The blower motor blows air but its not hot air.
Is your heater not working properly? Is cold air coming with the vent? Or is the air flow too low? This can be frustrating for you, as the air in your home is getting colder.
This could be due to the fact that the air filter in your heater is not working properly. It has become jammed with dirt or has become a staple for air filter replacement. This prevents warm air from spreading in your room. So open and clean the air filter. This could be a possible solution to the problem.
5 easy solutions for heater problems5 easy solutions for heater problems
To
troubleshoot this types of problem,click the link below :--- -------- http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html --------- http://schematicsdiagram.blogspot.com/2011/12/heat-blows-cold-on-drivers-side-and-hot.html ----------- ------------ http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html ------------ http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html --------- http://technoanswers.blogspot.in/2012/02/heaterac-blower-motor-not-working-on.html ------------ http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html --------- This will help.Thanks.
Car heater blowing warm, but not hot air?http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html
Engine Overheats and heater
blowing cold?
Heat blows cold on drivers
side and hot on passenger side?
No heat on car?
http://technoanswers.blogspot.in/2012/02/no-heat-on-oldsmobile-silhouette.html
Heater blows intermittently and temp
gauge goes erratic?
Heater blows cold?
Heater/AC blower motor not working?
A/C, heater, defroster fan, not
working?
http://technoanswers.blogspot.in/2012/02/ac-heater-defroster-fan-not-working.html
Heater problem?
SOURCE: My blower motor is working, but it will not blow
You will need to replace the blend door actuators located inthe lower dash panel behind the stiffener board under the carpet. This will correct your temp control problem on your 1996 Volvo 850
SOURCE: no a/c on my volvo 93
Did you purge and recharge the AC system ? Does the compressor run when engine idles ?
Testimonial: "ok"
SOURCE: Hot and Cold no Blow
Most likely it will be the blower. Check to see if there is power to it, and then ground it. If it runs, the blower speed control is likely bad. If not it will be the blower motor.
SOURCE: My 1998 S70 check engine light will come on and
You have air in the cooling system.
Please see my tip at http://www.fixya.com/cars/r6235876-no_heat_fan_blowing_cold_air . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
To troubleshoot this types of problem,click the link below
:----http://howtobyme.blogspot.in/2012/02/heater-blows-only-from-defrost.html
--------Go through the procedure to confirm the
issue.
blowing cold?
No heat on car?
gauge goes erratic?
http://technoanswers.blogspot.com/2012/01/heater-blows-intermittently-and-temp.html------------Heater blows cold?
---------Car heater blowing warm, but not
hot air?
http://schematicsdiagram.blogspot.com/2011/12/car-heater-blowing-warm-but-not-hot-air.html--------
working?
Heater problem?
http://technoanswers.blogspot.in/2012/02/heater-problem-on-isuzu-trooper.html---------
