Question about Epson Stylus Photo R200 InkJet Printer
R200 jammed carriage Grinding belt
Thanks for responding.
I've always been able to slide the carriage. The belt moves with it. Very smooth, no resistance.
The belt isn't broken because it transports the carriage now as good as it ever has-- for ink loading and for all the many back and forth startup gyrations.
The belt is what causes the grinding. The teeth on the belt seem to be being forced over a locked gear causing the grinding.
Any other ideas?
Thank you.
~Dan
    Genius:
  • 1,447 Answers
Hi-
That's interesting... try to reseat the cartridges and make sure cartridge cover snaps when you close it. check for foreign objects inside the printer. You can check for parts if you need to replace one from a distributor, go to compassmicro.com
Hope this helps
Posted on Nov 08, 2008
Ink cartridge jam
Try cleaning the carriage bar. This is a shiny rod that the ink carriage slides back and forth on. Wipe it off with a clean rag and put a drop or two of light oil on the rod. The carriage should move easily back and forth.
May 01, 2017 | HP Photosmart C5280 InkJet Printer
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
Jan 18, 2011 | HP PSC 1610v All-in-One Printer
The power light is flashing and the printer makes a grinding noise and won't print. There was a paper jam that i had to pull out prior to this issue.
Hello According to HP, follow these steps for resolving the issue
Remove the rear access door, or the automatic two-sided printing accessory, and check for any paper jams or paper obstructions. Remove any obstructions. Check to make certain the carriage is on the right side of the printer. Rotate the rear paper guide rollers upwards five times, then downwards four times. If the rollers will not move, open the top cover and slide the carriage to the right (if it is not already there and if carriage can move). Try to roll the rollers again while pushing the clutch in. If the rollers do not move, continue on to the next step. Figure Location of the clutch c00040832.gif Replace the rear access door accessory, or the automatic two-sided printing accessory. Close the top cover. Plug the power cable back in. Turn the printer on, and replace the cartridges if possible. If the carriage moves, but there is still a grinding noise, there may be a paper feed issue. If the carriage will not move, then it is a carriage stall issue. After installing the cartridge, if the printer has a solid power light, perform a self-test on the printer. Hope this helps, if so do rate the solution
Jan 02, 2011 | HP DeskJet 3650 InkJet Printer
I replaced my color cartridge on my HP Photosmart C3100 series printer and now it is making a grinding sound, but prints perfectly fine - what is the problem?
You would want to try and reinstall the print cartridges. It is possible that something is just stuck that is why you are hearing the grinding sound.
Let me know.
Apr 06, 2010 | HP Office Equipment & Supplies
Carriage problem with grinding noise
Your printers carriage belt has gone loose you are required to change it. I'd advise you to send it to an expert because changing of a belt in your ink jet is not feasible with guidence through text messages.
Thankyou for using fixya free utility - Kindly rate my solution
Jun 27, 2009 | HP Deskjet 3845 InkJet Printer
Red warning lights remain on.....
Ink and paper light on : head carriage error/general error. Head can't move extremely to right : head carriage blocked or CR motor error. Turn of printer, unlock head carriage lock. Move head left and back to right (to parking position). Is it move freely?
Jun 16, 2009 | Epson Stylus Photo R200 InkJet Printer
I have the epson R200 and the ink carriage will not move across the printer anymore. You can manually move it back and forth freely.
Does anyone of you have a diagram that shows how to replace anEpson R320 Inkjet Printer Carriage Delivery Belt ? I have two of them. One has a belt broken and the other the black cartridge does not print (I have replaced it with a new cartridge and have cleaned the heads etc.) Any suggestions? If so, please email me at ril-2000@surewest.netThank you
Feb 28, 2009 | Epson Stylus Photo R200 InkJet Printer
HP Officejet 7310 carriage jam
I'll start by explaining some of the components you need to understand to troubleshoot the carriage system.
The Carriage is the thing the cartridges are mounted in, it slides on the carriage rail, the bushings in most newer carriages are made of plastic, (or maybe it would actually be called a polymer, or composite material). The bushings are the pieces that wrap around the carriage rail.
The carriage rail is a shiny round rod that the carriage rides on, it is driven across the rod by the carriage belt, by the carriage motor, at the opposite end of the belt there is an idler pulley, ".
In a HP printer the device where the carriage parks, (sits at), when the machine is not printing is called the service station, it is responsible for cleaning the print heads, and for capping the heads when you are not printing, (so they won't dry up). The bottom of the service station is the "Spittoon Base", ink is spayed into the base before printing to prime the heads, there is an absorbent pad in the base to soak up the ink. Note that the pad does not always soak up all the ink, so if you tilt an HP printer you can spill the ink out of the service station, (especially if it is a heavily used printer). The piece that moves back and forth in the service station is the "Sled", it was wipers to clean the heads on it, and the caps that keep the heads from drying out are also part of this assembly. The sled is moved back and forth before the carriage leaves the service statio to wipe the heads, this happens after the heads are primed, then the carriage is moved off the service station and the sled is again moved back and forth to clean the wipers.
The encoder strip is a plastic timing fence that looks clear at first glance, but has black lines painted on it. The strip is threaded through an optical sensor on the back of the carriage.
When the printer initializes the carriage has to leave the service station, or, if the machine was powered off when the carriage was somewhere else, whatever spot it is sitting in, and travel the way to the other side of the printer, and then return to it's home position which is the service station.
When the carriage reaches the side of the printer away from the service station it sets that as a reference, then it counts lines on the encoder strip as it travels home, if it doesn't see enough lines before it gets all the way to the other side and can't move any more then the printer decides the carriage must have something blocking it.
Sometimes a service station will fail in a way where the sled does not retract fully, if that failure happens when the carriage is parked then the carriage will usually not be able to leave the service station. If the service station binds when the carriage is off of the station, then the station may not be able to move all the way to that side, and will detect a carriage jam. When the service station binds you might hear a grinding noise as it's motor tries to drive the sled back and forth.
If the encoder strip is dirty the printer may not see all the lines and detect an error, often when the strip is dirty the carriage will move too fast and slam to one side of the printer.
I use water to clean the encoder strips in HP printers, water works well on water based inks, if your printer uses ink with another base you might use alcohol, but "ONLY" if the ink is not water based.
One end of the encoder strip is attached to a spring mount, if you wipe the strip starting at the end that is attached to the frame, and wipe only towards the spring mount, then the strip will stay attached to the printer.
A dry carriage rail will cause the carriage to bind, if the carriage does not move fast enough a carriage jam will be detected. Some newer HP printers use grease on the carriage rail, many models use a liquid lubricant, Use "ONLY" light synthetic or silicone based lubricants on printers that use a liquid lubricant, Petroleoum based products may melt the plastic bushings and ruin the carriage. (YES, Petroleoum based means WD-40)
some HP printers have a timing disc on the service station, and if the service station binds, or the timing sensor fails they report a carriage jam, but as far as I've seen that jam always occurs before the carriage moves.
You can use a synthetic lubricant on the carriage rail :hope this helps
Jan 09, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hi-
Normally it will not allow you to move carriage manually. Belt is broke. have it service or purchased a new one.
Hope this helps
Nov 08, 2008 | Epson Stylus Photo R200 InkJet Printer
HP 7210 - Carriage Jam
Your item jumped a knotch. Like the fan belt in a car, timing is off. Needs professional service. The carts are out of alignment.
Jun 02, 2008 | HP Officejet 7210 All-In-One InkJet...
Epson Stylus Photo R200 InkJet Printer Logo
188 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
