Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Frost on Ice Maker shute
The freezer has an Ultra Ease II water filtration system. The ice maker has been accumulating frost at the opening of the shute at the bottom of the ice maker and at the opening of the shute on the door where the ice is supposed to come through. I am continually having to chip the frost (which turns to ice as well) off both the door and the ice maker. The temperature and humidity in the house hasnt changed much. The fridge is a year and a half old. Please advise.
  • 6 more comments
  • jerrylg Jan 27, 2008
    Whirlpool ED25CQ side by side started building up frost at icemaker exit chute and entry of door chute. Cleaned and removed frost . This morning it is frozen again. No other indications of frost in the freezer. Chute flapper door has a bit of spring tension (how much is needed?) and rubber gasket and mating o-ring are not damaged and are reasonably clean.
  • jenniferfall May 30, 2008
    Same problem here. It's the ice chute door. Doesn't close completely anymore. Air gets in and causes frost. Ice dispenser stopped working too. How do i reattach the ice chute door? That little flap? It's impossible to see in there to figure it out! Whirlpool customer service said i needed a tech. I should be able to reattach it myself, for crying out loud!
  • DEWCLAW22 Jul 16, 2008
    KENMORE MODEL 106-56984600 CHUTE DOOR ACCUMULATING FROST AS WELL AS OPENING CHUTE ON DOOOR. ITS JUST 2 YRS OLD.SEARS WILL NOT COVER ANYTHING WILL COST ABOUT $500 TO FIX IT. TOLD THEM TO SHOVE IT.SEARS DOES NOT BACK UP THEIR PRODUCT ANY MORE LAST TIME I WILL PURCHASE ANYTHING FROM THEM
  • betzos4 Jul 17, 2008
    same problem. I think I know what is wrong. the small door that closes off the shute from the outside is loose. Can't figure out how to get it back in the mechanism that closes it when the lever for ice is back to non ice dispensing postion.
  • NicoleLW Oct 27, 2008
    Slightly different Whirlpool model, but it's a 2006 Whirlpool Gold side-by-side with the ice storage in the door.
    Since we had Hurricane Ike come thru, the ice chute flap won't reclose resulting in the frost and leakage reported by others. We've taken a look and see how the chute is opened, but don't see how it is automatically closed (or rather how it should be closing) to fix the issue.
    Can another offer more details on what should cause the chute flap to close itself?
    Thanks, Nicole
  • Anonymous Mar 17, 2014
    frost on ice maker
  • Anonymous Mar 20, 2014
    ice maker where you putglass to get ice has a fixed black surround on outside that holds lever and door with a 5 inch hinge that holds it together snapped off is the black 2x3 pc fixed in permanent or can it be replaced it 2 years old
  • Anonymous Mar 21, 2014
    gasket keeps coming out or staying open in ice dispenser. How do we get it in properly
    President:
  • 878 Answers
Dtot, does the flap shut all the way? Sounds like you are drawing moisture from the chute. The flapper should seat so that no air is being drawn in. I have seen a number of these Whirlpools where the pin and spring retainer has broken off from the dispensor housing causing this problem. They use to replace the whole freezer door because the dispensor housing is not a servicable part. They have now come out with a kit to address this problem. This is not a fun job for a first timer. You may want to contact Whirlpool and inquire about the aforementioned. If this is your case, there is a good chance they will cover it. Catriver..post back.
Posted on Oct 21, 2006
I have a Sears model 106.57943700 and it was exhibiting the exact same symptoms. The ice chute door hinge was broken. Here's how I fixed it. Unplug Fridge!!! I carefully pried (a table knife worked good) the trim & ice/water selector unit (it has a connector plug on it that needs to be disconnected) from the door. Set it aside. Unclip the light / switch holder and tape it out of the way. Remove the ice chute door assembly along with the little round piston. Set it aside. Then I saw the broken plastic hinge piece that holds the hinge pin. Fortunately, the piece was still there. I super-glued it back together and put an additional bead of glue where it parted. Waited an hour and put it back together. WORKS FINE!! If you have limited mechanical abilities, you might want to seek help on this, but I fixed mine in about 15 mins. + 1 hr. glue drying time.
Posted on Sep 21, 2009
  • 3 Answers
Flapper closure was restricted by the top section of the rubber chute (next to the water dispenser outlet) which had warped. I trimmed off 1/4 inch of the warped section - flapper now closes completely. Problem resolved in 5 minutes.
r
Posted on Dec 04, 2012
I dont know if the repair guy is needed..will know soon. I ordered a kit for my kenmore 106.57943700 after getting advise from appliance specialist just ask or something like that..gave me the site..and they give free help. it looks like if you don't know the names of the two popular types of screwdrivers..call a repairman..but..it doesn't appear to look like engineer work..i'll let you know if i regret it.
Posted on Jul 23, 2010
Whirlpool side by side model# ed25qf- how do you get the drain pan out from underneath???????????
Posted on May 23, 2008
CALL THE REPAIR MAN TO 8002531301 TO GET THE RIGHT PERSON TO FIX YOUR ISSUE, SINCE YOU HAVE WARR, YOU WILL WANT TO USE IT OR YOU WILL LOOSE ALL OFYOUR WARR OVER DOING THINGS YOURSELF ON ANY OF YOUR APPLIENCE.
Posted on Oct 31, 2007
The freezer portion of the refrigerator accumulates an ice and frost build up in front of the ice maker and on the compartments on the inside of the door. We have tried removing the ice container and...
thanks for that help...now how do you fix the flapepr door. We had the same ice problem adn we are having problems w/ the ice flowing out through the flapper door. It gets stuck and you have to reach your hand up to push the ice out. Thanks!
Aug 17, 2010 | Whirlpool GS5SHAXN Side by Side...
ICE MAKER NOT WORKING WHIRLPOOL ULTRA EASE II
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
' 8798yuiy
Jun 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker icing up
Sounds like you may have a couple of problems here. The frost build up could be from a bad door seal. Moist air can be drawn in and collect on the inside. As for the water temp, it sounds like the water line connected to the refrigerator could be tapped off a hot water line. It needs to be connected to a potible cold water line.
Aug 26, 2009 | Kenmore Freezers
Bottom of ice maker is frosted up & leads to food getting frost
Sounds like your freezer is pulling outside air into the freezer from the dispenser door or around the door seals. This could be a defrost problem beginning as this is moisture remaining inside the freezer compartment and not being taken out during defrost. So it may be a good idea to look into the back of the freezer and see if there is frost forming also on the rear wall. If yes you will need to manually defrost by unplugging the refrigerator and removing the rear panel in the back of freezer to expose the evaporator coil. If frozen over I want you to defrost with a hair dryer until we can have a look at the defrost heater below these coils. The heater in your model PSS26MRSS has glass around the heating elements and will be easy to see if the element is burned out. If burned out the defrost heater part number WR51X10055 and the defrost thermostat part number WR50X10068 should be replaced. Let me know if you are ready to begin or if this is helpful. If by chance these 2 parts look OK then we will need to look over the main control board for burn marks or signs of heat damage. I'll be here if you need me Thanks, Sea Breeze
Aug 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frost on back of bottom freezer of a 3 year old kenmore
how long did you leave it unplugged? it's possible all the frost didn't defrost .you need to leave it unplugged and the doors open for at least 12 hrs.
May 20, 2009 | Kenmore 76283 Bottom Freezer Refrigerator
Excessive frost buildup in bottom freezer section of Kenmore refr
There are several reasons this can be happening...
1. The seal on the door may have a tear or may not be seating properly...this allows excess warm air into the freezer compartment and in its effort to remove the same ...frost appears.
2. There is something call a thermistor that is cycled on and off as needed to remove excess frost accumulation and or ice buildup on the evaporator (freezer) coils...it is a heat strip which actually defrost the frost/ice. if this is not working frost will accumulate and eventually it will become Ice......now the remarkable thing about Ice accumulation is that you would think everything would remain cold or get colder ..however in this case the opposite occurs...it insulates the coils and thereby increasing the temperature...put a thermometer...one that is calibrated properly...(calibration can be set by placing a thermometer into a glass of ice water...the temp of a glass of ice water..after a few minutes setting will be exactly 32 degrees)..if the temperature of your refrigerator is gradually rising over the period of a week...you will need to call a tech or replace the thermistor and or trouble shoot other problems that can occur such as..
3. The evaporator fan may be going out although they usually make a high pitched whining noise of a whirring noise before they go out...not always and if they are intermittently cycling off then frost would build up...do you always here a fan running when you open the freezer...if so that is good...fan is working...but it may be cycling off at times when no one is aware.
P.S. the odds of your ice maker causing this are very, very slim...in 35 years in the industry ..I have never had an ice maker cause frost due to water spray...it will almost always result solid sheets of Ice..if it evers does cause a spray....which like I said is rare...lottery ticket type rare :-)
This should lead you in the right direction...if you need help in finding a reputable service company in your area let us know..I hope this has been helpful..if so PLEASE rate me....thank you... .......The Fang
Mar 26, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Frost accumulation on ice maker
Normally the frost is taken away during defrost so if things get worse we need to look at the defrost timer.If freeze temps.begin to rise let me know, Thanks JT
Oct 24, 2007 | Frigidaire FRS26KF5C Side by Side...
Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Aug 27, 2007 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
5,548 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
