Jack up o/s of car and support on stand
Remove front o/s wheel
remove bottom engine covers from inside o/s wheel arch and also bottom engine cover(plastic)
support engine with jack; remove yolk engine mount ( on belt side)
Put 1/2" extension drive into top of belt tensioner and pull toward engine - you can now put a 3mm drill bit or allen key into hole at side of tensioner to hold in position.
remove serpentine belt
from underneath car, use 8mm ( I think) allen key to remove centre bolt from belt tensioner
Chances are that the Saab Ignition cassette is failing. You can find them on ebay, I recommend a new one since it is a common failure. Best to put new plugs in it while you are at it.
Easy to change, you just need a T-30 Torx (4 small bolts)
and one electrical connector on top of the engine. Oh and a good spark plug wrench.
Use a 6 or 8 inch 1/2 socket extension bar and place it in the top of the tensioner pulley, there is a notch in pulley for this. The tensioner pulley is near the firewall at the top of the engine....make a diagram of the belt routing and note which side( smooth or grooved) is lying on the pulley(usually grooved side of belt). Next you would pull tensioner pulley forward and slip the old belt off....you would route your new belt the same way and slip it on the tensioner pulley last.....you will need to pull the tensioner pulley forward again to get the slack you need to slide the belt over the pulley. I have found the Saab to be one of the easiest cars to change the serpentine belt on. I hope this helps.
