Question about Smeg WM16AAA Front Load Washer
Smeg wm16aaa error code e06 Can anybody help me on the above please
  • sales194 Nov 13, 2008
    I have the same problem , i have clean all filiters and hoses but has not cleared code any other ideas
  • grantturner Dec 08, 2008
    I've got the same problem qwith a Smeg Fab giving the error code E 06. If anyone knows what this means or where I can look it up... I'd really appreciate it.
    Problem Solver:
  • 8 Answers
HEre's a link to Smeg's web site with all the error codes:
The only problem is that the code doesn't really tell you a lot though apart from it's probably not draining properly. Does any one have any ideas for E06?
Posted on Dec 08, 2008
  • grantturner Dec 09, 2008
    Ok so basically the issue is either that the filter at the front bottom has some cak in it. if you have cleaneed this then remove the outlet pipe at the back and run water through it. If that works ok then the only thing left is the pump. I've been informaed by Smeg that it would probably mean a replacement pump is needed. One thing to try after cleaning the pipes and filter is to get a low level bucket and put the end of the outlet pipe into it to let the water drain off. So long as the bucket is at a low level it will allow the machine to drain off. Then try switching the machine off for a few mins, then back on and running another cycle. Last thing to check is that there is no blockage inside the machine where the water emptys through the hole in the rubber at the front. If none of that works then have a chat to SMEG support at this page:
    Hope this helps
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Aug 24, 2015 | Maytag Washing Machines
JVC GR-DVM55U Error E06
"E06" it is the carriage mechanism that has failed. and will not carry the tape to the heads and thus is not passing the sensor that tells you if the tape is in position and then telling the unit as it should there is fault.
take it to the nearest dealer and get it fixed.
Aug 23, 2008 | Televison & Video
Panel shows code error e06
tengo un error E06 tengo 2 meses que compre el equipo espero puedan ayudarme mi correo es
Jan 03, 2013 | Lime Pro Equipment D7.3 Treadmill
Kenmore dishwasher error e06
the error is linked to the float switch at the base of the dishwasher. Without model number and some description of the condition of the dishwasher leading to the fault code would be helpful.
in the meantime see this site and this too.
Jan 01, 2013 | Kenmore Dishwashers
Error 4 on my smeg washer, not doing any programmes only rinse
Smeg Error 4 states 'NTC- water in, short circuit or interrupted'.???
'NTC' stands for 'Negative Temperature Co-efficient' or water temperature thermostat to you and me!
Might be worth trying the following in case the thermostat is just stuck.
One way of hopefully getting around the problem is first to ensure the washer is empty then pour the contents of a boiling kettle into it. That can sometimes kick the device into correct action. It's worth a try anyway before having to call in the repair man ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 08, 2011 | Smeg WM16AAA Front Load Washer
No manual
ask them, they will get it within hours.
Aug 31, 2011 | Smeg WM16AAA Front Load Washer
Try turning power off, unscrewing the back panel of the machine and removing, reaching inside and giving the wheel which looks like a waterwheel (has 'fans') a couple of turns. This is the pump and sometimes small particles jam the wheel. Turn the power back on and if still in mid-cycle should resume and finish.
Apr 12, 2008 | Smeg WM16AAA Front Load Washer
WDI12C Machine Will Not Drain - Error Code E06
remove the two wires from pump connect two wires with a test bulb. this would eliminate the control issue if the bulb lights. 240 volt bulb. take it from there
Nov 24, 2007 | Smeg WDI12 Front Load Washer / Dryer
Open Questions:
See all Smeg WM16AAA Front Load Washer Questions
Smeg WM16AAA Front Load Washer Logo
4,522 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
