My laney aor series amp has completely stoped working, the valves are still glowing but no sound is coming out
  • Anonymous Apr 08, 2009
    hi...same prob i have tt50 combo 1x12.
    no sound...all tubes light up...and i had a repairman look at it.
    he couldnt find anything wrong ...except...lol...no sound...the fuses are good ...and were even replaced...cant find prob..any known issues? or something else to check?
  • 1,512 Answers
Hi.
Have you checked the HT fuse. the amp has 2 power supplies, one for the tube heaters, and another for the actual operation of the amp. Check that fuse, and replace with exactly the same type if blown. If it keeps blowing fuses, then you may well need to change your output tubes. They don't last forever, and you will get about 6 months out of them in normal gigging/rehearsal use, longer if you don't use the rig at high levels. Be sure also to use a proper speaker lead, not just an instrument patch lead, poor connectivity from anything that is not heavy duty can cause your amp to blow fuses, AND pop valves. I am happy to talk more to you about it, I have had a long love affair with valve amplifiers, both building and repairing them.
regards
robotek
Posted on Nov 09, 2008
Why do my laney 100 reverb combo lights come on but no sound?
First, plug your guitar and cable into a different amp to make sure the problem is the amp. Then check to see if you have output from any headphone jack or effects loop. If so your problem is in the power amp section. If not, it's likely the preamp section. Whichever section it is, it will most likely need to go to the shop.
May 21, 2016 | Laney Music
Maytag oven will not heat, no gas flow. Broiler works, clock and timer works.
You may even see the orange "glow plug" (called a hot surface igniter) glowing orange and so assume that it's OK. Not necessarily!! You have to measure the current/amp drawn by the igniter and compare it to this repair sheet before you can say it's OK or not. The gas valve has a bi-metal that open when a certain amount of current flows through it to heat it up. The igniter is wired in series with the gas valve. As the igniter gets older or weaker, it's resistance increases to the point where not enough current is flowing to the gas valve bimetal to open it up. As a result, the gas valve never opens up. BTW, a common symptom of the early stages of this problem is erratic temperature control in the oven due to delayed firing of the bake burner while cooking.
The hot surface igniter will not come on - check igniter with a ohm meter, you should have continuity through the glow bar, the glow bar can also crack = new igniter time. The glow bar comes on but the main burner will not light - you should have an amp probe to check properly, but often this is a hot surface igniter problem. The hot surface igniter often looses it's ability to get hot enough to open the gas safety valve. The safety valve can fail, but most times it is just a bad hot surface igniter. The hot surface igniter can also quit part way through cooking , in other words the oven may cycle a couple of times and then it just sits there with the red glow from the igniter. See this service sheet for the proper way and amp readings for the hot surface igniter system. Hot surface igniters do weaken and will eventually generate less heat than they normally could. When this happens they can still allow marginally correct current to flow to the oven gas valve for it to open but not get quite hot enough to ignite the gas burner immediately. When this happens, gas released into the oven can sometimes build up to the point where when finally ignited, the amount of gas lit can cause a small explosion inside the oven or cause an odor of gas with out the oven working. Yes, your glow bar igniter can glow orange-red and still be bad!! How a common gas valve works - click here.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 13, 2011 | Maytag Microwave Ovens
My Laney VS30 212 at band practice last week decided to intermittently cut out, but not fully just the volume would drop out then return about 5 mins later. Not sure if this was a common problem. It might...
Sounds like output valve, if the amp is more than few hundred hours then suspect this for sure. I don't know much about this amp specifically but does the sound fade/return suddenly or over a few seconds? Try running it with the back off and fan on the valves etc. Then play at loudness where problem occurs and see if any improvement. Remember that at band practice you always play much louder than you think and put a lot of stress on it.
May 03, 2011 | Laney VC30-212 VC Series 30 Watt Class A...
Hi,I just bought a Roland FS 1 footswitch.I have a Laney AOR 100 tube amp which takes a Laney FS 1 footswitch.I was hoping the Roland would work with my Laney but it doenst.I bought the Roland used as well...
OFTEN Roland has the opposite sense of normally closed contacts versus normally open. Test the switch with any continuity tester or an ohmmeter to see that the contacts work and come out to the switch. ALSO some amps require a TRS type connection (three wire plug) and others do not. From the schematic it appears that the Laney may REQUIRE a normally closed contact. There is also a pull switch involved that you MAY have to change the state of for operation of the pedal.
Here is the scheamtic for your amp:
http://elektrotanya.com/laney_aor100h_sch.jpg/download.html
Scroll down to the link at the page "Get Manual" and click to download. It is a JPG type file.
Apr 22, 2011 | Roland FS1 Footswitch Pedal Switch
I have an intermittent trouble with my Laney LV 100, intermittent crackling sound in sequence with the power light getting dimmer. this usually happen with high volume playing in chords. To describe more,...
clean all "vr" (variable resistors) like volume bass treb etc, sounds like bad contacts. this happens due time while they oxidating. maybe helps. use "contact" spray for best result
Feb 27, 2011 | Laney LV100 65 Watt 1X12 Guitar Combo
Kenmore series 500 gas dryer not heating up. model # 77542600 Other than the ignitor what could be the problem?
Check the coils on gas valve. If igniter glows bright & no CLICK sound heard after a few seconds of igniter glowing, coils are bad, or flame sensor if so equiped
Feb 13, 2011 | Kenmore 500 6952 Dryer
My Laney VC30 Guitar valve amps volume keepd fading in
CHANGE THE TUBES. ARITHEBASSPLAYER
Mar 25, 2009 | Music
My Kenmore 90 series dryer's pilot light is out. What can I do?
Modern Gas dryers do not have a pilot light. You CANNOT re-light them. They use a glow-bar or spark type igniter to ignite a flame. If you are having problems with ignition, the first thing to check would be if your igniter is working or not. Here's some useful information about igniters you should know and understand:
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
An easy way to determine if you may have an igniter problem is to check for a glow or listen for a clicking noise. The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad.
Please provide an accurate model number and I can assist you further. If you have questions, please post back and let me know. I hope you find this information helpful.
Feb 24, 2009 | Kenmore 63942 Dryer
227 people viewed this question
 Grubhead
Grubhead
