Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
2003 883 sportster wont start
Ran great last ride bike sat a few days went to ride it and while cranking would misfire.never started acted as if flooded.checked spark looks ok.eventually i got the bike started ran a bit rough so i filled the bike with fresh gas and added some b12.next day bike started and ran great.2 days later right back to not starting.cleaned carb drained tank still cant get it to run,it tries to start .dont know if its carb or electrical please advise.
thanks scott benton
  • 216 Answers
What u are describing is typical of a faulty ignition system, but could also be a fuel problem. I check by removing the aircleaner and rotating the throttle. If u see a nice spray of fuel, thats probably not the problem. Check for a spark at the plugs. I can explain how if you need me to. If you cant see a good spark, U have an electrical problem. I had a crank position sensor go bad on me. Dont do what I did (replaced the battery, ignition, and regulator as part of my diagnosis procedure)
Posted on Nov 08, 2008
Have a 99 Frontier 3.3. Started running real rough, bucking and jerking. Didn't idle. Hard to start when warm.
I have seen a few crank sensors do this. When I pulled them, they had a small crack in them. Don't know where yours is. But guessing under the harmonic balancer.
Dec 02, 2015 | Cars & Trucks
96 ford bronco cranks over but no start.sat a few days and started.then didn't start next day.layer that night started and ran great.parked and went into store .came out and truck no start
Distributer module sounds like the problem. Ford had a unique way of letting you know the module was about to quit, the car would start intermittently for a few days. After that it would completely fail and never start again. Other makers cars just croke right then and there. New distributer module is a very easy repair it can be done in just a few minutes, and they aren't that expensive.
Sep 27, 2015 | Ford Cars & Trucks
CAR WONT START
CKP sensor or cam sensor. one goes bad and causes other to go bad. easy fix and not too expensive.
Mar 13, 2014 | 1999 BMW 318 ti
Pulled the choke bike wont start
Usually if you flood it (by overchoking), you open the throttle wide open (to draw in more air to lean the mixture) while cranking starter.
Beings you had the spark plugs out you could have cranked it then, and let the engine compression blow the excess gas out the spark plug holes.
Jan 12, 2014 | 1990 kawasaki VN 750 Vulcan
Fuel injected sportster ran out of gas and now wont start, i do not hear the fuel pump running either
Hi Anonymous, I'm sorry but I just loaned my listening ears to the lead technician at your local Harley Dealer so he could take your bike for a test ride and evaluate the noise. Have a nice day.
Feb 16, 2013 | 2007 Harley Davidson XL 883 Sportster
2001 nomad, has power commander, vance and hinse exhaust and hyper charger. Bike starts but miss fires. Bike seems to run better uphill then down hill. It started on day on a ride when the bike just died...
DRAIN CARBS FROM PETCOCK AT BOTTOM OF EACH CARB MAKE SURE FUEL DRAINS COMPLETELY THEN TURN FUEL BACK ON, IF THIS IS AN INJECTED MODEL DRAIN TANK AND FLUSH THEN RUN IT HARD FOR 20 MILES OR SO, MAKE SURE YOUR OIL LEVEL IS OK
Oct 04, 2009 | 2001 kawasaki VN 1500 Vulcan Classic...
1979 F250 460 Dying suddenly, choke stuck?
There is a control module on inner fender well under hood,natorious for causing this type problem,ussualy on drivers side.
Jun 18, 2009 | 1988 Ford F 250
Lands Phones Logo
323 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
