Question about SanDisk Sansa e250 MP3 Player
Won't turn on.
I tried to turn on my sansa and the blue wheel lighted up but the screen didnt turn on. When i connect it to my computer a box pops up saying i need to install driver software for my tango digital media platform.
Press the Power/Menu button during 15 minutes. As you can see, after 10 seconds the whell light will turn off (wait a couple of seconds after that before release the button). This will reset the configuration of the player. Then turn on the player normaly.
Posted on Nov 10, 2008
Blank screen
make sure the battery is fully charged, then disconnect from your computer. Wait a while for the device to cool and try turning it on again. Mine took a few tries but once it sat for a while it didnt fight me again.
Apr 02, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e260 only wheel light will turn on, screen remains black
you need to contact Sandisk and have them walk you through this problem, www.sandisk.com
Mar 24, 2009 | SanDisk Sansa e260 MP3 Player
Sansa MP3
Very hot = not good - replace the player
For laughs, Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jun 11, 2008 | SanDisk Sansa m240 MP3 Player
Sandisk sansa e250 blank screen
If you have a blank screen but the blue lighted ring is on. Remove the back, the battery, remove the 4 tiny screws. pop the front plate off. Carefully remove the circuit board from the case starting from the bottom. On the back of the circuit board you will find a smaller circuit board that is plugged in. This board sometime becomes partially unplugged do to rough handling. Press this board back into its socket carefully. Reassemble the unit and everything should be fine.I repaired 2 Sansa E280 unit from Woot grab bags with this method.
May 08, 2008 | SanDisk Sansa e250 MP3 Player
Sansa E250 Black screen lighted wheel, wont do nothing else.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e260 doesn't even turn on
Had the same problem, blue light no screen, took the cover off found a small black rectangle block not completely pushed in. the block is located on the right center on the part above the battery and right behind the screen.
Jan 12, 2008 | SanDisk Sansa e260 MP3 Player
This is the most ultimate and disasterous problem known to sansa users (me)
hellz yea Metallica kicks ass!!! o and 1 way to solve that problem is by hitting it on the ground.....i dont advise it cause its dumb but i had same prob with my screen and i hit it on the ground and it started working!
p.s. dont hit is real hard or youll jst mess it up worse
Jan 09, 2008 | SanDisk Sansa e260 MP3 Player
Sansa E260 Charging Problem
The battery may have become disconnected from the contacts, therefore it will not charge the battery but lights up when connected to the PC. Remove the 4 screws on the back, remove and re-seat the battery. Charge the device for a few hours. Best of Luck. p.s.- you can add to this question if this didnt help.
Oct 08, 2007 | SanDisk Sansa e260 MP3 Player
Sansa E260
-Tha Mp3 Doctor
Mar 25, 2007 | SanDisk Sansa e200 MP3 Player
Whattt is going on?
-Tha Mp3 Doctor
Feb 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
364 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
