Question about Refrigerators
My fridge is a hotpoint frost free. its still operating but too hot. fan comes on behind freezer part but not all the time?? temp fluctuates between -5 and -10 in freezer and is way too hot in fridge. (30) unit has some frost bulid up on it. please help!
  • 4 more comments
  • lamps28 Nov 08, 2008
    but is the fan meant to be on all the time anyhow?
    and i have no idea where to get the replacememnt parts, or indeed how to rpleace them. solenoid?? dont even know where it is?
    ok, thanks.
    but.......the fan does apperat to work, just not all the time. could the problem lie elsewhere.
    i just dont want to replace the fan for the same to happen.
    i cant find any defost timer, i have an electronic readout of temp whicj i can adjust for the refrigerator section to range from 0- 6. this has no effect on my problem
    MY FRIDGE WORKS, JUST NOT AS IT SHOULD.
    i know how to clean it!!!!!
    i dont know how to repair it!!!!
    THE FREEZER PART COOLS TO -15, THEN STOPS, THE FRIDGE PART DOES NOT COOL. HELPPPPPPPPPPPPP
    no door leaks.
    ok, defrost problem? how do i fix it?
    i dont have a 'cold control'
    Master:
    Sergeant:
  • 449 Answers
Hi!!!
find the termostat
may your termostat in not working
or replaced it
Posted on Nov 08, 2008
  • 83 Answers
You don't need to manually defrost your self-defrosting refrigerator/freezer. Every 6 to 8 hours, it heats up its cooling coils slightly and melts any frost accumulation on the coils. The resulting water drains into a shallow pan at the bottom of the refrigerator/freezer.
There's no need to empty the pan. The water in it will evaporate. But it may begin to smell bad over time. You may be able to remove it for periodic cleaning by detaching the lower grill and sliding the pan out the front of the refrigerator/freezer.
Note… When mold grows in the drain pan, it is sometimes considered to be a health concern. If your drain pan is removable, and if you're sensitive to mold, consider cleaning the drain pan periodically.
Under your refrigerator/freezer is a set of coils and a cooling fan that you need to clean at least once a year. The coils may look like a grate or like a wide radiator. Unplug the refrigerator/freezer and use a Refrigerator Condenser Brush (available in the accessories section of our website), and your vacuum cleaner to clean any lint, pet hair, and so on from the coils.
If the gasket or interior of the refrigerator/freezer needs cleaning, try Refrigerator Cleaner to clean the surfaces. You can find this useful product in our accessories section
  • rush2robby
    rush2robby Nov 08, 2008
    find all information as you want for your refrigerator (parts, service manual, user manual and all)---
    http://www.repairclinic.com/0047_4.asp
    Genius:
  • 1,447 Answers
Hi
If the refrigerator's light works and you can hear it running, but it cools poorly or runs without stopping, make sure nothing is blocking the passageway between the freezer and refrigerator compartments. If airflow is restricted by, for example, a loaf of bread situated in front of the passageway, the refrigerator won't get cold. Be aware that a refrigerator will tend to run longer when it's full of food, the door is opened frequently, or the room temperature is hot.
If your refrigerator runs without stopping, it may be low on refrigerant. Without a full charge, it cannot reach the low temperature that the cold control dial summons. More likely, it is a defrost problem in which a component in the automatic defrosting system is faulty. This could be a defrost heater, a defrost timer, or a defrost terminator.
Before you call a repairperson, do the following:
1) Determine whether the refrigerator section is being cooled. If you see frost at the top of a "frost-free" refrigerator even when the cold control is set low, it means the refrigerator probably has a full charge of refrigerant. If this is the case, the thermostat may be faulty or out of calibration.
2) Try turning the cold control both up and down. If the compressor doesn't shut off, the cold control may be broken. Call a repairperson. During the repair, it is a good idea to have the defrost timer and heaters checked to ensure they are working correctly.
3) Look at the condenser coils, located at the bottom of the refrigerator (behind the kick plate) or, in some cases, at the back. These coils disperse heat from inside the refrigerator out into the room with the aid of a fan. If the coils are dirty, the refrigerator won't operate efficiently. You must clean them regularly.
4) Make sure the drain line under the evaporator coils, which goes to a pan underneath, is not plugged up (water should drip into the pan when the refrigerator is defrosting).
5) To put off having the refrigerator repaired for a few days, you may be able to defrost it manually with a hair dryer—if you can access the cooling coils in the freezer section. Excessive moisture in the coils can turn into a frozen mass, reducing efficiency. Be very careful when using the hair dryer, and do not stand in a puddle of water; there is a serious risk of electrical shock. Also be careful not to melt the plastic parts.
Hope this helps
  • 2 more comments
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Nov 08, 2008
    Hi
    Check on the defrost timer as well. On some refrigerators, you
    can manually advance the defrost timer, a small black box that may be
    located almost anywhere but is usually on the ceiling of the fresh food
    section. Advance it until it clicks into the defrost mode (you should
    be able to hear the heaters come on).
    If this works, the defrost
    timer is defective and will need to be replaced, but this action will
    keep it running for a little while. If this technique doesn't work, the
    problem is probably the heater or the terminator. Call the manufacturer
    for advice.
    Thanks for using Fixya!!
    clean condenser coils on
    forced-air refrigerators, such as side-by-side and built-in models, at
    least twice a year. (If you have a refrigerator with the black coils
    mounted on the back, these coils don't require semiannual cleaning.)
    Here's how to do it:
    1) Pull the refrigerator away from the wall, and unplug it. Or, if it's a built-in model, turn off its circuit breaker.
    2) Remove the cover panel
    to reveal the coils. On most models, the kick plate or top trim plate
    simply lifts off. You may have to remove a few screws to remove a back
    cover.
    3) With a long, narrow nozzle on your
    vacuum, clean out all of the dust and debris. (At an appliance parts
    store, you can buy a special long-handled brush that looks somewhat
    like a bottle brush for this job.)
    4) Replace the cover, and then plug the electrical cord back in or turn the circuit back on.
    If all fails contact a repair person
    ) Check the cold control.
    Be sure it is set to "cold." Normally, the temperature inside the
    refrigerator should be about 37 degrees Fahrenheit.
    2)
    Listen for the freezer fan inside the freezer. When the freezer fan is
    running, it means the defrost timer and the cold control in the
    refrigerator are both set to cool.
    3) Listen for
    the compressor fan, where the compressor is located (typically behind
    or beneath the refrigerator. When the freezer fan is operating, the
    compressor fan should also be working (most of the time).
    4) If one of the fans is not working or the compressor is off, the refrigerator will offer very little cooling or none at all.
    keep us posted
    can you hear the two fans working? the freezer fan and the compressor fan?
    factors:
    Normally, the defrost
    timer automatically cycles the refrigerator to defrost for about 20
    minutes every 6 to 8 hours—it essentially heats up coils to melt the
    ice. If it isn't working right, ice remains on the tubing and,
    eventually, restricts airflow through the refrigerator.
    Genius:
  • 1,550 Answers
The condenser fan motor and its blade can develop problems.
Check to ensure it is operating and at full speed, whenever the compressor is running.
  • 1 more comment
  • SAM ANDERSON Nov 08, 2008
    You can get replacement parts from the link below
    Hotpoint parts
    Check your door for air leak.
    There is also chance you have trouble with defrost circuit .
    You can get information about defrost circuit from the link below
    Defrost
  • Refrigerators Master
  • 19,396 Answers
If the fan behind the freezer is operating erratically, replace the fan or the solenoid that activates the fan.
The fan is part of the defrost system, when it is defective, the fridge wont produce enough cool.
  • Ginko
    Ginko Nov 08, 2008
    In your case the fridge is obviously not cooling because of a problem with the evaporator coil.
    Replace the fan.
    You find schematics and replacement parts here.
    On this problem see also : Cooling is poor
  • Ginko
    Ginko Nov 08, 2008
    I told youy, if you get ice in the coil at the back of the fridge, that means that the defrost system is not working properly.
    The fan it is not supposed to run all the time, but if cooling is poor, and you see the coils at the back are freezing, then there is a problem with the defrost system, and the fan it is part of this.
    As an user, the only thing you can do is defrosting thoroughly the fridge, leaving it umplugged overnight.
    If after restarting, in one or two day, youy get the problem again, then the defrost system (fan, heating element, etc) has a problem.
    From here onward you can proceed in two ways.
    1, you have some background and experience in repairing appliance.
    In this case use the information given, and the schematics that you find here schematics and replacement parts here.
    2 You never attempted disassembling a fridge and repairing parts before:
    In this case ring the phone number listed on the user manual, report our advice, and ask them a quote for repair.
    This can still save you some money, since you know what the problem is already, and you can ask a quote for the specific repair.
I have a frost free hotpoint and theres ice on the freezer door and the food inside it what could this be and how,do i fix it
Hallo
Frost free means there is an evaporater coil behind the backplate of the inside of your fridge.
How it works is a fan is for example installed in the lower back of your fridge and the evaporater above the fan covered by a plastic cover/steel plate and now the fan is pulling the warm air from the top over the evaporater ( the evaporater is then pulling the warm air into the evaporater without increasing the temperature of the evaporater) and dehumidify at the same time and blowing the cold air out a the bottom of the backplate while the warm air moving to the top where it could repeatedly repeat this action.
Tell me what is the condition of your freezers door seal? It can only be caused by humidity getting in so it mean the door is not sealing 100%.
Regards
Jun 09, 2016 | Hotpoint Refrigerators
How to fix a hotpoint frost free fridge freezer
I would call a repairman . possibly the fan has worked loose on the motor shaft
Oct 08, 2015 | Total Micro HDP80CF72-PAN 80Gb Notebook...
My F&P FROST FREE fridge/freezer will not get cold
try having a hvac technition come and recharge the freeon
Feb 19, 2014 | Nissan Maxima Cars & Trucks
My GE fridge PSi23SGNA BS freezer defrosted.
Condenser fan should be about 1300 rpm, I believe!
Jun 13, 2012 | GE Refrigerators
My hotpoint frost free, fridge compartment keeps collecting water at the bottom of the fridge. I've checked drain hole is clear of any bits. The temperature strip in fridge is constantly black and ...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 14, 2011 | Hotpoint FFA60 Bottom Freezer Refrigerator
Got a hotpoint ffa97, freezer was still cold and no alarm had gone off to say that that there had been a power cut yet the fridge temp had risen enough to curdle milk??\r\ntemp gauge was still showing...
Milk can sometimes curdle in a working fridge. But it does sound like your defrost system may be malfunctioning. Can you empty your freezer and inspect the defrost system behind the air circulator fan?
I know that defrost elements sometimes go bad and the controllers can pop too. You should check your operators manual and see how to put the fridge into manual defrost. *(it usually involves turning the fridge light on and off by hand. See if the freezer drains during manual defrost. If you have lots of food that dries out in a frost free unit the moisture contains a lot of contaminants that can plug the defrost drain. Which leads to a blocked air passage between the freezer and fridge sides.
You might want to get a small backup fridge for a while to run this down.
Or just use up the food in your fridge before running the tests.
Good luck and be careful.
Jun 28, 2010 | Hotpoint Refrigerators
My hotpoint ff187e fridge is not cold, the freezer is working but getting a build up of ice which i have defrosted. tried turning off. when i open the fridge does not feel cold,not sure if the fan is...
we had same problem,apparently there is no such thing as a frost free fridge/freezer, you have to turn your appliance off for at least 3 days because the freezer has a build up of ice which stops the fridge from working, you must leave it switched off for this time otherwise it will just ice up again.
Nov 09, 2009 | Jenn-Air JCD2389G Side by Side...
Hi i have a hotpoint mistral plus fridge freezer, the freezer working fine however the fridge not getting cold, i have checked in back and the fan not working, have checked the fuse that is fine. 1) Does...
hi is this the frost free version ??? if it is which i think it is it could be a fault with temp module{frost free have electronic modules to control the system rather than a old fashioned bog standard thermostat inside the fridge} the fans should be controlled by the module in case of frost free models it could be the module which is playing up
Jul 23, 2009 | Refrigerators
Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Feb 21, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator warm, frost in freezer
take back panel off freezer and check for ice build up which will block air flow and temps will rise. melt off carefully with a hairdryer.make sure drain is also clear and use hot water and patience if blocked with ice. if fault re-occurs, you have a fault with defrost system
Apr 24, 2007 | Hotpoint 21.7 cu. ft. Side-by-Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
