE CONNECTION FROM THE AMP TO THE BATTERY, CONNECT THE AMP DIRECTLY TO THE BATTERY TO SEE IF THE SAME PROBLEM EXIST OUTSIDE THE CAR
Aug 28, 2008 | Pioneer GM-X924 Car Audio Amplifier
Need help
u should connect at least six 12" subwoofers (preferably 1000W each) to that pioneer amp of yours. Crank it up and enjoy. Your amp shouldn't cut off now. If it does cut off, you should change the fuse on your amp to a higher ampere.
Oct 30, 2007 | Pioneer GM-7200M Car Audio Amplifier
POWER
short in the system, or bad ground, or connections?
Oct 22, 2007 | Pioneer GM-5200T Car Audio Amplifier
Speakers cut off when bass goes up...
it might be that your wires from your amp to your subs are too thin. since they were relatively new the first three months, they were probably undamaged, but after pushing them too much, they probably have broken wires, and can't get enough power to the subs when turned up, i suggest getting thicker wires before investing in a capacitor, it could save you money.
Mar 21, 2007 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Pioneer GM-5200T Car Audio Amplifier Logo
123 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
