Question about Dell Dimension 9150 (DIM915MIN) PC Desktop
Dell Dimension 9150 PC Desktop _ Eytor Sigurbergsson
"Dead" constant yellow blinking in the powerbutton and the diodes on the network innlet are blinking to.  Otherwice no life at all. Prior to this I had problem with one of the USB innlets at he rear. possible shortcut in the cable. brg. Eytor
  • eytor Nov 08, 2008
    Tx i found a shortcut in the USB inlet wich I had overlooked. Now its working again :-)
  • Dell Master
  • 998 Answers
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged. Here’s a link to the service manual for your model: http://support.dell.com/support/edocs/systems/dim9150/en/sm/adtshoot.htm#wp1054146
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 08, 2008
Good video, no sound with my dell dimension 9150
You can try to get the drivers off of your CD or you can download the drivers from here:
http://www.dell.com/support/drivers/us/en/19
1. Just choose "Select A Different Product"
2. Then choose "No, Choose from a list of all Dell products" and
select "continue"
3. Then select "Desktops"
4. Then select "Dimension"
5. Then select "Dimension 9150/XPS 400"
6. Now just scroll down and pick the drivers you need.
Don't forget to install your chipset and network drivers as well.
Jun 04, 2012 | Dell Dimension 9150 (DIM915MIN) PC Desktop
I can't find Ethernet Controler for Dimension 9150 Service Tag DB22PY81
You can find all drivers for your 9150 here.
The Intel driver for your built-in network card depends on your OS (WinXP or Vista).
(Your service tag might be outdated, so it doesn't work.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 27, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Error when starting Dell Dimension 9150 desktop PC: X300XT BIOS P/N 113-A33437-102
go to www.dell.com and check for a bios update if one is not present contact support and tell them your problem
May 31, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
My Dell Dimension desktop 9150 was running very slow so I shut down the computer. When I pressed the power on button I notice that it was flashing. I pressed the button even holding the power button in...
the constant Green, states that the motherboard is getting Power.
The red/yellow would possibly suggest, that the ethernet port has a fault or possible corruption.
Solution:- remove the Power Lead from the Computer Case.
Remove side panel. take out any ethernet-Cable from the rear.
Locate the CMOS battery, round silver Battery on The motherboard.
For 10 seconds, this should reset The bios, to it,s original Default Settings. Replace Battery, side Panel. And power Lead.
You could also try This. Boot with Hard-drive power Cable Disconnected ( this will Eliminate HD Fault ) same for CD/DVD drive et,c.
Mike @ Compurepair.
Oct 22, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
My Dell Dimension 9150 will not turn on
Use your CD to boot up the computer and recover your operating system
May 05, 2009 | Dell Dimension 9150 (DIM915MIN) PC Desktop
Can't find ethernet port
is this the 400/9150 viewable at the below address? http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=FBT5D91&SystemID=XPS/Dimension%20400/9150&os=WW1&osl=EN
if so, i actually used to have one! The network port is on the rear of the case, as you can see as number 4 on this image:
http://support.dell.com/support/edocs/systems/xps400/sm/about2.jpg
Nov 28, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Dell Dimension 9150 (DIM915MIN) PC Desktop Logo
366 people viewed this question
Alun Cox
