Question about O2 XDA Mini S Smartphone
Ipaq hx2490 align screen
Cant get off my align screen,it lets me press the targets but keeps making me do it over and over
    New Friend:
  • 58 Answers
It is because you have a problem with your digitizer. it is the upper layer of your LCD screen or it is commonly called as the touchscreen module. I would recommend you to bring that to a service center and have the digitizer/touchscreen module replaced. I hope that I have helped you in your problem. Good day.
Posted on Aug 29, 2009
I cannot get past the align screen page is there a way of bypassing it?
If it just keeps asking you to calibrate, then that means the touch screen is faulty.
Oct 24, 2009 | HP iPAQ RZ1710 Pocket PC
When I connet the Ipaq 2490, teh screen lights up
press & hold power, press & hold calender, press & hold mail, press & hold reset small hole at base of unit, screen will blank, device will now hard reset.
Oct 13, 2009 | HP iPAQ HX2490 Pocket PC
Align screen on IPAQ
Tap the target firmly and accurately at each location on the screen.The target will continue to move until the screen is aligned,
pls help.what can i do.
Jul 23, 2009 | Compaq iPAQ H3955 Pocket PC
Replacing a broken screen on a HP ipaq 2410
video on yube to open ipaq same kind of procedure
Mar 17, 2009 | HP iPAQ HX2490 Pocket PC
HP iPAQ 2490B can not be hard reset
remember that you must hold down the two buttoms at the same time then push in the reset for 2 sec (holding it in). release the 2 buttoms then remove the stylus for the reset port. after about 4 sec press & release the reset buttom again, sytem will pwr up. If this doesn't resolve the issue then try the clean reset but bear in mind u will loss any thing u installed on the ipaq as system go to default setting and u will be required to align the screen. good luck
Mar 07, 2009 | HP iPAQ HX2490 Pocket PC
Screen is frozen at the ''align screen''. The battery is fully charged. I have used the reset button many times without results. I have removed the battery and then replaced it with no change in the frozen...
I posted a solution for this problem just using your finger to align at first then use the stylus, at any point where target doesn't respond use ur finger.
Mar 02, 2009 | HP iPAQ HX2490 Pocket PC
When i do hard reset hx2490b screen calibration does not appear
Try using your finger to calibrate the screen at first. (If you have difficult to navigate to the alignment screen use the stylus & keyboard to feel out your way) when calibrated to an accepable degree use the stylus to calibrate the sreen, if the target doesn't respond to stylus at any specific piont use your finger. Continue this process till u get it aligned as best as possible. I suspect this problem is caused by specific points on the screen going bad.
Feb 24, 2009 | HP iPAQ HX2490 Pocket PC
How to hard reset hx2490b
Recovery Procedure for HP iPAQ hx2750, hx2490, and hx2790 Pocket PC Series:
To perform a Hard Reset on the iPAQ Pocket PC by pressing and holding the Calendar and iTask buttons (1 and 4).
2. While holding down the Calendar and iTask buttons, use the stylus to lightly press and hold the Reset button, which is located at the bottom of the iPAQ Pocket PC, for approximately two seconds.
3.. Release all buttons.
4.. Connect AC power to the iPAQ Pocket PC. The handheld Powers On,
performs the normal boot sequence, and automatically restarts system.
Oct 30, 2008 | HP iPAQ HX2490 Pocket PC
HP Ipaq 2410 screen alignment
relic, what good is this device?
why not ask HP , where if lucky , some one there can even remember that long ago.
its 14 years old. has zero value , seen in garage sales for $1
and no buyers.
why you? sorry but what good is it?> there is no service now.
my advice? is to dump this and buy a used real cell phone for $5
and work on that, work on something with a future and not this device IPAQ anything.
now here is real HP , this is not spam nor jackers or the like,
its the REAL DEAL, the maker of you DEVICE.
HP
https://h30434.www3.hp.com/
Nov 26, 2017 | HP iPAQ HX2490 Pocket PC
HP Ipaq hx2490
hi,
thats no problem, i got one of these little babys.
Nice piece of kit.
Underneath, small hole on the side by the Battery.
Use your stylus, push button. Hard-Reset.
Let me know if this Works, ****Before you rate this Solution****
Mike @ compurepair.
Feb 28, 2008 | HP iPAQ HX2490 Pocket PC
O2 XDA Mini S Smartphone Logo
130 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
