For the slow pick up of speed, change the EGR valve. A bad exhaust Gas Emissions valve will make it impossible to pick up speed or climb a hill of any kind. Fix the exhaust system leaks also, That could make the Oxygen sensor not work properly and cause the check engine light to come on. Once you've done all repairs, other than what I've told you, the light will not go out on it's own. You need to take it back to Auto Zone and have them turn it out electronically.
SOURCE: mk1 problem
could still be the clutch make sure it releases good or is not just done afdter testing new engine good luck
SOURCE: Clutch pedal goes to the floor(new clutch installed 2 wks ago)
that cable fited one side to cluch pedel and ather side fited gear box side where palte which is relecing clutch bearing. dont forget to adjust.
SOURCE: po299 code exhaust noise decreased performance in 2004 jetta tdi
I had the same problem. It was the EGR cooler pipe from the turbo to the pre-cooler before the exhaust inters the EGR valve. I replaced it myself. the pipe cost $103.00 from TDI parts online. There is a kit to block it off but it was more than the pipe. Blocking it off turns on check engine light. The EGR heat exchanger also preheats the coolant that goes directly to the heater core for quick warmups in the winter. Good Luck!
SOURCE: Clutch rattle
this sounds like an adjustment issue. you did not mention the mileage...The clutch is released by a bearing, this release bearing needs to come back off of the fingers of the clutch pressure place, early wear and noise happens.
Near the end of the clutch life, you may find that you cannot release any more, if your model is adjustable.
Start with proper clutch release adjustment.
Doc
Testimonial: "cheers, the problem only started today, i've not had any problems in the past. it's done 126000 miles but don't know if it's the original clutch."
SOURCE: clutch stopped working
BROKE RELEASE BEARING OR FORK OR AIR IN SYSTEM.CHECK CLUTCH MASTER CYLINDER BRAKE FLUID LEVEL IF LOW CHECK FOR LEAKS AT HYDRALIC LINES TO MASTERCYLINDER AND RELEASE CYLINDER.FIX AND BLEED THE SYSTEM.
