Question about SI-TEX ColorMax 6 GPS Receiver
SiTex Color Max 6
I turn on the GPS and the map shows up but ic an not input data or register where I am. The screen says no signal.
Navigation map do not show up, next turn etc. Also show message "no map info".
My problem was cured by reformatting the Mini SD card that holds the map data. I had the same problem this week with my Garmin Nuvi 265. After doing an update I received the "No Data Available" message when trying to use my GPS. After trying three days of so-called fixes I remembered that, at least in my case, the map is stored on a Mini SD card. I pulled the card from my Nuvi and popped it into the computer to see what's on there. There are 4 or 5 files associated with the map. I deleted the files and reformated the Mini SD card using the FAT32 setting. I reinistalled the card into my GPS. Prior to connecting the GPS to my PC, I uploaded the latest version of Garmin Express. Once that was loaded I reconnected the GPS and had to re-register the unit. Once that was done the software told me that there was a new update. I ran the update. Lo and behold . . . after about 25 minutes the map was successfully loaded to my Nuvi and it was working as it should.
Mar 20, 2016 | Garmin nuvi 50 Travel Assistant
My gps freezes when on speedo
Okay. I have to explain what happens when you use the speedometer option. While it is off, the GPS use using less cycles per minute to get the location from the satellites and sometime from ground beacons. When in speedo mode, it now needs more processor, memory, graphics speed and the power needed for the receiver. Now the unit is running about twice the cycles per minute to provide an accurate location to judge your speed.
How to work around this.
Best answer: Dont use this option! Its simple and you dont have to burn your noodle worrying about it.
2. If you must use it, then go into your display and map options and turn the map details and quality down. This will free up memory and CPU speed.
3. Turn tracking off. This will free up memory and CPU speed.
4. Use Garmin's mapping program to only load necessary map locations.This will free up memory space.
5. Be sure you are updated to the latest map data and firmware.
6. This can also be caused by the location of the GPS in the vehicle. On the main screen of most Garmin's, you press and hold on the corner near the icon showing the GPS signal. It will go to a more detailed screen of the satellites and signal strength. Stay in one place in an open area like a parking lot. Let the GPS locate itself first. Then relocate it where you can easily see it and you see 40% of signal or more from 4 or more satellites.
Have fun with what I gave you and good luck. VicFixx
Oct 27, 2014 | Garmin nuvi 1250 Car GPS Receiver
My garmin1250 keeps freezing when it is on speedo . how do I stop it from doing this
Oct 27, 2014 | Garmin nuvi GPS
Scepter flat screen input problem
It sounds that the input signal selection IC is faulty. This IC is at the main board, and will be very difficult to replace to an inexperienced person. Contact any service technician.
Jun 24, 2013 | Sceptre Televison & Video
No problem. just trying to download updates. 1 year
Garmin periodically releases updated maps for its GPSdevices. The my Garmin website offers convenient access for managing yourGarmin devices and finding the map updates you need. Garmin offers threeoptions for map updates: free download, single-purchase download or lifetimesubscription. Regardless of which option you choose, the process to downloadmap updates to your Garmin is the same.TOOLSAND INTRUCTION NEEDED TO SOLVE THE PROBLEM1 Connect your Garmin GPS to your computer. Locate theUSB ports on your computer and on your GPS. The GPS ports are typically on theback of the device and may be hidden by a protective cover or rubber cap. Plugone end of the USB cable into your computer and plug the other end of the USBcable into your GPS. Power on the GPS.2 Sign in to my Garmin(see Resources) with your username and password. If you do not have an account,click the Create New Account link to register your Garmin devices.3 Click the my Maps tab to display a list of yourregistered devices and their associated maps. Click the Map Downloads link todisplay a list of available map updates for your devices. Select PC Download orMac Download link.4 If you are alerted to run the Garmin CommunicatorPlug in, click Run. When the Plug in has detected your GPS and is ready todownload the map update, click the Launch Download Manager button.5 At the Save As prompt to save the map update, notethe location or select a new location to save the file. Click the Save button.6 When the Map Update file has finished downloading,click the Launch button.7 At the "Welcome to the Garmin Map Update"screen, click Next.8 After the Map Update USB Driver Check finishes, clickNext.9 Follow any instructions on the Map Update SuccessfulInstallation screen. Click Next.10 At the Software Data and License Agreement screen,select the checkbox to accept the agreement. Click Next.11 After the update installation finishes, click Finishto exit the program.12 Disconnect your GPS from your computer.Thanks.
Sep 18, 2011 | Garmin nuvi 255W GPS Receiver
My garmin 1300 says no map data available and will not navigate anywhere.
Your map file may be corrupt. You can go to the Garmin website where you registered your unit, and download the same map. If you want to update to a newer map you can do that as well. To ensure that you have the correct map you will have to register your unit if you haven't already done so. Go to the following link:
https://my.garmin.com/mygarmin/customers/myGarminHome.faces
You will have to first make sure that your GPS is attached to your computer with the black USB cable that came with your unit. Plug the smaller end into the back of the unit and the larger end into one of your USB ports. The GPS will automatically power on. You will see a graphic on the bottom of your screen that looks like a GPS connected to a computer. A line will appear halfway up the screen which will start as a white line and then change to a green one. Once that is done you can register at the above site. The website will attempt to connect to your GPS so that it can read your model and serial numbers. It will then show you which maps are available for you.
Mar 13, 2011 | Garmin nuvi 1300 Car GPS Receiver
My 1300 doesnt seem to calculate trip data such as time or average speed, miles, etc. stays on zero. does show max speed.
is it set in similation mode?? try reset by holding down finger on bottom right hand corner of screen before you power up, and go to www.garmin.com for software update
Dec 01, 2009 | Garmin nuvi 1300 Car GPS Receiver
I have recently bought this sat nav and would like to register it as it keeps asking me if i agree when i turnit on
Your Garmin nuvi will continue to show the warning screen after you turn it on even after you register it. It's kind of like the warnings on cigarette packets. You'll get used to it though and it wont bother you after a while.
If you haven't done so yet, go to www.my.garmin.com and register your new gps. You must register it within 60 days of aquiring the first satellite signals in order to be eligible for a free map update. And by the way, you don't have to press 'Agree' each time the warning appears, it will disappear on its own.
Aug 05, 2009 | Garmin nuvi 255W GPS Receiver
Cannot find my map data anymore
Have you checked the wrench menu, map info, the preinstalled map should have a check mark, if not tap on the check box, it should now show a detailed map screen when you go back to the main menu and select show map.
May 03, 2008 | Garmin nuvi 350 GPS Receiver
SI-TEX MAX 10 NT
Yes, they are. Call SITEX 727-576-5995 x139
Oct 05, 2007 | SI-TEX MAX10 NT GPS Receiver
SI-TEX ColorMax 6 GPS Receiver Logo
55 people viewed this question
Top SI-TEX GPS Experts
Will Halftowaite
Are you a SI-TEX GPS Expert? Answer questions, earn points and help others
