Printer reports out of paper when its not - Office Equipment & Supplies
  • Anonymous Dec 01, 2008
    Indicates I'm out of paper even though I have paper.
  • lonestarpaul Mar 05, 2009
    ok, fine, need to check paper sensor, but would have been better if you would have given directions on how to check the sensor, as well.
  • 57 Answers
Hi simthr1,
try to check paper sensor,
hope this helpfull
thanks,
Hamedo
Posted on Nov 08, 2008
Printer t2280+ displays paper width error after printind only one line and stop . even on selftest without connecting to the system
Hello
When using the Show method of Data Report to preview the report, the page orientation defaults to the default printer settings on the local computer. Therefore, if the orientation of the default printer settings is set to Portrait of standard Letter paper and your report width is more than 8.5 inches wide, the following error occurs:
1. Make sure that there is no extra white space in the report. If there is any extra white space in the report, close up that section so that the ruler falls within the width of your default printer.
2. Set your Left Margin and Right Margin to 0.
3. Check your printer setting to ensure that your default printer is set up correctly. If the report is landscape (that is, greater than 8.5 inches) the default printer should be set accordingly.
Jun 29, 2011 | Office Equipment & Supplies
Printer reports blocked paper,even without paper.
This is a very old printer, I dought you'll get parts for thi printer. Pull out the paper tray and check under the printer, there should be one or two swing sensors. it should swing both ways. If it does'nt then it's either out of position or broken.
Apr 24, 2010 | HP LaserJet 4L Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Paper Jam message on every print job.
I have the same printer without the doc feeder. Check the paper trail thru the printer for the paper sensor lever hanging up. It gets pushed up by the paper and can stick, making the printer think it still has paper in it. Pulling the cart unsticks it till you print again.
Jul 03, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Printer says its out of paper, plenty of paper hp psc 1610
Another example of the paper sensor being messed up by paper dust, which can block the sensor to such a degree that it reports the wrong thing.
Clean the sensors with compressed air and then your printer will report the correct things to the central unit and you should be fine.
-a.
Jul 02, 2009 | HP PSC 1610 All-In-One InkJet Printer
Epson c90 paper feed problem
Is the message general error? The problem is tchip. When turn on chip is recognized by printer, but when start to print, printer "read" some information from the chip. Here is the error. Some pin at the chip for redaing the existence of chip, other pin for reading the information. Check connector between chip and carriage.
Apr 17, 2009 | Epson Stylus C86 InkJet Printer
How do I stop daily reports from printing? How do I change the default tray for fax reports?
To program a default paper tray to print fax reports, perform the following:
1. Select Utility/Counter.
2. Select User Setting.
3. Select System Setting
4. Select Paper Tray Setting.
5. Select Print Lists
6. Select the paper tray for the fax reports to print from.
7. Press OK.
8. Press Exit on the lower left side of the display to return to the copier screen.
to set the activity report to not print daily
1 touch the utility button
2 touch administrator settings and enter the password 12345678
3 press fax setting
4 press report settings
5 select activity report and change to off
6 press close then exit
Mar 17, 2009 | Konica Minolta bizhub C250 All-In-One...
I don't want fax receiving confirmation report it waste my paper.
Go to menu (wrench)
Arrow down to Reports - OK
Arrow down to Fax Reports - Ok
Hit Ok at Fax Confirmation
Select Never and hit OK
Hit Cancel when done and it should now not print confirmations.
Dec 05, 2008 | HP LaserJet M1522nf Multifunction Printer...
357 people viewed this question
k24674
jasbo
jasbo
