Question about Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP TV
System Board I Have samsung SP61 L3HX and its system board is not working. Can I find a new board The Model # HD3 SR V3.6 And Code # is BP41-00119B which is written on the board.Iam residing in Pakistan
SOURCE: samsung refrigerator sr-l628ev ,refrigerator not
I don't have a solution, but I have the same problem. Or rather I did until today when the freezer started defrosting itself too.
It sounds very similar to the RS21 problem that is on the watchdog website, but as my fridge/freezer is 8 years old I don't think they are going to give two hoots about repairing it foc.
Posted on Aug 24, 2008
javswr
  • 44 Answers
SOURCE: Samsung PS42C7S Power Board
A blinking led does point to a bad power supply board! First, Look for some bad caps (capacitors) on the board. They will look bulged on the top an may be a little leaky (brownish stain).
You should be able to find a service manual @ www.manualzone.com
Buying a power board try www.shopjimmy.com or ebay!
Good luck, hope this is helpful!!!
Posted on Mar 02, 2009
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
SOURCE: Samsung Cooltech fridge - type SR-52NXA - when
Yes, I had this problem. $85 visit from a very condescending repair man located a piece of old hard cheese that had become wedged in and stopped the thing from turning - the noise had been terrible. Fixed in 2 minutes - embarrassment lasted much longer.
Posted on Apr 06, 2010
futurework
  • 70 Answers
SOURCE: The system keeps saying protected and turning off,
I am unsure of where to find this board but try ebay. as of today a replacement unit is 139.00 plus shipping. The board can be repaired, The problem is most likely a bad transistor. In some cases components surrounding the transistor will go bad also. If you can solder remove the transistors one by one until the protect mode goes away. Read the numbers off the part and type them into a search and order replacements. install the replacements and check for good audio out. Hope this helps.
Posted on May 03, 2010
Samsung sr-l3426bs fridge not getting cold
you would need your fridge defrost sensor replace, check for ice build up within the vents of fridge section,
best to a tec to come and replace it for you,you would need the sensor to be reset on your fridge computer board
cheers
Nov 04, 2012 | Frigidaire FRS26R4A Side by Side...
Seiko lp1020 led head
Sir..,Not help for local dealears.,
So. pls ur help sir.,
SEIKO LP-1020 Model Machines
MEP Board (PCP) AFXY U00077354803 (Board arjent)
Account No pls send sr.,
waht price sr.,
Pls help sr.,
Aug 08, 2012 | Seiko Teriostar Lp1020 Printer / Copier /...
Getting sr error code
The Sr error code means that there is a stuck relay on your main board. Would request you to replace your pc board.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Unable to reinstall DVD backups after HP SYSTEM RECOVERY failed
Code "purple" means you and your computer are done. It is an unrecoverable error that means you need a new system. However, I have found a couple of postings that claim to know a fix. I can not verify these methods, I do not own a HP or other type of prefab PC (custom is the only way to go). Anyway, here are the links, good luck.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=6115
http://forums.techguy.org/windows-nt-2000-xp/469752-code-purple-configuration-error-hp.html
http://forums.techguy.org/all-other-software/644163-code-purple-advice.html
May 16, 2009 | HP Computers & Internet
Samsung inverter SH12VA1
standard is the pc board,propably the indoor,samsung has codes for the boards and put them with the remote control.call them and tell them the model to give you the code to rearrange the pc board.and its not to difficult to put the code with the remote control.
May 16, 2009 | Mitsubishi MS-A09WA Split System Air...
Samsung ht-q70
You can try fixing it yourself Front Board part # AH92-02494A FROM SEARS $45.27 + $10.99 S/H but it can happen again.
Jan 17, 2009 | Samsung HT-Q70 Home Theater System System
Region free DVD code for a Pioneer Avic-HD3
Me to if there is a way in doing so for AVIC-HD3
Dec 04, 2007 | Kenwood KVT-715DVD Car DVD Player
Samsung SR-L39 fridge freezer switching off
replace the thermostat of the freezer
Sep 16, 2007 | Refrigerators
Samsung model SR-L38NMB refrigerator
that problem very likely is the control board. there is another brand of fridge in S.AFRICA THAT DOES THE EXACT THING OF WHICH THE BOARD HAS TO BE CHANGED.
Mar 15, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Samsung SP46L6HXX/XEU 46" HDTV-Ready DLP TV Logo
54 people viewed this question
Henry  Thomas
Henry Thomas
