Question about Linksys Wireless-G Broadband Router
Lan the yellow cable from my router has no appropiate connection on my tower or computer i have a netgear 4 port router
 i am having lan and my linksys is not responding  when i plug in the lan cable in the internet port the light is working but when i turn on my psp system psp is finding 100% network but the internet is not  running ?????
   please respond soon i am very much dependent on your reply to solve my prob if u still not get the problem i will agagin type everything but if you say so.......
        thatnkxxxx...........
Posted on Nov 14, 2008
    Brigadier General:
  • 6,966 Answers
If you are referring to the Ethernet cable, initially, it can then be presumed that your computer then has no LAN port. What would be required is purchase and installation of an add-on networking card. Although it is quite rare for most modern desktops not to have a built-in LAN port. The image below is an example of an add-on PCI LAN card
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
What are the numbers on my netgear n600 dual band gigabit router?
The numbers are the LAN ports on the router. When a number is turned on, it indicates a LAN device (computer) is connected to the router and is active.
If a device is connected to the router and that LAN port number is not turned on then either the LAN cable is faulty or the LAN card in that computer is faulty or LAN driver is not installed.
May 27, 2012 | NetGear N600 Wireless Dual Band Gigabit...
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
The CD is not available for installation is it necessary? I have all of the cable if the Yellow cable connects to the cable router what does the white cable on the wireless router connect to. Thank...
If the cables supplied have RJ45 connectors then they are used for connecting and configuring the wireless settings in Netgear router and to connect the Netgear to the DSL modem foe Internet access.
Most likely the color of the cables is not important.
To configure the wireless settings, connect a cable from one of the LAN ports (not the WAN/Internet port) to the LAN port on your computer. You may remove this cable after configuring the wireless settings if you want to connect to the Netgear by wireless only. You need to connect other computers to the Netgear's LAN port with a cable if they do not have wireless cards installed in these computers.
The other LAN cable is used to connect the Netgear WAN/Internet port to the DSL modem so you computers can connect to the Internet via the Netgear router.
Follow these instructions to configure the Netgear router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Feb 23, 2011 | NetGear WGT624 Wireless Router
At work we have a LAN connection, can a Netgear 834g router be used as a wireless access point by plugging the LAN into one of the ports, (using it as a port switch?)
yes you can use as a wireless access point by plugging lan cable in to the yellow coloured port on your netgear not any of ports, have a good day....
Feb 01, 2011 | NetGear DG834G Router
I8 only have 1 ethernet commector and need 2 had I know this i wouldn't have bought it in thr git=rst place!!!
You can add more ethernet ports by purchasing a 4 port hub or 8 port hub.
Connect a LAN cable from the Netgear wireless router to one of the ports on the hub and then connect the other computers to the ports on the hub.
Sep 03, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
How do i connect my netgear rangemax wireless router
You should have a manual/setup guide.
BUT, the basics of setting a wireless router are.
Connect an ethernet cable from your MODEM to the WAN port on the rear of the ROUTER.
Connect an ethernet cable from one of the LAN ports (usually 4) to your computer.
You now log on to your router via your web browser, set your wireless security (using WPA2) choose your password.
Save and exit from the router setup, disconnect the ethernet cable from your computer to the router and try and connect wirelessly
Your support page is here, choose which version of the router you have and download your manual
http://kb.netgear.com/app/products/family/a_id/1299
Aug 11, 2010 | NetGear RangeMax WPN824 Router
No LAN output from router
This router has 4 LAN ports and 1 WAN port. If you mean to say like if you are running out of LAN ports or if you require more LAN ports to connect more number of computers. Then you can buy a network switch which will help you connect more computers. All you have to do is run a ethernet cable from router's LAN to switch LAN
Aug 09, 2010 | NetGear RangeMax WPN824 Router
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
How do you hook up your netgear wireless router to your clear wire modem?
Hi Leon,
have alook at Clearwire's webpage (here), where they describe different setups for your router.
I personally would always prefer to connect the modem to the router via a cable. The cable you will need is an Ethernet (CAT5) cable and the connectors at the end look like this (compared to a phone cable:
You will connect the output of your modem with the WAN port of your router. This port is usually separated form the 4 other LAN ports, which connect to your computers, printers, etc.
(You didn't specify which router model you have, so I can't give you more details, but it should be very obvious, when you look at the back of your router.)
For the initial setup of your router, you should use a second Ethernet cable connected to one of the LAN ports of the router and to the Ethernet port of your computer.
If you need help with the wireless setup of your router, you have to look either in your manual of give me the details of your router (like the model and version, i.e. Netgear WGR614) and I'm happy to assist you.
Feb 25, 2009 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
No connection when installing WGT624 Netgear router
Plug an ethernet cable into the wan port of the router from your virgin modem... then plug ethernet cable from computer into a port on the router....that should solve your problem.
Jan 09, 2009 | NetGear WGT624 Wireless Router
Linksys Wireless-G Broadband Router Logo
51 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
