Question about Sharp Televison & Video
Cannot connect vcr to Lc-32AF3X aquos tv - Sharp Televison & Video
    Brigadier General:
  • 6,966 Answers
To my knowledge, most VCR units would have a yellow, red and white connectors commonly called RCA. What is required then is a triple RCA to RCA connector as shown below. The yellow is normally connected to the video, while the red & white are for the R & L of the audio. An identical set would be on the rear of the TV unit henceforth the connection would be OUT from the VCR to the IN of the LC-32AF3X. Thereafter, the TV must be set to A/V, V1, Video or Aux.
In some instances, a single cable is used to connect some models to the TV. This is called an RF patch cord and would look something like below. This would come form the RF OUT of the VCR to the RF/CABLE/ANT IN of the TV. Pls make sure that the style/form fits your units. Additionally, the TV must be set to either Ch 3 or 4 or whatever the VCR is using as its RF output channel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
No audio, no video but program guide displays
1. You should check you cabling connections at the satellite receiver to the TV.
2. Check the mode you are in on the HDMI cable
3. Your HDMI should have 3 modes in the set up screen (HDMI 1,2,3)
Apr 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
The cable connector running from tv is loose.
cannot be tightend. the coax connection is soldered in place. if you use a cable box or vcr you could use composite input and get a better pict. use the vcr or cable box to bypass tvs tuner
Jun 02, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Sharp Aquos LC-37D44U only shows B&W images from DVD & VHS source
First thing- why not just use the HDMI instead of standard def cables in the first place? Anyway- If the RCA-video (yellow composite cable) is not producing color, 1 of 2 things may be wrong: 1. You accidentally connected the a/v cables [yellow white and red] to [red green and blue] component inputs or vice versa, or.. 2. Your TV or DVD player is somehow set to the wrong video format. Check the DVD settings for video output format and video connector type. Format should be NTSC, and connector should be composite and/or s-video for the cables you're using.
If this is only happening when connecting the DVD player through the VCR, then check to make sure the same cables connecting the DVD player to the the VCR are also connected to the TV from the VCR.
BTW- if this is just to record DVDs to a VCR, I'll tell you it's not worth it. If your DVD player has an HDMI port, your picture quality will be so much better than if you're watching a VCR copy of one. Your new HDTV will look worse than an old standard def TV. Worse; I'm not kidding.
I hope some of this helps.
Jun 01, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No Picture with sound
sounds like you have a bad panel. This ussually happens when a backlight lamp has gone bad and the inverter board senses this and sends a signal to turn the backlight off.
Mar 06, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Connection problem
The best hook up for this unit is to use the hdmi if your samsung box offers hdmi output. The panasonic vcr should be hooked to any one of the composit video inputs with the yellow video cable and the red and white audio cables. If the vcr does not have composite output then use a rf (coax cable) to antenna a input and put the tv on channel 3 or 4 as vcr is set for.
Jan 13, 2008 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Aquos lc-26ga5u to mac mini
Adjust resolution on your mac mini to something the TV supports. Usually 1080 vertical resolution or below
Nov 07, 2007 | Sharp Aquos LC-32D40U Television
RCA tv
Check the signal type. It may be set incorrectly. Change the channel. You may be on a blank channel. Check to see if the TV is tuned to channel 3 or 4 if you are watching a videotape. Check the TV/VCR button on the VCR is in the correct mode by pressing the TV/VCR button on your VCR.
Aug 11, 2007 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Televison & Video Logo
90 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
