Question about Acer Aspire™ T180 PC Desktop
My pc showing yellow screen
Every time i try to boot up my pc only a yellow screen appear and nothing else happen ? how to sort out this prob ?
  • 849 Answers
Monitor gone bad, check your computer on other monitor
Posted on Nov 08, 2008
When i switch on my pc ,the hard disk light starts glowing but after some time the light goes off..nothing appears on screen ,the monitor never goes on plz help me sort out ds prob.
The problem would be solved with 80-97% (aprx) accuracy if you replace the CMOS battery and re-set the BIOS replacing/switching the CMOS jumper. 10-15% times this happens due to RAM problem. 5-10% chances for motherboard problem.
Jun 05, 2010 | Samsung Computers & Internet
Wont boot on its own, wont boot with install disc,
As the hard disk appears to be showing up when you boot up using the install disc, I would suspect that the system is somewhat corrupted. You could reinstall the system again and if you are happy starting from scratch and wiping the hard drive select this option failing that and there is some data on the imac you could install using the preserve user data. A fresh install should sort out any problems. Hope this helps.
May 18, 2010 | Apple 20" iMac Desktop
Pc won't boot ...
it seems to be an issue of a loose Hard drive connection.. you can open up a tower and re-connect the cable.
Feb 25, 2010 | HP Compaq Presario SR2150NX PC Desktop
I pluged in the power supply and nothing is happening. The small yellow batery icon came on near the screen and nothing else is happening
Remove the mains power lead and then take out the battery. Hold down the on/off button for 30 seconds to dispel any residual power.
Plug in just the mains lead (AC adapter) and see if the machine will boot on mains power only. If it does let it boot up and then shut it down again. Remove AC and reinsert the battery, plug in AC power again and see if it will boot with the battery in.
If it boots up the problem is sorted, if not then there is a problem with battery so you would have to use it on AC only until you find a replacement battery.
Please post back if need anymore help.
Good luck and regards.
Jan 11, 2010 | Dell Latitude D505 Notebook
Nothing appears on screen
This happens to me from time to time, i just cycle through my outputs and come back to HDMI (which is what i have mine hooked into) and it pops back in
Nov 26, 2008 | Sony Playstation 3 (PS3) Console
Inspiron 530S Power Save Mode Loop
First you need to make sure that there are no other removable devices plug on the system, like usb, external hard drives, then if that will work try to go to the bios, press f2 when you see the dell logo, and go to the system setup, go to the boot device configuration and make sure that removable device is not the first boot device, if it is the first one choose hard disk and then second boot device ad cd rom/dvd rom and then disable the 3rd boot and the fourth boot device. Make sure to save the changes. And restart the system again. Once the computer is back and running try to go to support.dell.com and check the bios, download if there is a bios update for the system.
Oct 30, 2008 | Computers & Internet
Toshiba L20 - screen appears dead?
Try to plug in an external monitor on laptop to check if there is a problem with your LCD.
Plug in the external monitor then boot the computer. If still nothing happens try removing the battery and the adapter, let it rest for a minute then plug in only the adapter and try to boot up with out the battery.
Hope this helps.
Sep 13, 2008 | Toshiba Satellite L20-S310TD Notebook
Sony vaio screen dark then light
might be going into a powersave after it boots...try checking the power options
Feb 28, 2008 | Sony VAIO PCG-K35 Notebook
Acer Aspire™ T180 PC Desktop Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
