The single usb port does not seem to work at all. if i use a four point hub with a nano wireless mouse it fails after 5/10 mins
Based on the information you have provided, it seems that the issue might be Hardware related.
All the USB Ports use a common driver. As all the other ports are working fine, its clear that the issue is not with the USB Driver.
It very much looks like the port which you have mentioned above is faultly.
Hence, it would be better to contact the authorized service center to have a detailed check on the Computer.
Please feel free to contact for further assistance.
Hope this helps.
If you unplugged ANY usb-devices without safe-mode you probably fried your usb-port sooner or later.....
SOURCE: toshiba satelite laptop mouse not working
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
So in regards to the touchpad, it’s not working. Device
Manager is where you want to go to see if something is wrong with it. You know
also, I'm not sure if any other Toshiba has this built in it. Like on some HP,
they have a button just to the top of the touchpad. If you hit it, it turns off
the touchpad. Hit it again, its back on.
I’m pretty it doesn’t. If the button is not there,
then it might be just your touchpad is dead or loose cable on the inside.
Let me know
comier957
SOURCE: CL51-15 USB Port Problem
I was hoping you can help me out guys, i have this laptop acer travelmate 290 and everything seem to be working properly. All the drivers and devices are installed and working fine(Audio, Display, Network, Wireless, PCMCIA......) except my 2 USB port. I tried almost all devices on it but nothing works and cannot be detected at all ( mouse, keyboard, cam, printer etc...) Device manager say's my usb port is working properly and has no conflict at all.
OS : Windows XP Pro /SP3
USB Controllers
USB: Intel(R) 82801DB/DBM USB 2.0 Enhanced Host Controller - 24cd
- ...... 24c2
- ...... 24c4
- ...... 24c7
- USB Root Hub.....
Everytime i plug something on the USB port i dont see any respond at all, like new usb device was found or somethin message pop up on the lower left on my screen. Nothing at all.
Hope you can help me out guys
SOURCE: Configfree problem in Toshiba L300
go to network connections and look for the wireless connection and start it that way
SOURCE: my acer 5532 touchpad has suddenly stopped
sounds like the driver is missing or has become corrupted.
try a new mouse with the enclosed software.
SOURCE: replacing keyboard on Toshiba Satelite L300
I'm assuming you've already managed to lift the keyboard to expose the cable and ribbon connector on the motherboard.
As you can see the ribbon looks as though it just slot into what looks like a rectangular block.
The top and rear of the connector block is one piece and needs to be CAREFULLY lifted, it only comes up and eight of an inch or so. This releases the ribbon. The block stays in situ.
Here's a Youtube video which shows a similar connector :-
http://www.youtube.com/watch?v=GcM9knr_P4Q
It may be the same as yours,
Here's another youtube clip describing the kind of connector I tried abover.
http://www.youtube.com/watch?v=l2ii1PIHaCM&feature=fvw
